Old Oct 21, 2001, 10:18 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Help!! Can someone please tell me how to hook up a twin in paralell?
I am building my first speed 400 twin and I need to know how to hook up the motors in paralell. Can anyone explain this to me? I would really appreciate it as I am a newbie in twins.
Thanks Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Oct 22, 2001, 12:08 AM
Brad Trent is offline
Find More Posts by Brad Trent
Brad Trent's Avatar
Canada, BC, Abbotsford
Joined Mar 1999
Joe:
You need to "Y" both the pos. and neg. output leads from the esc . Each motor will have a + and - lead to it from the controller, which must have a high enough amp rating to handle the sum of the 2 motors' amp draw. My 48" S400 twin draws 7A/side, for a total of 14A, and my Astro 217D handles this easily, since it's rated for 30A continuous. You'll find that twins seem to perform a little better than 2X a single motors output might suggest, and have a nice "cool factor" as well.
Brad.
Brad Trent is offline Find More Posts by Brad Trent
Old Oct 22, 2001, 01:02 AM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
speed 400 twin
Thanks Brad, I think I understand now. Each motor gets hooked to the ESC that has two Y's of wire running from it. So the ,otors see all the voltage. I also have a 217D new in package that I will use for this plane.
Thanks Again Joe
Old Oct 22, 2001, 02:56 AM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
question... I've never built a twin, but since it's a twin speed 400, wouldn't it be better to get a left-hand and right-hand prop and hook one of the 400's contacts up backwards? seems like it would help to keep the plane from getting squirrely when you punch the throttle...
opualuan is offline Find More Posts by opualuan
Old Oct 22, 2001, 07:19 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
If you can find matching props then counter-rotating motors is a perfectly good idea. But in reality the torque reaction from a pair of 400s is not severe, and pusher props are only made in a few sizes (so you'd be lucky to find the one you want).
Bill Glover is online now Find More Posts by Bill Glover
Old Oct 22, 2001, 12:49 PM
opualuan is offline
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
ok... I don't think this is necessarily about a twinjet, just a twin... could be any plane with twin speed 400's, so it might be tractor props...
I agree with you about supply of props... I'm still looking unsuccessfully for a pusher prop for one of my scratchbuilts (4.5x3 was optimal I think), with NO luck.
Old Oct 22, 2001, 06:37 PM
Joined Nov 2000
Sorry, I obviously didn't explain that very well! If you want the motors going in opposite directions so the torque cancels out then one needs to be fitted with a tractor prop and the other a pusher prop (regardless of whether the plane has the motors in pusher or tractor configuration). Both props need to be the same diameter and pitch, but made for opposite rotation
An electric pusher doesn't normally need a pusher prop - you just run the motor in reverse (re-timing if necessary) and use a normal prop.
Can any one tell me how to make a homemade gas powered jet turbine jet engine? Zupo Fuel Jet Talk 44 May 11, 2008 03:10 PM
Can anyone please tell me the weight of an Apogee 1050 cell wildstallion Micro Helis 1 Sep 24, 2004 09:53 AM
Can someone please tell me how jdd44 Beginner Training Area (Aircraft-Electric) 5 Mar 22, 2004 08:07 PM
Someone please tell me about these NMH Batterries... KZZ Batteries and Chargers 2 May 16, 2003 08:12 PM
