Old Jul 30, 2011, 01:42 PM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
3.2m thermal 'wing
Time for another 'wing!
I'm planning for this to be just over 3.2m span and will use it off the flat as a power assisted thermal ship.
The plan is driven by what I can cut from readily available foam panels without waste. As it happens, the layout is almost exactly the same as a 2.4m 'wing I built a few years ago.
This new model will be bagged foam, probably with a carbon 'd' box for rigidity. The 2.4m wing had no spar and flutters easily. I'd like this new version to be a lot stiffer so that maybe I can make a slope pod with ballast tube and/or winch launch it.
I've attached my initial sketch and hope some of the usual suspects will chip in. I'm going to use the HS 522, as it seems to come up trumps for several studies Edwinzea has done.
First question...
Is there any benefit from a 3 stage washout like the later CO 'wings? I will need to cut each semi span in three sections anyway. so hope someone can inform me as to whether it will be worth steeping the twist rather than doing linear washout.
I look forward to hearing from you all!
miniphase is offline Find More Posts by miniphase
Old Jul 30, 2011, 01:58 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Yes. The washout produces a dead spot on the wing that produces no lift but plenty of drag. Thus 'wings do have parasite drag even though they don't have all those nasty non-wing parts. Non-linear washout reduces the size of this dead spot and moves it toward the tip where it adds to the directional stability.
--Norm
nmasters is offline Find More Posts by nmasters
Old Jul 30, 2011, 02:02 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Nice! But why so small? Just kidding! I'll definitely be watching this thread.
Brian
cpdude is offline Find More Posts by cpdude
Old Jul 30, 2011, 02:06 PM
miniphase's Avatar
Joined Nov 2004
--Norm
next question....how do I calculate it Norm?
I was planning on 2 degrees linear root to tip, how would I go about translating this to a non linear twist?
Old Jul 30, 2011, 02:45 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
You could just guess but I think I have his article on my hard drive. I have people expecting me to act like a responsible grownup for a few hours so it'll be a while before I can look for it. latter
Old Jul 30, 2011, 03:08 PM
miniphase's Avatar
Joined Nov 2004
No problems Norm.
I won't be cutting the cores for a few days yet, enjoy your stint of responsibility....I prefer to give such duties a wide berth!
Old Jul 30, 2011, 03:55 PM
miniphase's Avatar
Joined Nov 2004
Brian
I hope to get it thermalling high enough to make it look very small Brian
Old Jul 30, 2011, 06:00 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Perty. But I'm all thumbs when it comes to foam. Doesn't anyone make a good size thermal FW out of balsa?
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jul 30, 2011, 06:23 PM
cpdude is offline
Joined Jan 2004
@Fly Wheel - Yes! Well, I guess that depends on what you mean by "good size" Anyway, Take a look at some of my posts. You can decided.
Brian
Old Jul 31, 2011, 01:07 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
@fly wheel and CPdude. Well not quite balsa. But the liteply is pretty lite, and much stronger. You can actually use little spring clamps on the ribs without crushing them.
@ miniphase, looks good, i'd put a nice little bat tail on there but i'm just partial to them
Robbie d is offline Find More Posts by Robbie d
Old Jul 31, 2011, 01:40 AM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
The article I was thinking of was Jochen Haas' piece describing his design procedure for highly tapered 'wings with BSLD and no vertical fins. Obviously that's not what you need for this project but others watching may find it to be for them.
So I looked elsewhere and found two references to segmented washout on Hans-Jurgen Unverferth's 'wings. Twist Distributions for Swept Wings, Part 1 mentions washout in three segments:
Zero twist on the first 1/3 of the half span
then 1/3 of the total washout on the second 1/3 of the half span
then 2/3 of the twist in the last third of the half span.
But as far as I can tell both the CO2 and the CO5 had a two segment washout schedule: no twist on the inboard half and all the washout on the outboard half.
--Norm
P.S. There's an article about the winglets that Burt Rutan designed for the LongEZ that you should see.
Old Jul 31, 2011, 02:22 AM
miniphase's Avatar
Joined Nov 2004
Thanks Norm
The CO8 used the 1/3rd step, the Zanonia site shows this in a bit more detail http://www.zanonia-flyers.de/
So my intuition tells me that if I have no twist for the first 1/3rd of half span, then I'll need a bit more on the outboard 1/3rd
Hopefully Edwin will chip in, he stepped the washout on his last swept 'wing
Old Jul 31, 2011, 03:47 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Here's one for inspiration!
http://www.rc-network.de/forum/showt...%28-Kr%E4he%29
The text isn't English, but lots of photos.
DT56 is offline Find More Posts by DT56
Old Aug 02, 2011, 01:13 PM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Hey Paul
I stop visiting the FW forum for three days and you come with something new already :P I also planning on starting my 3m project this week :P if everthing goes right.
I tested the non linear washout in XFLR5 and it gives better glide ration and less induced and viscose drag, as norm has already pointed. I also teste it on my A.J.R.V. and it works pretty well.
I can calculate the wash outs for you(shame on you, you did not asked me ) :P please give me more details on the profiles, to make a good XFLR5 model. do you want to use the same thickness allong the wing??
Are you making a three piece wing??
good luck
EZ
PS. I should read the whole thread before postin, shouldn't I??
Edwinzea is offline Find More Posts by Edwinzea
Old Aug 03, 2011, 01:44 AM
miniphase's Avatar
Joined Nov 2004
Hi Edwin
HS 522, constant thickness.....I'm thinking two piece wing purely because I don't enjoy messing around with joiners, but I'll se how I feel as the build progresses.
I've now got some time away from work so foam cutting will begin shortly!
Cool Cool little full-house 2m thermal ship from Holland DrFragnasty Composites Fabrication 0 Apr 23, 2011 04:56 AM
Question 2M vs Bigger, is it really that hard to thermal a 2M or smaller? Pauliwog Thermal 75 Dec 13, 2010 07:35 AM
Wanted Any Polyhedral Thermal Wing 3.1-3.5m jrbackus Aircraft - Sailplanes (FS/W) 3 May 17, 2010 10:28 AM
Sold Gabby 3.2M 3 Piece Wing - Like New (Well... Almost) acampfield Aircraft - Sailplanes (FS/W) 5 Jun 07, 2008 12:12 PM
Discussion airbrakes or crow brakes for 2m powered thermal wing Robbie d Flying Wings 2 Mar 04, 2008 05:36 AM
