No it doesnt have adjustable links, but it does have a swashplate and that has to be level. If the FS is bent thats another story, all things being equal, folding the blades back is how its done on the larger FBL heli's also. Good luck & your welcome
BTW if you tried to bend the blades, then you might have bent the FS.
I hear you & nothing wrong with being particular, particular gets you the best flying heli IME - its the perfect hobby for the obsessive
![]() If the swash is level visually, then maybe a turn on one of the 3 adjustable swash links might get you better. There are tools for this (FBL), a datum tool, and a digital bevel box. Unfortunanly they dont make them in the micro size or that will fit the mcp-x. I suppose the guy that designs a micro bevel box that wont weigh the blades down would probably sell a few, but in reality it isnt as critical of a measurement as it is on the larger heli's With the MCP-x and its ~120mm per blade length, the fold back method seems to work easiest for zero. Once you get zero, then you might be interested in this as a FBL pitch guage for the MCP-X; http://www.rcgroups.com/forums/showthread.php?t=1409275 |
United States, AL, Huntsville
Joined Jun 2011
Good info & actually very interesting though. I can't believe I got my degree in computer science with my aversion to math!
bent linkages can mess up tracking as they get shorter when they bend. it threw off my tracking until I replaced them
if it tracks well on low throttle but doesnt track with high throttle then it's the pitch (links are bent). if it doesnt track with low throttle then it's the feathering shaft |
| Thread Tools | |
| Question Blade tracking affecting blade pitch? | Torch8 | Beginner Training Area (Heli-Electric) | 5 | Jul 01, 2011 02:29 PM |
| Wanted WTB blade Blade MCPX | upperking | Aircraft - Electric - Helis (FS/W) | 2 | Apr 10, 2011 01:38 PM |
| Discussion exi 450 pro adjusting blade tracking | jpare315 | Mini Helis | 12 | Mar 31, 2011 02:48 PM |
| Discussion Blade tracking question / issue | RC_Marine | Electric Heli Talk | 2 | Mar 14, 2011 07:40 AM |
