Old Aug 01, 2011, 07:52 PM
RCICE is offline
Find More Posts by RCICE
RCICE's Avatar
Joined Oct 2010
brushless esc with a brushed motor?
now i am wondering if i can use brushless esc with a brushed motor because i can't find a brushed esc that is cheaper than a brushless one at hobbyking
RCICE is offline Find More Posts by RCICE
Old Aug 01, 2011, 08:28 PM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
A brushless ESC will not work with a brushed motor, it is a totally different type of ESC. GWS still sells a wide range of brushed ESC's, what amperage ESC were you looking for?
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old Aug 02, 2011, 04:27 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
HobbyKing isn't the only retailer in the world, (as many seem to think), who do good prices on cheap gear.
Try doing a search for a brushed ESC at the current you require. There are many local retailers out there still selling modelling stuff at good prices, until they get killed off by the 'I must buy from HobbyKing' mania.
eflightray is online now Find More Posts by eflightray
Old Aug 02, 2011, 09:11 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Ontario, Canada
Joined Apr 2010
GWS ICS brushed ESC's are fairly inexpensive. Less than $16:
http://www.allerc.com/advanced_searc...ws+ics&x=0&y=0
Note: if you are using Lipo's, choose the GWSESC480A:
http://www.allerc.com/gws-ics-480-li...ol-p-1787.html
philipa_240sx is offline Find More Posts by philipa_240sx
Old Aug 02, 2011, 10:26 AM
RCICE is offline
RCICE's Avatar
Joined Oct 2010
thanks for the reply i was just thinking because i heard some one talking about Castle Creations SCT Brushless System and that it could handle brushed motors with a simple wiring change so i had some hopes because i have some hobbyking esc's on the way
but anyhore i just found out that the motor i was going to use can only handle 3-4 flights be four it brakes (some crap that is sock in the plane) so maybe it is a better to put some money in a brushless system and save in the long rune. the system is a 370 bruset motor on a gear box so what system is good for a 38" wingspan and a 30" length foam traner (inrunner vs outrunner, prop, gearbox or not what kv) ?
Old Aug 02, 2011, 11:54 AM
Ontario, Canada
Joined Apr 2010
The CC Sidewinder SCT is a Car/Truck motor ESC and can be operated in both brushed/brushless mode. It CANNOT be used for airplane/heli motors.
In the model airplane world, ESC's are either brushed or brushless... not both.
so what system is good for a 38" wingspan and a 30" length foam traner (inrunner vs outrunner, prop, gearbox or not what kv?
What make/model of pane is it?
Do you know the weight with batteries?
How big of a prop will fit on the plane without touching the ground?
Can you modify the existing motor mount for brushless? Sometime these conversions are very tricky and should only be attempted by experienced modellers.
Old Aug 02, 2011, 12:47 PM
sh4nce is offline
Find More Posts by sh4nce
sh4nce's Avatar
BelgiŽ, Brussel, Brussel
Joined Nov 2010
Hobbyking has a range of brushled esc. If I remember well from 20A and up. Don't have a link but if you list all esc and sort by price that one is sonwewhere at the end.
sh4nce is offline Find More Posts by sh4nce
Old Aug 02, 2011, 12:51 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Here's one. 20A brushed for five bucks.... Cheaper than brushless.
Also, here's a 30A for $7.83.
Piece is offline Find More Posts by Piece
Old Aug 02, 2011, 01:03 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Plenty of brushed esc here, from 15 to 30 Amps:
http://www.bphobbies.com/view.asp?id=V573706
But the one TP16 linked are good too if part of a larger order to offset shipping cost!
coriolan is online now Find More Posts by coriolan
Old Aug 02, 2011, 01:24 PM
RCICE is offline
RCICE's Avatar
Joined Oct 2010
thanks right now i am looking towards the brushless option but it is good to know about the other one
so the plane is a cessna 745 from LANYU http://cgi.ebay.com/3-Ch-Radio-Contr...ht_3454wt_1185 the Flight weight is 500g i am thinking about getting this http://www.hobbyking.com/hobbyking/s...rop_Combo.html
Old Aug 02, 2011, 05:49 PM
coriolan's Avatar
Canada
Joined Sep 2006
Don't bid too high on it, its already overpriced as the Tx seems to be rather tatty with a range of 300 meters. If using a gear drive it can fly on that motor (380=Speed-400)
The motor/esc combo from HK is a lot more power:
Old Aug 02, 2011, 06:40 PM
Ontario, Canada
Joined Apr 2010
Here is the OP's plane, made by Lanyu Hobby:
http://www.lanyuhobby.com/viewProduct_en.asp?flowNo=297
IMHO, fly the plane the way it is.
These are fairly inexpensive planes and it's just not worth trying to mod them. Replacement parts are impossible to find, so if something does go wrong your only option is to buy another.
It's unfortunate really. This is why a recommend one of the more mainstream and popular planes like the Hobbyzone Supercub RTF. It's a basic 3 channel trainer, easy to learn on, easy to modify, and all of the parts are replaceable and readily available.
Good luck!
Old Aug 02, 2011, 07:29 PM
RCICE is offline
RCICE's Avatar
Joined Oct 2010
no i already haw the plane i got it 2 years ago and it broke before it flew
the one i haw had some weird 5 wire servos and the resever and esc was the same unit the motor is a 370 vs 380 in the new version and it i not lipo ready so i jus want to get this in the air as it would be my second plane (i am getting a little tired on my champ) alo i want to be able to use my DX6 whith it and lipo
Sold 24g Brushless Motors and Esc , Flight simulator , Servos, Brushed esc's and motors jkelley05 Non R/C Items (FS/W) 8 Jul 09, 2011 11:17 AM
For Sale 4200 kV Brushless motor with 50 MM Ducted fac, 20 Amp Brushless ESC and 850 mah LiPO ariasd Aircraft - Electric - Power Systems (FS/W) 5 Jul 05, 2011 09:50 AM
Sold zagi 5 5 amp brushed esc and micro brushed motor dr rc Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jul 01, 2011 06:04 PM
Sold Brushed motors + Brushed ESC ; Brushless Motor VK1601 Aircraft - Electric - Power Systems (FS/W) 2 Mar 15, 2011 12:02 AM
Discussion brushed motor, brushless ESC gwinhh Power Systems 8 Mar 13, 2011 04:24 PM
