Old Jul 31, 2011, 04:43 AM
Menno is offline
Find More Posts by Menno
Joined Nov 2005
Help!
Yaw gyro KK board not responding
Hi,
I hope this is not a repost, but the search function didn't solve my problem .
I have received my KK 5.5 Blackboard and installed it on my Tricopter frame. Somehow the yaw gyro seems to be unresponsive.
Pitch and roll work just fine and it tries to stabilise the tricopter like it should.
The tailservo responds normally to yaw inputs that are given by the transmitter. Also when I put the tailservo on motorpins 1, 2 or 3 it instantly tries to compensate for movement.
I am lost here. Can this be a defective yaw gyro on the board. Is there any other way to check this. Or am I missing something simple (I hope )
Firmwares tried:
- Tricopter (V1.6 [m168] kapteinkuk (mirrored by lazyzero.de)
- Tricopter (V2.0 [m168] kkmulticopter.kr)
On V2.0 I also tried the pins on motor 5 (reverse), but it makes no difference
Maybe I should just put on an extra GY401 .
Regards,
Menno
Menno is offline Find More Posts by Menno
Old Jul 31, 2011, 04:59 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
my search function turns up this thread
Hope it helps....
Mike Barton is offline Find More Posts by Mike Barton
Old Jul 31, 2011, 05:55 AM
Menno is offline
Joined Nov 2005
Hi Mike,
Thanks for the response. I actually did see that post, but I missed the fact that he had manual control over the tail servo, just like me.
Hmm, seems like I have a simular problem.
And I hoped i would finally get some airtime this weekend .
I am not sure which points I should measure on the board with my mulitmeter to check??
Old Jul 31, 2011, 06:09 AM
United Kingdom
Joined Nov 2008
OK - the Yaw gyro is the vertical board at the back.
The 3 connections at the base are (left to right): Supply (~5V) : Gyro Out (~1.35V) : Ground
So you just need to measure the Gyro Supply and Output voltages relative to the Ground connection.
Old Jul 31, 2011, 06:20 AM
mikehawkey is offline
Find More Posts by mikehawkey
Joined Mar 2011
Yaw gyro
Hi Mike,
I'm not sure either but I will take a look at the soldering on the board. Can sympathise with your frustration as I have had so many conflicting solutions but hey I will crack it at some stage. I'll let you know how I get on when I ref lash my board.
mikehawkey is offline Find More Posts by mikehawkey
Old Jul 31, 2011, 06:52 AM
Menno is offline
Joined Nov 2005
I am measuring ~4 volt on the left connection and ~1.4 volt on the middle one
Old Jul 31, 2011, 08:44 AM
Joined Mar 2011
Just measured mine and have about 4.6 and 1.7 on the same connectors. Not sure whats that telling me about the problem though other than I am getting roughly the right voltage at those pins.
Old Jul 31, 2011, 08:48 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
The middle one should change as you rotate the board around.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jul 31, 2011, 09:22 AM
United Kingdom
Joined Nov 2008
the gyro voltage appears fine.
the 4V seems a bit low (should be at least 4.7v)
What is the voltage across R4 (should be ~90mV) ?
the 1.7V output is way too high (assuming standard murata gyros)
What is the voltage (Aref) on pin 20 of the ATmega (should be ~1.64V) ?
What are the voltages for the other gyros ?
As an example, my KK blackboard gives 4.78V and 1.53V (<=high, so I have changed R10) respectively
Old Aug 05, 2011, 02:47 PM
Menno is offline
Joined Nov 2005
Thanks everybody for the responses. I've returned the defective board to the seller and he has send me a new one. The gyros on the new board work like they should.
I guess this thread can be closed.
Old Nov 26, 2013, 09:58 AM
fmata is offline
Find More Posts by fmata
fmata's Avatar
United States, IL, Forest View
Joined Dec 2005
I have a board that broke off wanted to run some wires to the end points..
Would you know where Yaw Gyro Out would go?
Name: Yaw Breakout Board Schematic.jpg
Description:
Name: Design Schematics for the v.5.5 SMD PCB.jpg
Description:
Name: kk 5 5 board.jpg
Description:
fmata is offline Find More Posts by fmata
Discussion KK board as camera-gimbal stabilisation gyro? ed.ge Multirotor Talk 16 Jul 25, 2015 12:54 PM
Mini-HowTo How to fit the new type HK401 gyro sensor to a KK board. kapteinkuk Multirotor Talk 18 Apr 06, 2012 07:12 AM
Question kk blackboard yaw gyro not working!? Help needed. rash Multirotor Talk 13 Oct 28, 2011 06:48 AM
Discussion 2 Gyros on board + 1 Gyro standalone (KK inside)? iacei Multirotor Talk 4 Aug 12, 2011 04:25 AM
Wanted STABLE Quad control board (not kk,gaui or fy90q) RChelisrule FPV Equipment (FS/W) 5 Mar 28, 2011 04:41 PM
