Old Aug 23, 2011, 03:14 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
It is SOOOOOO nice to see someone in this forum
who is NOT interested in doing 200 mph !!!
I may take your Ribs and DO UP a Ribbed version.
birdofplay is online now Find More Posts by birdofplay
Old Aug 23, 2011, 03:23 PM
miniphase is online now
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
Thanks Bob, I'll be glassing over foam cores along with some some carbon for this one. Hopefully that will keep the dreaded flutter at bay.
miniphase is online now Find More Posts by miniphase
Old Aug 23, 2011, 03:52 PM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Sigh... I wish I had building skills. And flying skills.
This would be a really cool platform.
sawman is offline Find More Posts by sawman
Old Aug 23, 2011, 03:56 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I just tossed together somethign from your provided pix.
Assuming 3.2M span.
Sheeezzz that is one THIN foil section ! ! ! I get ~ .78"
or most likely about 20mm thick
Old Aug 23, 2011, 10:40 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Man that's a thin, skinny, center section. With that much sweep you're going to have a lot of torsion to absorb. Be ware of flutter and build stiff not just strong!
--Norm
nmasters is online now Find More Posts by nmasters
Old Aug 23, 2011, 11:14 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Edwinzea and Norm:
yeah these foils looked WAY thin to me.
( might as well make a foamy ;-}
It's looks kinda DLG like to me.
But a Thermal-able Wing was the Criteria and calc's were made so ...
I'm just asking you guys to look again and see if it still makes sense at this thickness.
Bob
I took miniphase's top view drawing , scaled to 3.2 meters
Took cords and scaled the rib drawings to the derived chord .
Then placed them in position with the tapering washout still intact.
I then made surfaces at each section using the curve from the TE
by sweeping it along the two rib curves.
all in all only a few minutes of CAd time :-)
Bob
Old Aug 23, 2011, 11:38 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Quite likely take some exotic construction to build that with enough stiffness and yet maintain a low enough wingloading for thermaling.
DT56 is offline Find More Posts by DT56
Old Aug 24, 2011, 05:12 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
well I will try to reply in order
@ Paul, the airfoil should thicken from root to tip not otherwise as you wrote. Check the ZIP I added on this thread with the composite construction, you will need some cap spars to keep the wing without flutter. and you can always edit the title of the thread :P
@Bob, the airfoils are thin in % but counting with the chords there are about 2cm think enough for good servos. Furthermore, the thinner airfoil produce enough lift for the task at low speeds and reduces the drag, which is already increased by the washout, so is a matter of compensation. if You want I have a 2m design that I can provide you. the ribbed version will need extra care on the spars to avoid flutter
@Norm, I thoght of making a three piece wing, in that way the center can be properly reinforced to absorb the torsion
Regards
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Aug 24, 2011, 05:15 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Not really you need the right material in the right place
EZ
Old Aug 24, 2011, 05:37 AM
miniphase's Avatar
Joined Nov 2004
Regards
I think you may have misunderstood my earlier post, we're describing the same thing but coming at it from different directions.
The tip is nearest to the original thickness of the HS520, so the section gets thinner from the tip to the root, not thicker from root to tip...sorry to be a pedant
I think with a carbon d-box and spar cappings she'll be stiff enough. I was thinking of buying 50mm carbon tape (at 200gsm) rather than cloth. I won't get the benefit of a bias weave, but it'll be easier to handle than cutting strips of cloth.
On another note of concern, will the thinned root section have undesirable stall characteristics?
Old Aug 24, 2011, 06:14 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
mmm good question, but in fact I followed the design principles from the Zupair wing and it seems to work nicely on their videos also seems to work very well on XFLR5, the thinner airfoils have a slightly better glide ratio and less drag though. Again this design is orientated to thermal flying, and I thought that even a slight increase was a bonus that also goes for the Lift, but we will only know when it is in the air :P
Regards
Edwin
Old Aug 24, 2011, 06:59 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
You can always build this one http://www.zanonia.de/yoda.php
EZ
Old Aug 24, 2011, 10:47 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Hey, those are some nice thermal machines.
Gotta get out my translator
Old Aug 24, 2011, 03:57 PM
DT56 is offline
Joined Aug 2005
Originally Posted by eflightray View Post
What about the Hump ?, the plan is still available - http://www.myhobbystore.co.uk/product/15966/sf423--hump
Or the Redwing?
http://www.glide.net.au/on-the-wing4...Redwing-3A.pdf
Cool Cool little full-house 2m thermal ship from Holland DrFragnasty Composites Fabrication 0 Apr 23, 2011 04:56 AM
Question 2M vs Bigger, is it really that hard to thermal a 2M or smaller? Pauliwog Thermal 75 Dec 13, 2010 07:35 AM
Wanted Any Polyhedral Thermal Wing 3.1-3.5m jrbackus Aircraft - Sailplanes (FS/W) 3 May 17, 2010 10:28 AM
Sold Gabby 3.2M 3 Piece Wing - Like New (Well... Almost) acampfield Aircraft - Sailplanes (FS/W) 5 Jun 07, 2008 12:12 PM
Discussion airbrakes or crow brakes for 2m powered thermal wing Robbie d Flying Wings 2 Mar 04, 2008 05:36 AM
