Old Jul 06, 2001, 07:20 AM
Airnut 2 is offline
Find More Posts by Airnut 2
Innisfil, Ontario, Canada.
Joined Dec 2000
Great planes elictrifly C-50 question.
i recently purchased this SC for my Kyosho T-33. The instructions say that the supplied Schotky Diode must be installed on the motor
or the SC could be damaged.I do not want to remove the motor from the fuselage, but it looks like that is the only way to install the diode.( not an easy task!) Do I really need to use the Diode or will the SC work OK without it?
George
Airnut 2 is offline Find More Posts by Airnut 2
Old Jul 06, 2001, 08:35 AM
Rod is offline
Rod
Find More Posts by Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
Yes you need the Diode. Solder it to the motor terminals with the bar on the diode at the + terminal. It will prevent current from the motor (when free wheeling) backing up into the ESC. Remember that a motor becomes a generator when it is driven -- by the prop when power is shut off and the motor free wheels.
Rod is offline Find More Posts by Rod
Old Jul 06, 2001, 09:03 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You need the diode or your ESC will be toast. However, you can solder the diode to the output of the ESC, doesn't have to be across the motor (although that's usually best).
It's not to protect from "freewheeling" generated current, that's low voltage similar to that put in. The diode is there to absorb reverse EMF spikes that are generated as the comm. segments move under the brushes. These pulses can reach dozens or even 100's of volts, and will fry your ESC's FET's. They're small spikes, however, so the diode simply conducts them and dissipates the minimal power.
..a
Old Jul 06, 2001, 02:18 PM
Airnut 2 is offline
Joined Dec 2000
Thank you very much fellows!That answers my question.
George
Old Jul 07, 2001, 12:04 AM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
As Andy said, it is better to attach it directly to the motor, but if this is a no-go, then you could just solder it to the wires by the ESC. Just don't get the ESC too hot!
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
For Sale: Great planes Electrifly C-3 ESC sky guy Aircraft - Electric - Helis (FS/W) 1 Jan 12, 2003 04:18 PM
FS: Great Planes Electrifly C-30 ESC sky guy Aircraft - Electric - Airplanes (FS/W) 3 Jan 08, 2003 06:21 PM
Great Planes Cap 231EX Power question Mike Parsons Foamies (Kits) 3 Nov 27, 2002 10:51 PM
FS: Great Planes Electrifly C-20 ESC NIB snoozer Aircraft - Electric - Airplanes (FS/W) 1 Sep 07, 2002 06:34 PM
Great planes electrifly C-30 amp. limit? electrohead Power Systems 0 Dec 26, 2001 02:05 AM
