Old Aug 04, 2011, 10:31 PM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
No power at new RC club
I've joined a new RC club that has no power. I'm not set up for charging with a generator or deep cycle batteries. I'm using a Hyperion duo II (may upgrade to the new Icharger) charging mostly 3s 2200 to 4s 5000mAh at 10 amps.
whats the best way to go
I've hear of people using two 12V deep cycle in series (24V) for 30 amp charging. Then using a generator and battery charger to charge the deep cycle batteries. Is this the best way? or can I just hook my power supply and hyperion to the generator?
Was looking at a 2000watt generator at costco for $500.
Any ideas would be much appreciated.
D.B.
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Aug 04, 2011, 10:59 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
In my opinion, yes. Do NOT run your charger directly from the generator. The power is not filtered enough for such use.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Aug 04, 2011, 11:19 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
mw
That would depend on the generator. The honda generators are fine
Hance is offline Find More Posts by Hance
Old Aug 04, 2011, 11:41 PM
How about this one?
http://www.costco.com/Browse/Product...uctsInCategory
Old Aug 04, 2011, 11:48 PM
Hance is offline
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
It is an inverter so it SHOULD be ok. I don't know for certain though.
Old Aug 05, 2011, 12:03 AM
DonA is offline
Find More Posts by DonA
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
Couple comments
The specs don't list the db rating on it so I would expect it to be noisier than an equivalent Honda. Run times seem a little short even in Econo-mode. Other than that, it looks fine.
Don
DonA is offline Find More Posts by DonA
Old Aug 05, 2011, 04:04 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
There are hundreds of posts on generators and the options available. Use the search facility and you'll find a wealth of information.
Ohmic is offline Find More Posts by Ohmic
Old Aug 05, 2011, 08:22 AM
Tried that but turned up nothing. Maybe you could point me in the right direction?
D.B.
Old Aug 05, 2011, 09:25 AM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
I went to search and entered Generator and selected titles only, Display as Threads and restricted it to this forum only. That found 23 threads averaging maybe 20 posts each. Probably worth a look.
Removing some of the restrictions (like this forum only) greatly increases the list of matches but also increases the "noise" that you have to sift through.
Dave H. is offline Find More Posts by Dave H.
Old Aug 05, 2011, 09:39 AM
Would someone be kind enough to post a link to the generator thread.
Damned if I can find it. I always look first before asking. My search turns up nothing
Old Aug 05, 2011, 10:07 AM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
How did you put that list of threads here, without retyping them all? Or did you?
howell
gwinhh is offline Find More Posts by gwinhh
Old Aug 05, 2011, 10:11 AM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
I think I paid around $160 for two 85ah costco deep cycle batteries. Wire them up in series and charged my 12s 5000mah packs all day. No need for a generator, just recharge the deep cycles when you get back home. The draw back is they are heavy. I put them in a milk crate and use that wonderful little $20 fold away dolly at costco to wheel them to the pits.
TheTick is offline Find More Posts by TheTick
Old Aug 05, 2011, 10:23 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
My generator used to power my MasTech 5020 power supply for doing A123-10S2P @ 20amps (38V -- 760watts) is my running 2007 For Explorer and Vector 2000 Watt Inverter -- big Inverter Generator!
jrb is offline Find More Posts by jrb
Old Aug 05, 2011, 10:51 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
howell
Opened another Tab and used the Search function to find the Links.
Used copy Link ,switched Tab (back to here) pasted then switched back to Search tab ,repeat.
Charles
Discussion Im trying to start RC Club at my school RCSUPERCARZ Chit Chat 19 Nov 22, 2011 06:14 PM
Video SAM Contest Day 3 at Tn Eagles RC Club in Harriman TN RcFlyerJeff Fuel Plane Talk 0 Jul 20, 2011 08:54 PM
Video Gassers At Mather Aerospace Modelers RC Club DMEN Fuel Plane Talk 2 Jul 03, 2011 06:58 PM
Discussion New RC club with no RC experience hawk rc Electric Plane Talk 9 Aug 24, 2007 05:07 PM
