Espritmodel.com Heli Air
Old Aug 07, 2011, 04:39 AM
Australia, WA, Perth
Joined Feb 2011
Perth apogee challenge
This thread is for anyone in the Perth area interested in joining in a building/flying competition.
The plane is an apogee handlaunch glider. It uses a v tail for flight controls (only 2 servos). Should cost around $20-$50 to build depending on how you want to build it.
There are 2 parts to the competition. The first is to see who can build the lightest plane. The second is to see who's plane can stay inflight the longest. We are looking at staging the flying comp near Joondalup in early November, so you have a few months to build and test your plane.
The apogee is a fairly simple plane to build, but the critical aspects for performance are weight and getting the wing airfoil right.
Here's a link to the plans and build info.
http://www.charlesriverrc.org/articl..._apogeehlg.htm
Rules are;
1. Any construction method and airfoil is allowed as long as the wing and stab planforms for the 40" version are used. (you can use balsa/foam/carbon/fiberglass for construction as you see fit)
2. you can mod the fuse shape/size to accomodate electronics or adjust cg.
3. NO ailerons or flaps allowed
4. Weight competition includes all electronics including your choice of battery. (only one battery type allowed, so choose carefully to give enough flight time) You can have as many batteries as you wish, but they must all be the same and have enough capacity for 1 entire flight. You can use any type of battery (e.g. nimh, lipo, life, etc)
5. Flying competition will be all participants handlaunching at the same time (javelin style NOT DISCUS). First to land receives 1 point, second to land 2 points and so on until everyone has landed. Multiple rounds to be held on the day. The person with the most points at the end of the day is the winner.
So far we have 7 confirmed entrants; Here is how they plan to build
-Crasha, Built up balsa wing, composite fuse
-Trudge, cnc foam
-Metamorphisis, cnc foam
-Kaffine, cnc foam
-Plane sailing, full balsa
-Glidingfool, balsa and hardwood, builtup wing and x tail
-Swervo, easy to build straight wing
The comp is open to anyone in Perth who wants to join in. Shoud be interesting to see if there is any difference in the different type of construction.
As for the carbon tail booms, do you guys want to use plain carbon tube or would you like me to order some tapered carbon tubes from the States. Tapered carbon would cost approx. $15 each, I will make a bulk order if anyone is interested.
Let the building begin!!!!!!!!!!!!!!!!
crasha is offline Find More Posts by crasha
Last edited by crasha; Aug 09, 2011 at 08:04 AM. Reason: added Glidingfool and swervo, changed the rules to suit them!!!
Old Aug 07, 2011, 08:31 AM
Woodsy
Drouin, Australia
Joined Sep 2003
Nice looking little HLG, i'm shite at scratch building but if some one wants to knock up a few kits at a reasonable price i'd be interested.
woodsy is offline Find More Posts by woodsy
Old Aug 07, 2011, 09:05 AM
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
Bit of a trek to Perth just for a comp isn't it woodsy?
Nice sounding comp though, like the idea a lot
discostu956 is offline Find More Posts by discostu956
Old Aug 07, 2011, 11:01 AM
Joined Feb 2011
I'm totally shite at building as well but I am hoping to use this comp for learning how to be less shite.
Maybe we could have a national comp. Just post your planes weight and time (or maybe video) the flight. That would make things interesting
Old Aug 07, 2011, 03:26 PM
What will happen if ....Oh....
OSOFAM's Avatar
Australia, VIC, Sale
Joined Oct 2007
Great idea but I am having trouble with the link to the plans.
Is this the right plane; http://charlesriverrc.org/articles/a..._apogeehlg.htm
OSOFAM is offline Find More Posts by OSOFAM
Old Aug 07, 2011, 03:36 PM
Joined Feb 2011
That seems like the right plane, Give this a try
Old Aug 07, 2011, 03:55 PM
Woodsy
Drouin, Australia
Joined Sep 2003
Not when work pays
Old Aug 07, 2011, 05:54 PM
What you looking' at fool!
GlidingFool's Avatar
Australia, WA, Morley
Joined Mar 2011
I'm in
You are a seductive creature, Crasha. I have managed to build one MiMi (my first ever scratch build) that actually flies and was about to start another.
Now I will be building an Apogee instead:
  • All balsa and hardwood.
  • Built up wing
  • X-tail
GlidingFool is offline Find More Posts by GlidingFool
Old Aug 08, 2011, 06:46 AM
Perth Australia
Joined Feb 2010
' must be V tail only '.
swervo is offline Find More Posts by swervo
Old Aug 08, 2011, 07:48 AM
Joined Mar 2011
Tail
Oops. Missed that bit. I think it is a bit of a mistake. The Apogee is a reasonably dated design and the current thinking (from these groups) seems to be very much that a V-Tail is a real disadvantage for DLGing.
Nevertheless, wing ribs are being planned as we "speak"
Old Aug 08, 2011, 08:44 AM
Joined Feb 2011
G'day Glidingfool, glad your in!!
At the moment you are the odds on favourite since you are the only contestant who has actually successfully built a plane before
As for the x tail, I'm sure we can bend the rules a bit for you. The apogee was originally designed for a javelin style throw, hence the v tail because it is lighter. From my limited understanding of dlg the x tail is better for a discus launch (must help the plane to straighten out when thrown?)
The flying comp was intended for a javelin throw to help avoid the chaos of everyone launching at the same time.
If the x tail is for you than fill ya boots and see you in November for the showdown Just no aileron or flaps OK
Hey Swervo, are you in (I know you are a master builder)
Old Aug 08, 2011, 08:50 AM
Is my CG correct?
Wollongong, Aus
Joined Sep 2009
I did have a thought about the throwing part, as it seems that this may favour someone who is a better thrower rather then just better/lighter build. My thought was that whoever launches the planes rotates, so each plane gets launched once by each other "competitor" (or each person has one go at launching each plane). My thinking was that this would reduce any bias due to throwing skill
Old Aug 08, 2011, 04:18 PM
Joined Mar 2011
Oh. The pressure! When you see the plane, you will relax a bit. Although it flies surprisingly well, nothing is straight!
As for flaps and ailerons - wouldn't know what to do with 'em if I had them.
BTW, My Mimi which is also a built up wing, 1m glider came out at 170g ready to fly. The designer of the Apogee had a target weight of 120g! I guess I'll have to talk to Jenny Craig.
Old Aug 08, 2011, 06:31 PM
KE your cub.
Curare's Avatar
in the gutter, again....
Joined Jun 2005
I have something that approximates a MiMi, with flaperons and no rudder.
It's a bit of a flying brick and has been rebuilt more times than I care to admit. Catching tiny aeroplanes is HARRD!
Shame it's not an open comp.
Curare is offline Find More Posts by Curare
Old Aug 08, 2011, 11:15 PM
Joined Feb 2011
Those mimi's look pretty cool, what sort of flight times do you get from a throw? Do you think it would be better to bungee launch to get some extra air time in the comp and maybe even things out? (I throw like girl, just ask my mate who's habu was smashed when he asked me to throw it for him)
Started building my apogee tail feathers today. Unfortunately I used the wrong out line on the plan the and the tail was 3cm too short
MUST USE THE OUTLINE WITH THE GRID ON IT!!!!
I am not off to a good start
Help! How do I fix a cracked wing on an Apogee Elite? hoverfiend Hand Launch 15 Sep 09, 2011 04:38 PM
Discussion Perth South of River flyers Leadbelly1 Australia 23 Aug 20, 2011 06:03 PM
Help! Vacuum bagging machine Perth Kaffine Australia 136 Jul 08, 2011 09:02 PM
Sold Apogee Elite RTF FlyDLG Aircraft - Sailplanes (FS/W) 2 Jun 30, 2011 05:19 PM
Question Park fly in Perth this weekend? (WAS: Any FPV pilots in Perth?) Mark Harris Australia 52 May 26, 2008 08:08 AM
