Old Aug 01, 2011, 08:51 PM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
87" DynaFlite PT-19 Electric Conversion
I acquired my Dynaflite PT-19 a couple of weeks ago.
A friend gave it to me.
This old girl was kind of ruff, but I saw some potential.
I built a "Drawer" type motor mount for batteries.
If you can imagine an electric motor mounted to the front of drawer
that slides in and out.
I had a huge Hyperion Z5045-16 lying around for a long time.
I purchased a 20X10 APC e prop to try it out.
The plane was missing a cowl and wing fillets, so I had to make them.
In the last few days, I painted the fuselage, covered half the wing
and added the servos, and wired her up.
Pretty close to flying condition now, just waiting on my three
Gens Ace 4s 30c 5300mah for a total of 12s to show it in a few days.
If anyone else is interested in Big Electric conversions or PT-19's,
Please feel free to post here.
wingspan100 is offline Find More Posts by wingspan100
Old Aug 02, 2011, 10:16 AM
Zipman is offline
Find More Posts by Zipman
Zipman's Avatar
USA, NJ, East Brunswick
Joined Nov 2003
wingspan100,
That PT-19 is lookin good. Great job. Could you post some pictures of your "Drawer" motor mount for the batteries. Always looking for new ways to do things.
Zipman is offline Find More Posts by Zipman
Old Aug 02, 2011, 10:29 AM
Joined Nov 2007
Originally Posted by Zipman View Post
wingspan100,
Sure, In a few days I will have my batteries.
I will disassemble the front end to do the install.
I will post pictures of what I did.
Old Aug 03, 2011, 11:58 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Slide out battery tray and firewall:
http://www.tnjmodels.rchomepage.com/tnjwaco45.php
T&J Models 1/8 Waco YMF Battery Access (0 min 45 sec)
I am planning to do the same thing when I convert my 1/6 scale Sterling Stearman.
Great looking PT-19... I wish I had friends like yours
warhead_71 is offline Find More Posts by warhead_71
Old Aug 03, 2011, 12:27 PM
Joined Nov 2007
Yea, that's basically the idea.
Old Aug 04, 2011, 09:58 PM
Joined Nov 2007
Check out these pictures.
Pull two pins and the motor chassis slides out.
Old Aug 05, 2011, 12:50 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I have mostly Gens Ace batteries now. I charge with an iCharger 3010B. They have the cheaper 6S 1000W charger now. You could run balance extentions and charge them in the plane if you had a deep cycle marine battery to cart around. I do that with a combat plane and I can charge in 15 minutes or less.
Melnic is offline Find More Posts by Melnic
Old Aug 05, 2011, 12:57 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
So you have to remove the cowl to remove pins through the battery tray? I'm not sure how far the battery tray extends into the front cockpit, but you could even add an extension if you had to... then you could pull the pin(s) from the from cockpit and remove the tray with the cowl still mounted. Maybe the joystick itself could be the pin?
P.S. --- I see you have half the batteries in the "drawer" and the other half in the fuselage. It would simplify things if the drawer was deeper to accommodate all 4 batteries. Too late to re-engineer it?
Still, a beautiful plane and I like the drawer pull-out --- don't mean to criticize.
Old Aug 05, 2011, 01:29 PM
Joined Nov 2007
I heard that Gens Ace batteries were the way to go when it come to quality and price.
I like that! Charger extensions.
Does someone make them?
Old Aug 05, 2011, 01:38 PM
Joined Nov 2007
How did you know I'd have a problem?
You can tell the future? You should be a rich man.
After I took these pictures, I discovered the plane
was much too nose heavy.
Right now, I am redoing the battery tray to go in
deeper and further back into the fuselage.
I am also trying to figure a way to mount the cowl to the tray.
Before I was hoping to keep the batteries lower near the
bottom of the fuselage. Now that I am making a longer tray,
the batteries will sit higher in the fuselage.
Old Aug 05, 2011, 02:22 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Here is what I'm talking about. Make sure those don't get shorted or pinched. You'd need to get to the battery connectors as well. I"m assuming you'd parallel charge the batteries if they are identical.
Old Aug 05, 2011, 03:21 PM
Joined Nov 2007
Because the batteries are further in now,
I think I will have to slide out the battery tray
in order to recharge.
Old Aug 05, 2011, 05:11 PM
Joined Nov 2007
Ok, Latest update.
I moved the batteries further back but it was still way too nose heavy.
I took out the batteries and laid them on the belly to find the balance point.
It turns out that the best location for the batteries for balance is over the wing.
Go figure...
Old Aug 05, 2011, 08:04 PM
TBolt is offline
Find More Posts by TBolt
TBolt's Avatar
United States, AZ, Chandler
Joined May 2004
What do you mean you have friends?
Are you cheating on the fellas at the flying field?
BTW, Nice PT-19. let us know when she is going up.
TBolt is offline Find More Posts by TBolt
Old Aug 05, 2011, 08:22 PM
Joined Nov 2007
Don't be
I was hoping to fly it this weekend,,,,,
If I can finish it.
For Sale JU-87 Stuka Guillows Electric Conversion. Tuctronics Aircraft - Electric - Airplanes (FS/W) 2 Aug 04, 2011 01:44 PM
Discussion Anyone convert a Dynaflite or other large PT-19 to electric tlh101 Giant Electric Planes 0 Apr 26, 2010 07:03 PM
Wanted Dynaflite PT-19 rwcd Aircraft - Fuel - Airplanes (FS/W) 1 Jul 06, 2005 03:40 PM
Great Planes Pt-19 electric conversion Gizz_mo Electric Plane Talk 0 Jan 21, 2005 10:01 PM
