Old Aug 05, 2011, 12:53 PM
Axefly is offline
Find More Posts by Axefly
South Africa
Joined Feb 2010
Question
Can i remove integrated esc bec (turnigy plush)
I've just got a deal on a heli but the guy handed me a turnigy 80 amp plush esc that works,
However it's intergrated bec has smoked.
I see the esc consists of 2 or 3 pcb's plugged into each other, now the guy tells me the silver square thingy is the bec that smoked, it looks to be locked or slightly soldered into the pcb on both sides of the square bec box via 2 sharp edges from the bec entering the pcb
Can i unplug the esc pcb's and just try and notch the bec off ? or would that make the esc stop from working
Axefly is offline Find More Posts by Axefly
Old Aug 05, 2011, 02:34 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If the BEC is totally dead and not drawing any current at all, you could just leave it alone, (less risk of damaging the main board).
One slight risk is there being some charring to the board if it got really hot and maybe some carbon deposits on the board, that may cause a problem, (clean the area).
The ESC only needs the -ive and signal wire from the Rx to work, (and obviously the flight battery). And the Rx and servos just need a new supply from somewhere.
Remove the red, center wire from the ESC's connector to Rx lead, and just add a stand alone BEC, (UBEC/SBEC best), or even use a separate 4.8v, (4 nimh cell) pack the power the Rx and servos.
If you think you can remove the old BEC fairly easy, Ok, but watch for any solder splashes, wiskers, shorts etc, when desoldering.
eflightray is offline Find More Posts by eflightray
Old Aug 05, 2011, 10:32 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I for one don't know the answer to that question - but if you disconnect the centre red wire from the ESC RX lead as eflitray said, that will allow you to use a UBEC or RX battery.
If the ESC, along with a suitable UBEC or RX battery doesn't then work, you probably have no alternative to removing the smoked circuit board - and if you do have to do that, please do tell us the results!
Good luck!
2Doggs is offline Find More Posts by 2Doggs
Old Aug 06, 2011, 03:58 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
The BEC is underneath the 'silver square thingy' (which is just a metal shield).
No. The pcbs are soldered together and not easy to separate. Chances are that it won't hurt to leave the faulty BEC in, so just disconnect the red wire and try it...
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Aug 06, 2011, 03:42 PM
Axefly is offline
South Africa
Joined Feb 2010
Thanks guys, No this pcb is not soldered together, it plugs in kind of like pc cpu's plugs into the motherboard, i'ts easy to spot that it is plugged in this way, now, what i don't know is if the thingy underneath the silver square is soldered onto the board ? And if i remove it will it somehow cause and open circuit so the esc won't work at all ? (is it soldered like a capacitor onto the boars or lis it more like a microchip with those many small wires that can only be basically soldered by robots ?
Old Aug 06, 2011, 05:45 PM
Joined Jan 2001
Interesting. Perhaps they have recently changed to plug-in connectors?
Here's a Turnigy Plush 80A with the BEC shield removed. It appears to be identical to my Hobbywing Pentium 80A, which has pins soldered between the two pcb's. I was able to remove the shield without separating the boards.
To disable the UBEC circuit you only need to disconnect pin 2 of the ACT4070/MPS1593 switch-mode regulator chip (2nd pin from top right). The easiest way to do this is simply cut the pin off with a sharp knife.
Old Aug 07, 2011, 01:36 PM
Axefly is offline
South Africa
Joined Feb 2010
You mean this one (encircled in black) Feels like i'm in one of those bond movies diffusing a bomb !
If i remove the whole chip, would my esc not work ?
Old Aug 08, 2011, 04:35 PM
Joined Jan 2001
Yes, that's it. Just make sure you're in a Bond movie, not episode 22 of Sledge Hammer!
Removing the whole chip is very difficult (it has a bottom pad soldered to the pcb) but you can cut off all the pins if you wish.
Old Aug 14, 2011, 07:37 AM
Axefly is offline
South Africa
Joined Feb 2010
"Yes, that's it. Just make sure you're in a Bond movie, not episode 22 of Sledge Hammer!"
lol, i wouldn't want anything to go wrong !
"Removing the whole chip is very difficult to remove (it has a bottom pad soldered to the pcb) but you can cut off all the pins if you wish."
thanks
Old Dec 25, 2014, 07:23 AM
izzzzzz6 is offline
Find More Posts by izzzzzz6
France, RA, Chamonix-Mont-Blanc
Joined Dec 2013
Is there a thread to explain how to disable the BEC on the Plush 6A ESCs? They use different voltage regulators. Basically i'm not using any of the 4 BECs as my FC is wide input and everything is working on 2S i only have the signal wires soldered directly to the board. I removed all other wires.
izzzzzz6 is offline Find More Posts by izzzzzz6
Old Dec 25, 2014, 07:44 AM
izzzzzz6 is offline
Joined Dec 2013
Just found the answer to my question in a round about way. Here is the info that will show how to remove the BEC on 6A Plush. Since i don't need any of them i think i may get a bit more fly time with this mod:
http://www.helifreak.com/showthread.php?t=591619
Old Dec 25, 2014, 11:11 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Jeez. Just remove the red + wire from the connector and tape it back.
tp
Mark Wood is online now Find More Posts by Mark Wood
Old Dec 28, 2014, 01:19 PM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Yeah, it's not that big a deal at all:
Depronicus is online now Find More Posts by Depronicus
Wanted 30Amp Turnigy Plush ESC JimClark Aircraft - Electric - Power Systems (FS/W) 2 Jul 20, 2011 12:53 PM
Help! Using hobbywing pentium esc and turnigy plush esc on one quad tahi_88 Multirotor Talk 1 Jul 12, 2011 01:43 PM
Sold AXI 2826-10 with a Turnigy Plush 60A ESC (((SOLD the ESC / re-listed the motor))) bah7566 Aircraft - Electric - Power Systems (FS/W) 2 Jul 05, 2011 03:11 PM
Sold Turnigy Plush 60 amp ESC melsailsnorth Aircraft - Electric - Power Systems (FS/W) 2 Jul 01, 2011 11:13 PM
Sold Turnigy Plush 60amp esc w/ programmer, Turnigy aerodrive C3548-800kV w/ spare shaft nephewkp Aircraft - Electric - Power Systems (FS/W) 4 Aug 27, 2008 08:48 AM
