Old Aug 02, 2011, 12:23 PM
tom66 is offline
Find More Posts by tom66
Basingstoke, UK
Joined Aug 2010
My LiPo just exploded
Okay I had a 3S Lipo which I over discharged and wrecked, so it was only useful as a 2S. That was useless to me as nothing I have runs 2S. So I, rather stupidly, peeled the label off with a knife to see if it was possible to replace a cell or to at least see how these things work. (Yeah - seems stupid now I think about it... we all do stupid things!! ) I did however think about the dangers and had a tub of salty water to dispose of it nearby in case it went bad as I heard salt water is good for making lipos inert.
And it did go up. Luckily I thought about the water. I must have punctured a cell because it basically burst and smoked everywhere, so I dumped it in the tub, and it seems dead now, but what do I do with it? Is it safe to dispose of? It's been in there for about 15 minutes.
tom66 is offline Find More Posts by tom66
Old Aug 02, 2011, 12:29 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Salt water disposal is a myth that just refuses to die.
LiPolys are safe to dispose of after being discharged to below 3volts per cell,the lower the better. Myself and many others use an auto tail light bulb to discharge them.
Charles
Old Aug 02, 2011, 12:34 PM
tom66 is offline
Basingstoke, UK
Joined Aug 2010
Charles
Yeah, so what do you do when the pack is simply on fire? I dumped it in my prepared tub and it stopped bubbling after about 30 seconds. Not sure if water is also an option but didn't want to take any chances. I wasn't trying to dispose of it, just trying to stop it exploding / burning.
Old Aug 02, 2011, 12:48 PM
Southern Pride
Dry sand is a better means to control a flaming LiPoly.
Next time use a plastic picnic type knife . Most likely you either punctured the cekll and cause a short or just shorted the contacts.
Charles
Old Aug 02, 2011, 12:50 PM
tom66 is offline
Basingstoke, UK
Joined Aug 2010
Charles
Didn't have any sand but would a tub of salt (with no water) be good enough?
Old Aug 02, 2011, 01:54 PM
tom66 is offline
Basingstoke, UK
Joined Aug 2010
Pack voltage now measures 0.14V. Two cells are completely dead; one measures 0.14V. So can I just chuck it?
Old Aug 02, 2011, 02:18 PM
vashon10 is online now
Find More Posts by vashon10
Renton, WA
Joined Nov 2006
The ref you heard about salt was associated most likely with soaking it for a long time for discharging, not extinguishing. Your result would have been the same with water alone. Sand is preferred as Charles mentioned.
vashon10 is online now Find More Posts by vashon10
Old Aug 02, 2011, 02:25 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Twist the leads together and dump it, yeah.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Aug 03, 2011, 12:15 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Hope you were doing this outside
lipoflyer is offline Find More Posts by lipoflyer
Old Aug 03, 2011, 01:46 AM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
Salt should be fine instead of sand too, it won't burn.
Though i don't see a reason not getting 100l sand.
Z
z-matrix is offline Find More Posts by z-matrix
Old Aug 03, 2011, 04:57 AM
tom66 is offline
Basingstoke, UK
Joined Aug 2010
Of course! On concrete too.
Old Aug 03, 2011, 05:47 AM
lipoflyer's Avatar
Australia
Joined Nov 2010
Z
Your not suggesting that salt should be used in place of sand are you?
Discussion Just fount out my Triton only charges up to 2.5a..and just got a 4000ma lipo.. Snow Bird PA-FL Batteries and Chargers 5 Jul 06, 2006 03:27 PM
lipo exploded talktodan Scratchbuilt Indoor and Micro Models 26 Feb 07, 2005 01:15 AM
Lipo exploded, still dangerous? Foamyfoam Batteries and Chargers 3 Oct 17, 2004 06:49 AM
The Big Delta AP just exploded Tom Harper Aerial Photography 16 Aug 09, 2004 07:46 PM
I just got my Orbit V6. it reads the volts just a tad high. Is it OK for lipo's? Heli Slime Batteries and Chargers 4 May 10, 2003 11:42 AM
