Old Oct 22, 2001, 11:09 AM
dorysch1 is offline
Find More Posts by dorysch1
Electriaddict
dorysch1's Avatar
Melville Saskatchewan Canada
Joined Mar 2001
edfs in snow
It is snowing .................... what is the lowest temp anyone has flown EDF
dorysch1 is offline Find More Posts by dorysch1
Old Oct 22, 2001, 11:18 AM
Brucejay34 is offline
Find More Posts by Brucejay34
stonington , conn....usa
Joined Sep 2001
cold flying
I've done it in the teens b4...isnt alot of fun though like anything else when it's cold.......right conditons though wil put your plane alot farther away then where you think it would have landed..plane without gear hanging down like sledding...unless it's too fluffy then you get full too fast..and it's water so beware
Brucejay34 is offline Find More Posts by Brucejay34
Old Oct 22, 2001, 12:09 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Last winter I regularily flew my Bill Grigg's ElectroScreamer, a hand-launched, high wing plane with the fan on top of the wing.
It would ROSnow, resulting in some of the most scale like take offs I have ever experienced. If I remember correctly the lowest temperature was in the mid teens.
The low temp made no difference to the plane.
Landing on snow was no different than landing on grass except the plane would slide a little more.
Just keep the batteries warm until use
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Oct 22, 2001, 12:38 PM
dorysch1 is offline
Electriaddict
dorysch1's Avatar
Joined Mar 2001
what were you using for gear for ROS
Old Oct 22, 2001, 01:05 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Cold dry weather will actually improve your performance - more power will be drawn and stallspeed will decrease. Top speed wont be affected much as drag increase.
All this is due to the denser air.
Besides - the patt.back are great as handwarmers....
Haldor is offline Find More Posts by Haldor
Old Oct 22, 2001, 01:07 PM
dorysch1 is offline
Electriaddict
dorysch1's Avatar
Joined Mar 2001
what about battery life is it affected by the cold?
Old Oct 22, 2001, 04:51 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Battery life as duration or life expectancy?
Duration - maybe slightly less as denser air means more work which equal more amps - nothing huge but a little bit.
The motor tries to spin the rotor just as fast as before.
The cells would most likely be more comfortanle with the colder ambient temp. as it will not heat up as much as usual and it will cool down faster and come off the charger less hot.
Personally I like 70-80degF.
-Haldor
Old Oct 22, 2001, 05:03 PM
Joined Sep 2000
My ElectroSceamer has a flat bottom, no LG.
I added a 1/2" high x 1/16" thick x 6" long 'skid' to the bottom. This kept the plane tracking straight on the snow.
Things like this make my winters bearable.
Old Oct 22, 2001, 05:29 PM
Joined Sep 2001
larry's mods
so Larry.if it rains alot are you gonna swtch to floats?....I think it's funny you altered your plane for winter landings in snow....i'm just teasing you......Bruce
Old Oct 23, 2001, 12:16 PM
Joined Sep 2000
Judging from your address, you're no stranger to the white stuff. I never tried to ROW but the ES was successful off frosty grass and very wet leaves.
Its either fly in the snow or wait till spring.
This winter's flier will be my Twin Star with its wide, flat bottom.
I'll add a snow skid to the TS's bottom if the rudder won't keep it going straight.
Old Oct 23, 2001, 12:31 PM
dorysch1 is offline
Electriaddict
dorysch1's Avatar
Joined Mar 2001
I'll probably build a foamy pusher to look like the BD5 I'll use a foam wing repalcement from a Sig Cadet that is sitting at the hobby shop and make a foam fuse with a T-600 motor and an 8cell NIMH that will do the trick!
Old Oct 23, 2001, 02:43 PM
Joined Sep 2001
snow-monkies
I have an idea!..try an F86 with underwing tanks full of air for your ROW....better get a light one though...the tanks arent that big usually.........jk
Old Oct 23, 2001, 02:55 PM
dorysch1 is offline
Electriaddict
dorysch1's Avatar
Joined Mar 2001
that could be a recipe for a winged Jetski
Old Oct 23, 2001, 05:09 PM
Rob Andrew is offline
Find More Posts by Rob Andrew
Rob Andrew's Avatar
Newcastle, England
Joined Sep 2001
We used to have a WeMoTec Eco II powered He-132
R.I.P (Rest In Pieces)
We found that on hot days it would hardly climb, but on Cold days, it was a fantastic performer, may hav ejust been coincidence, but doubt it.
Rob Andrew is offline Find More Posts by Rob Andrew
Ratatat: Snoopy shot down in the snow robs Parkflyers 6 Jan 05, 2003 09:38 PM
Miniflash in the snow - I need skis! Martin Hunter Parkflyers 15 Dec 31, 2002 07:44 PM
Flying in snow JamesD Parkflyers 10 Jan 28, 2002 02:09 PM
how to land in snow ....... Paul Penney Electric Plane Talk 3 Dec 02, 2001 09:04 AM
how to land in snow ....... Paul Penney Electric Plane Talk 0 Dec 01, 2001 11:22 PM
