Old Aug 01, 2011, 04:23 AM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
intermittent retracts on hobby lobby/freewing super hornet..how do i fix them?
like the title says my nose gear has become intermittent. i messed with the servo travel adjustment the other night(bumped it up to 110%) and ran it for a couple of minutes on the ground and had it working fine..then went to fly today and it was intermittent again. when i fiddled with it the other night, at one point the nose gear would cylce at low power or idle but not when the engine was running flat out..very weird. when i tried to set the travel adjustment at 125%, this caused the nose gear to stop mid cycle.like i said. it seems strange that i had it working flawlessly set at 110% travel, then today after having made no changes its back to its old tricks. as far as i know they are eflite retracts and are worm driven...any help would really be appreciated
jb0005 is offline Find More Posts by jb0005
Old Aug 01, 2011, 04:51 AM
benjo is offline
Find More Posts by benjo
Pointy end at the front.
benjo's Avatar
Joined Aug 2009
This happened to me once and i ended up changing the unit.
benjo is offline Find More Posts by benjo
Old Aug 01, 2011, 06:13 AM
jb0005 is offline
jb0005's Avatar
Joined Jan 2011
the front one is a real pain to change out and i was hoping it might be something that could be adjusted out
Old Aug 01, 2011, 10:52 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
If it's stock plane RTF or ARF then the retracts should be freewing, unless u already changed em out. Have you tried opening up the unit yet? Give that a try, clean the gear n add a lil silicon grease n put back together. Make sure not to over tighten the screws on the case or it'll bind. If nothing else... I say change it out. It might be a pain but it's more of a pain to keep dealing with it.
v8truckin is online now Find More Posts by v8truckin
Help! How do I fix a cracked wing on an Apogee Elite? hoverfiend Hand Launch 15 Sep 09, 2011 04:38 PM
Discussion How do you keep them water tight? Robert12 Dock Talk 15 Jul 08, 2011 03:53 AM
Video keychain cam on tail of Hobby Lobby (Freewing) F-16 habitforming Electric Plane Talk 11 Oct 10, 2010 05:58 PM
Build Log 78" Super Tiger Moth Electric all the way , Hobby Lobby has them. Joe Pierson Scale ARF/RTF 1 Aug 30, 2009 01:39 PM
Cracked Nacells on Twin Jet--How do you fix them??? TopGun Foamies (Kits) 5 Jul 11, 2001 05:11 PM
