Old Aug 04, 2011, 10:38 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Build Log
x5 flying wing from bevrc.com (maiden video on page 1)
Ordered one on June 26th and just got it delivered this morning from bevrc.com This is going to be my ''beater'' so keep in mind this is for pure fun, not duration/long range flights
http://www.bevrc.com/x5-flying-wing-p-255.html
Box came in dented pretty bad on one corner and girlfriend signed it anyways
...all resulting in a crooked/bent right wing...but there's not much to worry about, I've seen far worst
Pretty impressed with the molding and EPO's quality. There is lots of room for all FPV gear and big lipo pack (in above picture it's a 3s 5000mah 40c/80c)
Winglets:
Hardware that came with the plane is pretty much useless and incomplete so I'm going to use my own. Didn't even bother taking pictures of the bag.
Repairing the damaged wing was easy but time consuming. Manage to staight it up pretty good and decided to install carbon fiber ribbons on top / bottom to stiffen the wings:
Glued the motor mount with gorilla foaming glue:
Notice the top screws do have 3 washers to give the motor some angle as per website build log:
The nose of the plane was molded so you can fit your fpv cam nice and clean:
Some foam trimming might be necessary so you don't see the nose's sides but this should be an easy task:
Setup will be as follow:
Turnigy PLUSH 40A ESC
Turnigy C3530 1700kv outrunner
APC 7x5 prop
3s 5000mah 40c/80c pack
EzUHF
Sony 1/3 cam or RCV922 (have both so will try them)
Lawmate 500mW vtx either 1.2 or 2.4 GHz (have both also so need to try)
HK battery monitor osd
More to follow soon !
saucisse is offline Find More Posts by saucisse
Old Aug 04, 2011, 10:42 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Ready for its maiden flight
Ready for its maiden flight! AUW is 2lbs 6.2oz including all FPV gear and a fat 3s 5000mah 40c/80c pack. I'm going to test some 3000mah also.
Here are the numbers the wattups came up with the actual setup:
prop 7x5: 26.46A and 290.7 W
I know, it's an orange rx for now but maiden flights are always done with out fpv gear, I'll put dummy weights to save my gear in case of bad crash lol and put back if successful
Old Aug 04, 2011, 11:15 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
We should get Trappy one of these, it looks like it can float
Cheers,
Sander - ImmersionRC
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Aug 04, 2011, 11:25 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What was the reason of propulsion choice, do you intend to fly this so fast? This is a setup for +110kmph speed... not exactly what I expected for this whale shaped lady...
renatoa is online now Find More Posts by renatoa
Old Aug 04, 2011, 12:09 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
HAhahahah good idea!!
Cheers,
Renatoa: Because this is all I had lying around. Depending on how it behaves I might order a different motor/prop combo. Like I said, it's a ''beater'' for fun. I needed one plane for fast close range flights, skimming the trees, low passes and stuff with out fearing to destroy it, sander's style lol
Old Aug 04, 2011, 12:35 PM
KristianS is offline
Find More Posts by KristianS
FPV addict
Giske, Norway
Joined Aug 2009
Nice build!
I've been tempted to buy this plane/wing as well.
Keep us updated on the maiden flight
KristianS is offline Find More Posts by KristianS
Old Aug 04, 2011, 01:22 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Subscribed.
I like the look of it. The cg was no prob with a 5000mah bat?
NDw is offline Find More Posts by NDw
Old Aug 04, 2011, 02:06 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Nope. If you look at the last picture, the lipo is at the right place to balance the cg.
Originally Posted by NDw View Post
Subscribed.
Old Aug 05, 2011, 12:48 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Maiden flight: check !!
I'll post some videos as soon as I get the chance.
Old Aug 05, 2011, 10:03 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
So here it is!! I must say that my expectations were not too big on this one and will admit that I was really surprise on how well this plane performs once balanced and trimmed properly. Be careful, this plane requires very little travel on the elevons.
It just feels solid and almost on rails. I guess the extra reinforcements I did has to do for a lot. Cannot wait to put my FPV gear in this one. All I can say is go get one!
Enjoy !
x5 flying wing mainden flight (2 min 50 sec)
Old Aug 06, 2011, 12:21 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Almost ready for the FPV maiden flight. The only thing missing is the 8ch EzUHF rx.
Old Aug 06, 2011, 02:38 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Wow Saucisse ! this really looks promising !
what duration did you get out of that flight ? what were the amps consumed ?
It looks like this has a varied range speed, I bet it would glide just as well
rcmonster99 is offline Find More Posts by rcmonster99
Old Aug 06, 2011, 04:00 AM
ssassen is offline
Joined Jul 2004
Merci beaucoup monsieur Saucisse, ca c'est tres bon!
Cheers,
Old Aug 06, 2011, 04:19 AM
mudlark is online now
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Good stuff there Saucisse. Shame about the damage.
Mine arrived yesterday. No damage.
Only six days from BEVRC to the UK and no duty to pay.
I'm looking at building mine a bit lighter and slower.
Wanted it on a 2200 to 3000mah 3S pack running at 300watts max.
Do you recon that is possible or does it need a brick up the frount?
mudlark is online now Find More Posts by mudlark
Old Aug 06, 2011, 04:22 AM
Houba ! Houba !!
Joined Sep 2003
I will be watching this thread ! I like this plane for general messing about. did you see the building log from bevrc ? only 15 degrees movement on the ailerons and the motor tilted downwards... interesting.
Discussion New X5 Flying Wing for FPV from Skywalker manufacturer alishanmao Flying Wings 77 Jun 21, 2016 11:16 AM
Discussion GAUI X5 Review @ www.flying-hobby.com! fung Large Electric Helis 229 Mar 29, 2011 01:19 AM
Discussion Flying wing pusher prop - wing turbulence effect Stunt Double Flying Wings 7 Mar 16, 2011 10:27 AM
Discussion Bell X5 Swing Wing BulletMaster Electric Ducted Fan Jet Talk 8 Apr 08, 2008 08:08 PM
Whoops! Fritz X5 (Flying panzerfaust) stacker Electric Ducted Fan Jet Talk 9 Jun 06, 2006 10:21 AM
