Old Sep 05, 2003, 03:44 PM
research_guy is offline
Find More Posts by research_guy
Believer...
research_guy's Avatar
Bean Town 0 years since last World Series Win!!!!!
Joined Jul 2002
Where's all the MOD INFO for Zero???
I know that a long time ago people had huge threads concerning the mods for the GWS Zero, but I can't seem to find them anywhere. If anyone knows the threads, i.e. battery placement, correct CG etc. then please let me know since my first will be here next week. Thanks.
RG
research_guy is offline Find More Posts by research_guy
Old Sep 10, 2003, 10:15 AM
Believer...
Joined Jul 2002
Anybody know of anything at all???
RG
Old Sep 10, 2003, 10:26 AM
JimmyTheG is offline
Find More Posts by JimmyTheG
Cincinnati, Ohio USA
Joined Jun 2003
Researc Guy,
I also have a ZERO and attempted to fly it with the setup that Gws Recommends. This was before reading the info on this site.
I learned real quick that the CG is very important. The first flight started with a very unstable aircraft and ended with a fuselage broken in two. I read that the CG should be moved forward 10 milimeters. I used foam safe CA to make the repair and moved the CG and it flew fine. The battery placement is how you adjust the CG. I had to move mine way forward.
Now I am using a 1600 mah LiPoly Battery all the way up front just over the motor. I get flight time of 20 min or so between chareges.
It is fun to fly but seems to be a bit under powered though.
Hope this helps as I don't know where the thread is your looking for.
JimmyTheG is offline Find More Posts by JimmyTheG
Old Sep 10, 2003, 10:31 AM
Believer...
Joined Jul 2002
Jimmy,
So, it's 10mm in front of the suggested in the manual? I heard that it was sometimes necessary to carve out some of the foam to move the batteries. Also, I'll be running the GWS 350C, not the 300. It seems like that will help some. If you remember the ezone thread that you found that might help. I just can't seem to find it doing a search. (In foamies, parkflyers, or GWS)
RG
Old Sep 15, 2003, 02:44 PM
Believer...
Joined Jul 2002
I'll bump this just once to see if anyone knows. Is there any more information that I NEED to know before I start building????
RG
Old Sep 15, 2003, 11:02 PM
propwash42 is offline
Find More Posts by propwash42
Ida, Michigan
Joined Sep 2003
Hi RG,
I just finished getting all the bugs ironed out of my Zero. The best info I got was to put a 1/8 in stick of balsa across the fuse at 1 in back from the very front of the wing opening. This causes the wing incidence to be slightly less positive and makes a world of difference in how the plane flys. You then glue the front wing mount in so the wing stays at that angle. The balance point with this set-up should be 60 mm back from the front of the wing. I am using a ETECH 1200 2s1p Li-Poly battery and with that pack installed as far as it will go foward in the battery area, I added 1/4 oz lead in the nose in the cut-out under the motor stick. The AUW for my Zero is 12 oz. I flew it before doing this mod with the CG at 1/4 in behind the bamboo spar, but I had to add almost 2 OZ of lead in the nose to get it to balance. It isn't much fun to fly that way. I fly mine without the landing gear since I think it is kinda weak and it looks better without it anyway IMO. Good luck on your Zero!
propwash42 is offline Find More Posts by propwash42
Old Sep 15, 2003, 11:28 PM
jbc455 is offline
Find More Posts by jbc455
jbc455's Avatar
San Jose, California
Joined Jan 2002
Mine balances right on the wing stick.
I have the nose cut out so I can slide an 8 cell 600 almost all the way to the cowl. I was able to carve it out the same way after building my father-in-law's Zero, but mine was done when I got it.
Flies perfect, super stable. I launch it underhand, no landing gear.
John
jbc455 is offline Find More Posts by jbc455
Old Sep 17, 2003, 09:19 AM
Believer...
Joined Jul 2002
So, the majority say to go without the LG huh? I thought it would be really cool to taxi around on the new artificial turf in the park up the street. I guess I'll install it for now and then I can take it off later if I need to. Thanks for all the great info and advice. I just started building last night...very cautiously building. I'm using foam safe CA so that should keep the weight down in the end. Thanks again.
RG
Discussion Where's All These So Called Free Heli Models for AeroFly Flight Sim? Crash-n-Hard Simulators 4 Jun 21, 2007 09:17 PM
Where's all the HS-5955TG servos? cadconversions Hitec/Multiplex USA 2 Jun 07, 2005 02:32 PM
Where's a good DS site for a beginner in Southern Cal? codezilla Dynamic Soaring 7 Apr 28, 2005 10:27 PM
Help! Where's all the little lipolys schoey Batteries and Chargers 2 Apr 22, 2004 05:08 AM
Where's All The Free Video Space? Shawn Davis Webhosting 1 Feb 22, 2004 03:39 AM
