Very nice Maiden! Looks very happy on the ST 400 motors.
McD |
Latest blog entry: LEDs on my T-28
Ok, I subscribed to this thread and read all the posts. Now, if the rimfires are so expensive, which some say are a tad underpowered, there are no rimfires that are bigger that will fit from what I have been able to see on the TH website, then what are the best alternatives to them?? I don't want to do a lot of modification to the motor mounts, other than taking out the blind nuts and putting in more blind nuts in the mount.
Any suggestions, Thanks in advance. Conehead Orrin Eldred |
Latest blog entry: Pictures of Toledo
No matter what, you'll have to drill new holes. The Rimfire400 has a triangular bolt pattern that is not compatible with anything else. Your biggest limitation with new motors will be the motor length... I don't think there's much space between the firewall and the cowl to go with a longer motor ("maybe" you could go to 35mm), but you can step up in diameter a little.
So, with that in mind, it looks like the Rimfire400 is 28mm diameter X 30mm long (2830) and 950KV with a 3mm shaft. You could move up to the Rimfire.10 which is the same length but 35mm diameter (3530) and 1250kv with a 4mm shaft. (This is approximately a 480-size motor). Just a few cheap options: http://www.headsuprc.com/servlet/the...h-11%29/Detail http://www.hobbyking.com/hobbyking/s...ner_Motor.html http://www.hobbyking.com/hobbyking/s...ner_Motor.html http://www.rctimer.com/index.php?gOo...wt&goodsid=142 |
I get mine from Don http://www.strongrcmotors.com/Motors.htm
Mine's still flying fine with the RimFire motors.
McD |
These guys make an aluminum adapter that will give the same mounting pattern as the rimfire cross mount.
http://www.smallpartscnc.com/ I'm planning on using Hacker A20-22L's, which are about 3mm longer in the length measurement than the 30mm that the Rimfire motor drawing shows. The Hackers only cost about $5 more than the Rimfires. I'm sure there are cheaper motors also per the links posted above. I received my Hackers today and found that they had changed the design since I last bought one. As a result the distance from the back of the motor to the face of the prop adapter is now about 38.5mm vs. the 30mm of the rimfire. I'm sure the motors would still work but from a looks standpoint might stick out more than I care for. Kit is due in on Wednesday, so I'll have to see what it all looks like. I can always use the Hackers somewhere else if needs be. |
Ok, you all have convinced me. I must say I have never had any trouble with the rimfires I own.
I went with a larger rimfire on the Seawind, It really screams in my mind. Thanks everyone, I appreciate it. Conehead Orrin Eldred |
United States, AZ, Gilbert
Joined May 2005
The alternative motor that Im using: http://www3.towerhobbies.com/cgi-bin...&I=LXXGY2&P=ML
Mounts just like the rimfires with no modification. |
United States, NE, Grand Island
Joined Dec 2009
I bought this plane at a auction last month. It looked like it had never been flown and was in perfect shape with stock Rimfires. Had the Futaba servos and came with a battery all for $145.
I wanted to fly it off land first before I tried the the water take off. I removed the water rudder and tip floats. I had a good study 15 MPH wind and held the plane above my head and full power made it want to pitch down so moved my hand forward and tried full power again and with the little up trim I added to the elevator it flew stright out and away. Needed very little triming and at full power loops were as big as you would want. Tried some power off stalls and it held in there....but if you forced it...it would wing over. Not a big deal for the wing area and weight. After five minutes I brought it in against the steady wind with a full stall landing in the grass. I am happy with it. The floats are back on and next summer we are ready. |
| Thread Tools | |
| Sold Brand New Electrifly PolyCharge 4 port charger | HD Hucker | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Jul 20, 2011 11:15 PM |
| Sold Berg 6*G III ch 44 and 52 and Revolution antennae $25 | fpainter3 | Aircraft - General - Radio Equipment (FS/W) | 5 | Sep 29, 2009 07:15 PM |
| Yippee! Maiden flight G P ElectriFly F4U-1A Corsair | wolfpack72 | Electric Warbirds | 33 | Nov 04, 2006 10:05 PM |
| Anyone tried Expert or G.P. Electrifly recievers? | Billy Haynes | Power Systems | 4 | Apr 15, 2002 02:03 AM |
