This thread is privately moderated by Chuck, who may elect to delete unwanted replies.
Old Aug 08, 2011, 04:06 PM
Chuck is online now
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Mini-HowTo
3DHS Buck Huck Motor Box replacement
Well, the second time I bashed the motorbox, I decided to try the motorbox replacement kit, and I was impressed by how easy and straightforward it was.
First off, save the balsa bits that broke off so you can put them back in place when you put the box in.
The tools I used were:
X Acto knife
diagonal cutters
mini needlenose pliers
micro bar clamps
wife's emery boards
Epoxy- 30 min and 6 min
thin and thick CA
Debonder
pipette
kicker
You should have some scrap balsa in case you have to replace some balsa pieces.
Here's a pic of the plane with the front of the box removed.
Then with the rear of the box removed,
then, finally with the box completely out.
Use plenty of debonder to soften the CA and then gently pry the parts apart with your X Acto.
Use the diagonals to cut thru the thin parts of the ply so that you can take it out in small pieces.
DON'T FORCE ANYTHING, let the debonder do its job.
When you have it apart, cut the residual CA off of the parts in the plane so that the new box will fit.
Chuck is online now Find More Posts by Chuck
Old Aug 08, 2011, 04:20 PM
Chuck is online now
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Now, we take the new box and assemble it completely outside the plane so that we know what goes where. IMPORTANT, make sure that you get the right and left sides positioned correctly and marked.
Here is a picture of the box parts laid out,
and then partially assembled.
You probably won't use all the parts in the kit.
Old Aug 08, 2011, 04:28 PM
Chuck is online now
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Now, we start replacing the box. I didn't have to replace any formers or bulkheads, luckily.
The next pix show the progression of the replacement.
Old Aug 08, 2011, 04:33 PM
Chuck is online now
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Almost finished, front of box clamped so Epoxy can cure.
Old Aug 08, 2011, 04:39 PM
Chuck is online now
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Here is the motor mounted, then a pic of Jack with his new cowl and motorbox ready to huck.
Old Oct 26, 2011, 11:31 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
nice job, looks new again
3drcparts is offline Find More Posts by 3drcparts
Discussion 3DHS 48" EDGE 540 (1.5 Buck Huck) blucor basher 3D Flying 15391 Today 06:56 PM
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3DHS 48" Edge Orange "Huck Buck" NIB 170.00 Shipped boatdoc Aircraft - Electric - Airplanes (FS/W) 5 Aug 03, 2011 06:53 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
