Joined Dec 2007
http://www.seaplanes.org/mambo/index...k=view&id=1159
Current issue of WaterFlying has an article about this plane getting your Multi Engine Rating... |
Madison, WI
Joined Feb 2004
Waterproofing Wing and Control Surfaces
If you really want to waterproof all of this plane I'd think about stripping off all covering on the wing (and control surfaces if covered) and apply sanding sealer, dope or water based polyurethane. If the plane were accidentally flipped upside down in water you could just about guarantee the wings would fill up with some water. I know it would be a real pain to recover and or paint. One could even finish it with dope and paint and it would be as close to waterproof as it would ever get.
I have to admit, GP got the outline of the Widgeon pretty darn close to scale. I believe I viewed the full size version of this plane at EAA Airventure. Before I purchase I'll wait to hear Thayer's final thoughts. |
United States, CT
Joined Aug 2003
Fast Freddy, if you like what you see I would definitely place an order sooner rather than later, especially if you live in the northern half of the country. It would be a shame to miss out on the first wave and be forced to wait until spring to fly it.
Thomas, I guess it all depends on what you mean by the head of the servo. Yes, the entire output arm is exposed, and yes you can see the top of the servo case, but only right around the arm and not the entire case. This is not the typical deal where the servo mounting lugs and screws are on the outside of the model. Instead a plywood shim is glued to the inside of the plywood hatch plate and the servo is reverse-mounted on the inside of that. The exposed part of the servo case protrudes less than 1/32 of an inch from the wing surface. You are going to have to squint pretty hard to see that in flight. The manual is on line and the aileron servo mounting instructions with illustrations are on page 8. Mounting the servo on its side and having just the arm exposed will make it a lot more difficult to waterproof the wing in that area. Trust me, they did it right. Of course that doesn't mean you aren't allowed to spend an extra hour or three trying to improve it. Were I really troubled by the current install I would simply paint the exposed parts of the servo cases and pushrods white and move on. By all means going over the model to confirm that the covering is good is an important step, and the first one in the manual. I have seen issues there on other models as well and flying from the water is definitely a hostile environment. You will want the covering to stay on. Sounds like you have the power system all sorted out. I agree that an attentive and skilled modeler can always improve a mass-produced ARF. I am known to be rather picky as well and yet found very little to snipe about with this model. It is very well designed and the sample I was provided was also built very well. I obviously can't judge what number 1,000 will look like based on what I have seen but I would expect it to be similar to mine. I wish you all the best and hope it is everything you can reasonably expect. The more of these they sell the more likely we are to see additional similar subjects. Thayer |
| Thread Tools | |
| Sold Brand New Electrifly PolyCharge 4 port charger | HD Hucker | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Jul 20, 2011 11:15 PM |
| Sold Berg 6*G III ch 44 and 52 and Revolution antennae $25 | fpainter3 | Aircraft - General - Radio Equipment (FS/W) | 5 | Sep 29, 2009 07:15 PM |
| Yippee! Maiden flight G P ElectriFly F4U-1A Corsair | wolfpack72 | Electric Warbirds | 33 | Nov 04, 2006 10:05 PM |
| Anyone tried Expert or G.P. Electrifly recievers? | Billy Haynes | Power Systems | 4 | Apr 15, 2002 02:03 AM |
