Old Oct 27, 2011, 01:26 PM
Taurus Flyer is online now
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Originally Posted by Lennuk View Post
Tail on the table and making beefier spars. Idea taken from the Jim Brandon website which seems to be taken down for now. Airfoil is going to be E205 on root and E193 on tips.
Armin,
Did you already start with the wingribs?
I do design and built gliders for many years and also with the Eppler airfoils, only, this was more than 35 years ago, these are hopelessly outdated!!!
Are you forced to use these? If not, can't you make a better choise?
I also see people still use Eppler 205 on their Sagitta for exampe, but there are nuch better choices now IMO, depending of location.
Are there other members that also think this way?
Cees
Taurus Flyer is online now Find More Posts by Taurus Flyer
Old Oct 31, 2011, 02:26 AM
Lennuk is offline
Find More Posts by Lennuk
Estonia
Joined Oct 2009
No I have not started ribs jet. What do you suggest for replacement? I choose these profiles because of the flat bottom, then I do not need the special table etc.
Also I doīnt know so much about different profiles and differences between them and mainly choose eppler because I found a build log (Jim Brandon) which is not available in the net anymore. He did use these profiles and then I thought Iīll go with same.
Armin
Lennuk is offline Find More Posts by Lennuk
Old Nov 22, 2011, 02:14 PM
Lennuk is offline
Estonia
Joined Oct 2009
progress
Hi
One wing spar completed, I did whole spar at the time, so the tip part is also assembled. Donīnt know if itīs better or not.
Now I started to prepare to roll my GE boom. Waxed, vaselined and taped the mandrel and cut the glass on template. I also will put CF tows on 4 sides, makes it stiffer. Letīs see what the first one turns out, maybe Iīll try to roll all carbon boom also.
armin
Old Nov 23, 2011, 02:27 AM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Is the designer the same as the Eclipse 180"? Also has V tail....Just started thread on thermal sailplanes. Found pdf plans on old timer plans thread.
1967250s is offline Find More Posts by 1967250s
Old Nov 23, 2011, 04:07 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
Lee Renaud of Airtronics fame designed the Esprit (84") the Grand Esprit (132") and Super Esprit (173"). I know the Grand and the Super are great flying sailplanes, I fly them.
Hal Cover is the Eclipse designer.
Joe
Edit: Add photos of the Esprit family.
Thermaler is offline Find More Posts by Thermaler
Old Nov 23, 2011, 06:06 PM
R2R is offline
R2R
Find More Posts by R2R
R2R
R2R's Avatar
United States, FL, St Johns
Joined Nov 2009
Glued the stab together. Put the halves on the drawing to get the right angle and some square scrap wood to support the thing and get it precisely perpendicular.
Armin
I like this method.
R2R is offline Find More Posts by R2R
Old Nov 26, 2011, 07:46 PM
hasselblad7 is offline
Find More Posts by hasselblad7
USA, CA, Roseville
Joined Aug 2006
Wingspan
I've got a Grand Esprit I'll get to building someday. The wingspan looks a bit proportionally over wide wingspan. Anyone have any feedback if it was built with a slightly shorter wingspan?
hasselblad7 is offline Find More Posts by hasselblad7
Old Nov 26, 2011, 08:03 PM
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
I can't offer anything about a shorter wingspan on the Grand Esprit, picture #2 below.
I can tell you about it's big sister the Super Esprit, pictures 3 and 4 below.
The span is 173" and the tail boom is 4 inches longer other than that it is a Grand Esprit. The inboard panels on the Super are about 48" and the out board are about 40". The root and tip chords arer the same on both.
The Super flies MUCH better than the Grand proving that bigger is better.
Joe
Old Nov 27, 2011, 12:23 AM
Captain Canardly is offline
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
I have aquired a short kit- with a C boom!
Captain Canardly is offline Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Nov 27, 2011, 02:31 AM
USA, CA, Roseville
Joined Aug 2006
Yeah, I got a kit a while ago but then found a carbon and fiberglass fuse! I'm not sure if I should be true to the design and build the wood fuse or the composite one. I just had an idea to maybe buy a Houston hawk wing kit and use it without the wing tips for an vintage and an updated version.
Old Nov 28, 2011, 02:22 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Without the wing tips!?!?
schrederman is offline Find More Posts by schrederman
Old Nov 30, 2011, 11:16 AM
ErcoupeEd is offline
Find More Posts by ErcoupeEd
ErcoupeEd's Avatar
United States, IN, Grabill
Joined May 2004
Enjoying this thread!
My GE build got interrupted do to working 13 to 14 hours a day, and taking care of my home on the weekends.
Hard to stay with it, so I come here to get inspiration.
I also have an older Legionaire 140 I am putting back into flight worthy shape.
It belonged to a friend of mine , Bob Steele ,who was once President of LSF.
Bob is now deceased, but I bought the Legionaire off another club member
who got it from Bob, but lost interest in it.
ErcoupeEd is offline Find More Posts by ErcoupeEd
Old Dec 12, 2011, 01:10 PM
Lennuk is offline
Estonia
Joined Oct 2009
Bones
Wing spars completed, turned out quite nice and identical.
Old Dec 20, 2011, 03:21 PM
Lennuk is offline
Estonia
Joined Oct 2009
Did second boom and I think this one I could use. It is one layer UD carbon between 3 layers of 200g/mē 45/45 glass. One layer is inside the carbon and two layers are outside. In the first third of the larger end there is 4th layer of glass. It weights 78 grams and is very rigid. If I am right the original kit boom weigthed about 110 grams but its all glass. So I think mine is at least as stiff as original. I might try to do one boom with leaving one layer of glass out, this one seems to be a little overkill with so many glass. I doīnt know, I have not seen the original boom in real.
Saved tail weight is the most precious though.
Armin
Old Dec 29, 2011, 02:36 AM
Lennuk is offline
Estonia
Joined Oct 2009
Yesterday I took third boom off the mandrel. This time I left one layer of glass out. So its one layer UD carbon between two layers of 200gr glass, on first third there is again the additional glass layer. Now itīs 66 grams and stiffness seems to be almost the same as last boom with three layers of glass and weight 78gr. I think this one is going to be the one I use. Almost half the weight of the original boom, nice.
Armin
Sold Airtronics Grand Esprit ronrange Aircraft - Sailplanes (FS/W) 6 Jul 25, 2011 12:09 PM
Discussion Grand Esprit jaizon Sailplane Talk 0 Jul 21, 2011 04:27 PM
Found Grand Esprit jaizon Aircraft - Sailplanes (FS/W) 3 Jul 20, 2011 10:45 AM
Discussion Grand Esprit Found brentrob Thermal 3 Jul 18, 2011 05:45 PM
Sold Airtronics Grand Esprit, 132" (11 ft.) glider Soarthumbs Aircraft - Sailplanes (FS/W) 3 Jul 12, 2011 11:56 PM
