This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies.
Old Aug 06, 2011, 08:03 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Pitts 12 15e construction underway!!!
My new Pitts 12 15e from e-Flite came in a few weeks ago, and I was awaiting the motor and a few additonal bits [sullivan wire kit, dubro tail wheel kit] to complete the build.
This will be initially a 3S, 3800mAh system with a 900Kv, 770W motor. I will be using a 60A ESC (Eflite) and 4x HS82MG servos (Hitec) for the controls. A AR500 full-range RX completes the ensemble. I have a TruTurn 2.25" aluminum spinner painted gloss back to match the scheme, and I plan to use a MAS 12x6x3-blade prop. (see pix)
Wings and Elevator were done about 10 days ago, and I am now finishing the build. First major mod is the battery tray lowering to accomodate larger batteries. I cut out the upper front spar and made one using 3/16" balsa. (see pix) It is the same hieght as the rear spar, to allow the tray to ride on both.
This will allow a longer new tray to fit into the plane and manage CG better.
I also used Weldbond white glue on the front inner wooden surfaces to strengthen them a bit without adding a lot of weight...
More pix to come as we continue the build!
Darren/SkyCadet
SkyCadet is offline Find More Posts by SkyCadet
Sold E-Flite Pitts Model 12 15e Biplane milehigh club Aircraft - Electric - Airplanes (FS/W) 5 May 19, 2011 08:08 PM
Sold 1x E-Flite Pitts Model 12 15e ARF Hoangsta Aircraft - Electric - Airplanes (FS/W) 5 Nov 23, 2007 08:03 PM
Discussion E-Flite Pitts Model 12 15e... Safety Hawk 3D Flying 1 Aug 26, 2007 05:38 PM
New Product E-flite Pitts Model 12 15e ARF Bill K. 3D Flying 1 Aug 17, 2007 07:34 AM
