Old Aug 06, 2011, 09:46 PM
feda is offline
Find More Posts by feda
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
New Product
Hokusei 40-in EPP SBach 342 (Video)
Hokusei released their scale verison of EPP SBach 342. It employs the same construction as that of their Cap 232 SC and Extra 260 SC. The plane seems to have very nice flying characteristics. Take a look at the video: the designer/pilot (Mr. Ikeda) has a total control of his little SBach!
バギーコースでSbach342をフライト! Hokusei Model Sbach342 EPP SC (2 min 55 sec)
Hope that you enjoyed the terrific 3D flying!
Regards,
feda
feda is offline Find More Posts by feda
Old Aug 08, 2011, 07:23 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Oh, that plane looks great! Are you going to be selling it?
rmgmag is offline Find More Posts by rmgmag
Old Aug 08, 2011, 09:44 PM
feda is offline
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Yes, Sir. The link is: http://www.bestvaluerc.com/shop/shopexd.asp?id=325
Here are the specs:
- Wing Span 1035 mm (40.7 inch)
- Length 990 mm (39.0 inch)
- Wing Area 21.3 sqdm (330.2 sqin)
- Flying Weight 670 g (23.6 oz) with no battery
- Propeller APC SF 11x4.7, APC SF 10x4.7, GWS SF 1147, GWS SF 1047
Old Nov 06, 2011, 05:59 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
feda, what's up with this plane? Does anyone have any flight reports?
Old Feb 05, 2012, 07:00 PM
itsmillertime is online now
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Thread revival. Any others with experience on this one?
itsmillertime is online now Find More Posts by itsmillertime
Old Feb 06, 2012, 04:34 AM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I keep looking at this bird, but haven't pulled the trigger yet, mainly because nobody has posted any videos or a flight report, and I don't want to be the guinea pig....
Old Feb 06, 2012, 07:29 AM
Joined Dec 2011
Looks like this is the airframe only for the same price as the others that are arf. But the others require new servos and hinges, weigh twice as much and have cheap esc's...
Old Feb 26, 2012, 06:06 PM
Cheap aeros is offline
Find More Posts by Cheap aeros
Well they Started off cheap!
Cheap aeros's Avatar
Australia, TAS, Hobart
Joined Feb 2012
half way through build
I took a gamble and purchased one. I am half way through the build and being my first foam "scale" am taking my time. So far I am very happy with the quality and it is easy to assemble. All instructions are in Japanese but all the important measurements are clearly overlayed on the pictures. I will be using the recommended dual sky xm2834 980kv motor. Starting on 10x4.7sf and 1000mah 3s lipo o until I get used to it then will probably go to 11x4.7 and lighter battery.
Cheers
Cheap aeros is offline Find More Posts by Cheap aeros
Old Feb 26, 2012, 07:14 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
@Cheap, it looks great. Really looking forward to your flight report.
Bob
Old Feb 27, 2012, 03:10 AM
Schrottflyer is offline
Find More Posts by Schrottflyer
Deutschland, BY, Augsburg
Joined Nov 2010
Yeah, it looks very good. Waiting for more Vids from this Plane.
Schrottflyer is offline Find More Posts by Schrottflyer
Old Mar 02, 2012, 02:16 AM
Joined Dec 2011
Cheers
Have you flown it yet?
Old Mar 03, 2012, 12:17 AM
Joined Feb 2012
not ready yet
Hi, I have not flown it yet, a few more little jobs and waiting on a 2.4ghz light receiver.may program up on my FM if I can't wait, but weather is supposed to bad here for the next week
Motor draws 19amps on 10x4.7 wot which is below the 24amp burst Max.(15s) on 3s lipos
Cheers
Jas
Old Mar 03, 2012, 03:08 AM
Joined Dec 2011
What servos would be good for a plane this size? I was looking at Hobbypartz solar series.
Old Mar 03, 2012, 04:54 AM
Joined Feb 2012
Not familiar with those. I am using hitec feather hs55, mainly cause I had them and the hxt900 need too much ply shaved for my liking to get them to fit. The horns are quite long17mm which means the servo arms are at the furthest point on the longest arm 26mm to get 45deg throw just hope they are up to it!
Old Mar 03, 2012, 06:17 AM
Joined Dec 2011
So size-wise the hs55 8 gram servos fit pretty well? And it takes 4 of the same size? These are the ones I'm thinking about. 1 gram heavier but about the same dimensions, digital, metal geared, centers well, ball bearings, fast and over 30 oz/in of torque. I also wonder how the Omega 72g motor would work on this plane. Overkill on power and I'd need a bigger esc but it only weighs 2 grams more than the recommended Dual Sky xm2834 980kv motor but with 165 more watts.
Build Log New EPP 42" Sbach 342 Build motorhead 3D Foamies 166 Feb 04, 2013 04:43 PM
New Product Hokusei Sbach 342 EPP HV groovejet 3D Foamies 9 Jun 12, 2012 01:27 PM
Sold E-Flite UMX Sbach 342 BNF (new in box) PatternFlyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 14 Jul 28, 2011 10:33 AM
Discussion Sbach 342 EPP scratchbuild! Video & Pics! mytmousemalibu Foamies (Scratchbuilt) 9 Feb 25, 2010 09:02 PM
New Product the first 100cc Sbach 342 in the world(pics and video) pilot-rc Giant Scale Airplanes 0 Sep 18, 2009 06:03 AM
