Old Aug 09, 2011, 11:06 AM
spacecase is offline
Find More Posts by spacecase
Vermont
Joined Dec 2003
An idea of how to improve a heavy stock video tx antenna
Well Im sitting here with this heavy 3 dBi antenna for my lawmate tx and Im thinking. Its heavy, and the lawmate gets got, so why not shave weight off the base of the antenna while making it a heat sink? I'm going to get a patch or 7 dbi duck antenna so I have one antenna to mess around with. I was going to turn the base of the antenna with a drill while cutting off disk shaped sections with a dremel and a cut off disk. I would increase the surface area while making it lighter, but am not sure if it will interfere with function of it.
spacecase is offline Find More Posts by spacecase
Old Aug 09, 2011, 11:30 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Im using the little stock antenna right now. It is really light. Maybe you could try an inverted V? They don't weigh too much.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Aug 09, 2011, 11:56 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
V is the way to go. Best mix of performance, light weight and low drag.
ian
Daemon is online now Find More Posts by Daemon
Old Aug 09, 2011, 12:21 PM
KCStar is offline
Find More Posts by KCStar
United States, WI, Poynette
Joined Mar 2011
I was impressed with the performance of the stock antennas at first until I tried the inverted vee and a patch, much better! And as a bonus the transmitter runs cooler. I haven't tried CP yet, but I'm planning to.
KCStar is offline Find More Posts by KCStar
Old Aug 09, 2011, 12:55 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
For whatever it's worth, what we used to call the "inverted V" really
has nothing particularly inverted about it. It's just a V Dipole (or Vee Dipole) and most
sites list it as such now including IBCrazy's.
A traditional inverted V (name used for decades) is a type of antenna run
from up to the top of a tall pole and then diagonally back to the ground, typically used for
lower HAM frequencies.
ian
Old Aug 09, 2011, 02:17 PM
Vermont
Joined Dec 2003
Cool, its still feels like a paper weight I think I am leaning to a V antenna and perhaps a patch antenna for the tx. What sort of range, unobstructed, would I expect with this set up? Just like ballpark?
Old Aug 09, 2011, 02:36 PM
Village Idiot!
Joined Apr 2011
ian
So when the plane is in a dive......Its an "Inverted V" ?? Cool!
Old Aug 09, 2011, 05:10 PM
KCStar is offline
Joined Mar 2011
ian
I built mine using the instructions on IBCrazy'y blog, Whatever it's called.
I think your right Daemon it's really not an inverted vee, it's just what I first heard it called. I wondered how it got it's name. As for range I'm getting 3/4 of a mile. I'm just starting out flying FPV, I could go farther but I'm taking it slow. I'd much rather fly a plane then look for it in mosquito infested terran. Been there done that, don't like it. Your results may and probably will vary.
Kent
Old Aug 09, 2011, 06:21 PM
Vermont
Joined Dec 2003
The inverted or not so inverted dipole antenna is a 3 dBi gain antenna. The original antenna is also a 3 dBi gain ant, but I have a feeling with the "inverted" its still going to be the same as the original. 3/4 of a mile running 1 watt of power may not really be taking advantage of the real range of what one might think.
Old Aug 09, 2011, 07:36 PM
Village Idiot!
Joined Apr 2011
V is better than 3/4 mile. I out to 2 with crystal clear video.
Old Aug 09, 2011, 10:22 PM
KCStar is offline
Joined Mar 2011
I agree, I have no problems with the video except maybe on a hard turn. I'm just taking it easy and enjoying it. Going a little farther each time when I feel brave enough. I'm hoping to get at least 2 miles someday. I'm using a 900mhz 1/2 watt transmitter with 72 mhz control.
Old Aug 09, 2011, 10:36 PM
caaraa is offline
Find More Posts by caaraa
Joined Apr 2011
caaraa is offline Find More Posts by caaraa
Reply With Quote  (Disabled)
Discussion Antenna Reflectors to Improve Video Range. scrtsqrl FPV Talk 41 May 25, 2016 03:30 AM
Discussion how to improve video receivers? [solved] mkmkmk13 FPV Talk 21 Jun 03, 2011 07:36 AM
Discussion Improve range on RC and video TX and RX eye-in-the-sky FPV Talk 49 Dec 07, 2007 12:44 AM
Discussion How To Improve The Range Of An 'El-Cheapo' Cam? littleport2003 Aerial Photography 12 Apr 30, 2006 12:52 PM
how to make a Tx wireless video antenna??? Help! CactusJackSlade Aerial Photography 7 Mar 02, 2003 12:02 AM
