Old Sep 05, 2003, 02:59 PM
KenP is offline
Find More Posts by KenP
St. Louis, MO
Joined Oct 2002
Reducing the voltage of a 3 cell Li-poly pack?
Has anyone tried to reduce the voltage of a 3 cell pack to be 9.6 volts instead of the 12.6 that a 3 cell 4.2 volt per cell would give. The reason I ask is that in some cases a two cell would not give me the performace I want as compared to 8 cell Kan pack. But a 3 cell pack would cause me to either have to prop down or gear the motor differently. So I was wondering if it was possible to restrict the voltage to keep the same prop and/or gearing but get the duration and weight benefits of li-polys.
KenP is offline Find More Posts by KenP
Old Sep 05, 2003, 03:46 PM
soren is offline
Find More Posts by soren
Senior Member
soren's Avatar
Denmark
Joined Sep 2000
Re: Reducing the voltage of a 3 cell Li-poly pack?
Hi
The only practically way to reduce the voltage is to use the speed controller - don't give full speed!
....i know that this not was what you were thinking about - but some kind of step down power supply that can handle 10, maybe 20 A is heawy, hot, and not easy to make....
Good luck
Soren
soren is offline Find More Posts by soren
Old Sep 05, 2003, 03:53 PM
KenP is offline
St. Louis, MO
Joined Oct 2002
Soren,
Thanks for the information.
I guess I always to restrict the throttle travel to do the same thing.
Thanks.
Old Sep 05, 2003, 04:34 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Yes. You can maybe use the throttle trim - set it to full throttle when you arm, then as soon as it is armed pull it back. That way you are unlikely to over voltage the motor accidentally.
3 Cell Li-Poly Batteries with GWS ESC and EDF "H-type" NightOwl GWS (Grand Wing Servo) 10 Oct 08, 2003 01:01 AM
8 cell nicad compared to 3 cell li-poly Megowcoupe Batteries and Chargers 1 Oct 07, 2003 03:56 PM
3 Cell Li-Poly Batteries with GWS ESCs NightOwl Power Systems 4 Sep 30, 2003 04:29 PM
Servo count with 3 cell li-poly KenP Castle Creations 1 Sep 15, 2003 06:45 PM
Slowstick w/ 3 cell li-poly 1200mah Kcampa Power Systems 3 Sep 13, 2003 07:03 PM
