Old Aug 03, 2011, 11:10 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Doubtful unless you store the model in water.
Yeah, as long as you don't tie it you your dock and leave it you'll be fine.
Also, remember to clean all weeds and grasses off the plane before transporting it I don't know about other places, but around here there's a big fine if you get caught moving a boat that has Eurasian milfoil (an invasive aquatic plant) on it.
I wonder how that affects (full-scale) planes that take off and land on water? Is the pilot supposed to hang out of the cockpit with a rag on a stick and wipe down his floats before he lands?
Piece is offline Find More Posts by Piece
Old Aug 03, 2011, 11:53 PM
JSS4 is offline
Find More Posts by JSS4
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
HAHA I'd love to see that.
I doubt anyone has a dock small enough to tie this plane to anyways.
JSS4 is offline Find More Posts by JSS4
Old Aug 04, 2011, 12:04 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Oh, you'd be surprised
Old Aug 04, 2011, 12:07 AM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
I probably shouldn't say this, but it's late and I may not be thinking clearly.
OK, I had my fun...need to remove the non-family-friendly bits.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Aug 04, 2011, 12:26 AM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
Originally Posted by Dave Eichstedt View Post
I probably shouldn't say this...
Edit: Looking forward to the A5
Bajora is offline Find More Posts by Bajora
Old Aug 04, 2011, 07:52 AM
mrodgers is offline
Find More Posts by mrodgers
United States, PA, Butler
Joined Jun 2006
Nobody wants to be accused of having a small dock...
Is float planes like the pickup trucks out in the parking lot here at work? The size of the float plane would be inversely proportionate to the size of the dock?
mrodgers is offline Find More Posts by mrodgers
Old Aug 04, 2011, 03:14 PM
AeroRecon is offline
Find More Posts by AeroRecon
Work....fly, repeat...
AeroRecon's Avatar
Fredericksburg, Virginia
Joined Jul 2008
Originally Posted by pdansalvish View Post
There is one disappointment for me with this plane. Matt from HH stated there is no plastic bottom on the plane. Eventually, the foam will get water soaked and most likely not last long. I recommend coating the bottom with epoxy or something.
For other floatplanes, I add strips of that flexy kitchen cutting board stuff so I can fly off asphalt. Or those cheapy paper binders from Walmart. Real thin plastic, very flexible. Just cut to fit, spray 3M77 on both parts and wait a few minutes. Then push together and hold for a while. Makes the bottoms super slick and durable against the pavement. When I wear a hole, I just do it again.
With this thing having wheels, it won't be an issue, though. Jus sayin....
AeroRecon is offline Find More Posts by AeroRecon
Old Aug 04, 2011, 10:33 PM
mrodgers is offline
Joined Jun 2006
First, foam will absorb some water. It will dry out fast though. It should not deteriorate the foam, but will absorb and hold some water.
I extrude, expand, and mold EPP for work. If water deteriorated foam, we would not be able to mold it. It is molded with high pressure steam and the parts cooled with water. Water won't hurt molded beads foam one bit. The beads aren't glued together with an adhesive or anything, they are heated and melted together. Water isn't going to de-melt plastic last I knew (just made that word up, de-melt....)
Now if only I can talk my boss into building a couple of airframe molds for our presses......
Old Aug 04, 2011, 11:08 PM
Conehead is online now
Find More Posts by Conehead
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
If you are worried about the foam, why can't you glass the bottom?? It would add just a little weight, but you would have hard bottom.
Looks great. I love float planes. Guess that is because it is just 50 feet from the back door to the float flying dock. Yep, I got my own float flying dock. Right now I am fly a Super Cub on floats. I have had this plane for over a year and I had two flights this evening.
Conehead
Orrin Eldred
Conehead is online now Find More Posts by Conehead
Old Aug 05, 2011, 10:23 AM
AeroRecon's Avatar
Joined Jul 2008
3 words.... New Revenue Stream
You can be in charge of R&D and testing.
Old Aug 05, 2011, 06:24 PM
bfaulguy is offline
Find More Posts by bfaulguy
United States, NJ
Joined Apr 2001
You can easily glass the bottom, I did with my Z-foam Seawind. Used very light glass cloth, and Minwax water based polycrylic. Painted it with water based acrylics mixed to correct color, then another coat of WBPC on top. Works fantastic, adds very little weight, but lots of strength. You'll want to do this if you fly the plane off snow, since if it hits patches of ice the foam WILL tear and look nasty.
bfaulguy is offline Find More Posts by bfaulguy
Old Aug 06, 2011, 08:21 AM
Flutter-Bys are fun
Conehead's Avatar
Joined Dec 2005
This plane looks great, my problem is that it is coming out in Late October. The lakes freeze about early December and with all launches they are usually about 2 to 5 weeks late. So October becomes December, ice, snow abound here then and I wanted to see it fly off water, not snow.
I know it could fly off snow and all float planes do a great job on snow, but for the first flights I would have rather had water.
Oh well, Horizon has their time table, the fellows down South will have a great time.
Conehead
Orrin Eldred
Old Aug 06, 2011, 07:31 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Somewhere in the annals of the Interwebs, there's a video of someone driving an R/C boat on snow. Good stuff.
It WOULD make sense to release it in time for the northern markets, but I suppose Horizon knows what they're doing.
Old Aug 06, 2011, 08:09 PM
Flutter-Bys are fun
Conehead's Avatar
Joined Dec 2005
KMP has one also. It is much bigger, has retracts on it, 71 inch wing span, 5 and 1/2 pounds, can be gas or electric. I would love it, but too much money.
I will go with this one, learn how to fiberglass the bottom, everyone says it is easy, so even a dummy like me can learn to do it.
I like the design, that along with the Super Cub, my Seawind, and another float plane will be a great addition. 4 float planes, I got a short float plane dock and 4 chase boats. MasterCraft, Pro Star 190, A Larson 14 fit. ski boat, and a 14 ft, Duck Boat and a paddle boat. So I am set, one plane for each boat.
I wish they had brought it out in April, but I can get it, be ready for the spring and fly off the lake during the winter. Flying off snow is a hoot with a float plane.
Conehead
Orrin Eldred
Old Aug 06, 2011, 08:16 PM
Flutter-Bys are fun
Conehead's Avatar
Joined Dec 2005
Why does everyone have to BLAST the music on every factory video?? Please, it comes on, about deafens me and I have to go to the mute switch or turn the volume down on every video from every manufacturer.
Give our ears a break, LOUDER is NOT BETTER. I worked in a factor for 30 years, what hearing I got left, I want to keep till I die!!
Conehead
Orrin Eldred
Discussion ParkZone Icon A5 BNF or PNP ElIntocable Waterplanes 4663 Jan 28, 2016 05:50 PM
Discussion New Parkzone Icon A5 friz Electric Plane Talk 66 Apr 09, 2013 05:05 AM
Discussion ICON A5 by Parkzone Kinnerhatz Waterplanes 1 Jul 28, 2011 11:57 PM
Discussion HobbyKing Icon-A5 for FPV? djdavid60 FPV Talk 7 Jul 13, 2011 04:20 PM
Sold A488 ICON A5 70" wingspan, EPO, retracts,flaps $75 LPU baddb1 Aircraft - Electric - Airplanes (FS/W) 1 Mar 27, 2011 09:26 PM
