Espritmodel.com Heli Air
This thread is privately moderated by iflytailies, who may elect to delete unwanted replies.
Old Aug 05, 2011, 09:55 PM
aka Schleppmeister
PA
Joined Feb 2006
Trader Rating: 88
FEMA Retract, wheel brake, gas spring, servo holder, wheel cover, wheel, etc
All items are new and made by FEMA. Shipping is $5 no matter how many items you will order:
FEMA retract Z-9823
This FEMA retract is for sailplanes from 1/3.3 to 1/3.7 scale. For models up to 10kg/22lbs. Wheel diameter is 90mm/3.54in. No assembly required.
$199.99
FEMA retract Z-9814 A
This FEMA retract is for sailplanes from 1/2.5 to 1/3.2 scale. For models up to 16kg/35lbs. Wheel diameter is 127mm/5in.
$245
127mm/5in Wheel Brake FEMA Z-9810/11
Wheel brake for 127mm/5in. wheels. Assembly required
$43
152mm/6in. Wheel Brake FEMA Z9800/11
Wheel brake for 152mm/6in. wheels. Assembly required.
$49.99
FEMA Gas Pressure Spring 300N Z-9890/300
FEMA gas pressure spring, 300N springiness
$45
Servo Holder for Retract FEMA Z-9890/20
Servo holder, suitable for all retractable FEMA undercarriages
$8
Reversing Lever FEMA Z-9890/22
Reversing lever for wheel brake, suitable for all retractable FEMA undercarriages
$14
Wheel Cover FEMA Z-9810/14
Wheel cover from glass for wheel diameter of 112-127mm /4.5-5in.
$49
FEMA Wheel 152mm/6in. Z-143
$49.99 per wheel
FEMA Wheel 178mm/7in. Z-145
$57 per wheel
More items available at:
http://www.iflytailies.com/
iflytailies is offline Find More Posts by iflytailies
Sold FEMA retract iflytailies Aircraft - Sailplanes (FS/W) 0 Apr 28, 2011 04:53 PM
Discussion Castle Creation 60amp ESC-programming for EDF'S,brake,timing etc ? redtail Electric Ducted Fan Jet Talk 2 Apr 25, 2011 03:30 AM
Wanted wanted srping air nose wheel retract i-fly-any-and- Aircraft - General - Miscellaneous (FS/W) 1 Mar 15, 2011 06:13 AM
Sold NIB Air Power EV1U Proportional Electronic Brake/Retract/Speed Brake Valve Kevin Greene Aircraft - Fuel - Jets (FS/W) 0 Sep 08, 2010 09:20 PM
Help! Need FEMA Retract Dimensions SoarScale2 Scale Sailplanes 5 Apr 25, 2009 10:25 AM
