Old Oct 22, 2001, 06:54 AM
buckeyes1997 is offline
Find More Posts by buckeyes1997
buckeyes1997's Avatar
columbus, oh, usa
Joined Jun 2001
best value in 30amp ESC
hello could someone suggest a good 30amp esc. im planning on using it with a MM. i have an fma20 and it is a great unit but not rated high enuff. my definition of value is cheap but quality stuff.
thanks for the info.
matt
buckeyes1997 is offline Find More Posts by buckeyes1997
Old Oct 22, 2001, 07:10 AM
p471701
p471701
Guest
n/a Posts
kontroniks sun4001
Old Oct 22, 2001, 08:28 AM
LJH is online now
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
I have been useing the Kontronics Easy 3000. I don't remember the price but when I was looking around it was fairly priced and I have been useing two of them for a year and a half with no trouble. One of them actually spent four weeks 60' up in a tree. When I finally got it down it was a bit faded but I pluged it in and it is still pumping the amps to my colbalt 4014 in my PJC. Hope this helps.
Cheers,
Jim
LJH is online now Find More Posts by LJH
Old Oct 22, 2001, 11:37 AM
columbus, oh, usa
Joined Jun 2001
what do you think of this one
Watt-Age IC-30 ESC, 30 Amp, Brake, BEC-A/C, rated to 30A
or this one
Watt-Age IC-550 Motor Controller w/BEC Splug rated 35a (60peak)
or even
Watt-Age IC-380 30A ESC w/BEC S Conn
has anyone used these and how well did they work?
also what are the differences?
thanks
Old Oct 22, 2001, 12:07 PM
rcdude is offline
Find More Posts by rcdude
San Jose, CA
Joined Mar 2000
Pegasus 35 is my choice. Made in America!!!
rcdude is offline Find More Posts by rcdude
Old Oct 22, 2001, 12:39 PM
dezflyer is offline
Find More Posts by dezflyer
heli on the brain
dezflyer's Avatar
Apple Valley/Victorville, Ca
Joined Apr 2001
...i use the wattage ic-30 (high freq) in my 450 turbo/willets zagi. ive had no problems whatsoever. the only thing that i dont like about it is the soft on/off feature that slowly raises the rpm up to speed when floored. it really isnt too big of a deal, however, yesterday i planted it from about 50 ft. and the soft off barely turned the motor off before impact. all in all though, as for performance , its a good esc. along with any of the others mentioned here.
dezflyer is offline Find More Posts by dezflyer
Old Oct 22, 2001, 01:02 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Great Planes C-30 works great, and great price.
http://www2.towerhobbies.com/cgi-bin...1&I=LXUR96&P=7
DNA is offline Find More Posts by DNA
Old Oct 22, 2001, 03:43 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
WattaAge IC-380 and -550 are FRAME RATE and are only suitable for use as soft on/off switches. They are also big and heavy by current standards. Beyond that, between overheating motors and killing gearboxes..... well enough said.
The newer WattAge units (IC-30, -15, -5,-2) are high rate and work well (though I've had RF issues with the -30).
My own answer to the question posed at the top of the thread is Kontronik Sun 3000. (The Sun 4001 is a 40A unit, the Easy 3000 is out of production.)
Of US made units, the Castle Creations Pegasus 35 is definitely the best value (though $14 more than the Kontronik Sun 3000), and is smaller and lighter than the Suns (a little). However, the Pegasus doesn't have a brake. If you don't need one, that's no problem.
The GP units (from somewhere in Korea) work well as long as you stay well within their published limits.
As always, too many words.....
BEC is offline Find More Posts by BEC
Old Oct 22, 2001, 03:49 PM
DaJudge is offline
Find More Posts by DaJudge
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
I have both the Pegasus 35 ($49) and the Sun 3000 ($35).
I've been pleased with both. If they were the same $$, I'd say go with the Pegasus since it seems to operate more smoothly as you adjust the throttle.
DaJudge is offline Find More Posts by DaJudge
Old Oct 23, 2001, 08:05 AM
columbus, oh, usa
Joined Jun 2001
finally picked one
i really wanted to save some bucks and get the watt-age but im glad i asked first. i ended up looking at the castle creations and the kontronics and because of brake went with the kontronics. these should be able to handle the kinds of current i want with my MM setup. any ideas on batteries?? from what i gather the 8cp1600's and up are what i want? where is the cheapest place to buy those from?
thanks for the help on esc's guys/gals
Old Oct 23, 2001, 11:50 AM
rcdude is offline
San Jose, CA
Joined Mar 2000
8cp1600's ???
You mean 8 cells CP-1700SCR? There are a lot of places to buy them. Check the advertiser index.
Question Informed opinion on the best value in 1/10? em Electric Power Cars 2 Nov 20, 2006 07:37 PM
Sold Great Planes 5 ch Hi-band Rx with Built in 30amp ESC- autoshift Etonic Aircraft - General - Radio Equipment (FS/W) 3 Aug 22, 2005 08:16 AM
Small businesses are the best value in America sal Vendor Talk 11 Jul 22, 2003 12:05 PM
Best Value in Controllers CptCrunch Electric Plane Talk 11 Mar 20, 2002 02:16 PM
How many motors can the GP C-30 (30amp) ESC power and in what configuration??? kiwip Power Systems 8 Jul 30, 2001 01:53 PM
