Old Sep 11, 2012, 07:12 AM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Did you loosen the prop nut and ensure the collet (item C in picture) was pulled back? The whole assembly needs to be loose in order to slip on.
If it still wont go on then you need to spread the "fingers" so it can slip onto to motor shaft.
_OZ_ is offline Find More Posts by _OZ_
Old Sep 11, 2012, 09:21 AM
Same is offline
Find More Posts by Same
Perth, WA
Joined Jul 2006
Just the shaft on it's own, tried to spread it with a flat head screw driver didn't work.
Just want to know if the Extra 300s shaft is the same, otherwise I'll have to order one from another state no biggy just have to wait longer compared to being able to go buy the Extra 300 shaft from my LHS.
Same is offline Find More Posts by Same
Old Sep 11, 2012, 10:12 AM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
I think it is too short.
Wedge a small screw driver between the fingers to spread them.
Old Sep 11, 2012, 11:23 PM
Same is offline
Perth, WA
Joined Jul 2006
I have a mini hobby blow torch, should I try heat it up so it expands? Thanks for the advice
Old Sep 12, 2012, 06:22 AM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
no.
Old Sep 22, 2012, 12:01 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
On the prop do the numbers face the front?
rcrich is offline Find More Posts by rcrich
Old Sep 22, 2012, 12:19 PM
danrc is offline
Find More Posts by danrc
danrc's Avatar
Rockford Illinois
Yes
danrc is offline Find More Posts by danrc
Old Sep 23, 2012, 03:21 AM
Same is offline
Perth, WA
Joined Jul 2006
no.
Fixed it! I put it in a vice, stuck a flat head screw driver in each gap and banged it with a hammer.
Had a great flight today, but the rudder servo got wet once again so I've had to take it apart and leave it to dry.
Old Sep 29, 2012, 05:11 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
first flight
icon a5 parkzone seaplane rc (6 min 27 sec)
Old Nov 13, 2012, 04:05 AM
michaelpowell is offline
Find More Posts by michaelpowell
Joined Sep 2010
Loose Tail
Been out of touch with this thread for a while, so forgive me if this is old news...I tried a few flights off grass, but the tail boom snaps very easily unless the grass is very smooth on landing.
I've added some 3mm diameter carbon tubes on each side of the boom. I've not noticed any tail wobble since. And the tail remains in place!!
That canopy is so heavy that removing it allows a lot of equipment to be carried. I put in a full FPV set, including its own battery, and two Sony Bloggies on the sponsons. Seemed more than happy, and flew 15 minutes on a 3S LIPO 2100.
There is a space for two such drive batteries, and again, there was no problem with flying that, although the power level needs to be quite high, and its noisy.
I wanted to ask is about glitching on elevator. Has anyone noticed the elevator twitch downwards briefly in flight?
This has been a regular occurance for mine, but because its brief, I've been trying to identify the spot in the sky where it happens, since it seems to be consistent, but over a featureless area of remote hilltop. No other fliers, no cellphone masts, not even any vehicles or people. Just a sheep or two. Odd.
Next to look for internal errors. I'm using a simple 35MHz receiver sitting an inch or so from the speed controller. Its not necessary, there is room, but it doesnt normally give me problems, and its Multiplex, which is rock solid. It happens without any FPV equipment on board, by the way.
michaelpowell is offline Find More Posts by michaelpowell
Old Nov 14, 2012, 01:37 PM
a320jockey is offline
Find More Posts by a320jockey
a320jockey's Avatar
Ecuador, Pichincha, Quito
Joined Aug 2002
There seems to be no replacement servos available at HH now. Which servos would be equivalent to these?
Carlos
a320jockey is offline Find More Posts by a320jockey
Old Nov 14, 2012, 01:44 PM
AeroRecon is offline
Find More Posts by AeroRecon
Work....fly, repeat...
AeroRecon's Avatar
Fredericksburg, Virginia
Joined Jul 2008
Splashdown!
The video came out funny because of the YouTube stabilizing....it sorta 'breathes' in places. Not sure I like it.
Anyway, was tooling around trying to keep it close for my GoPro headcam and pulled a little too tight and it spun in. Still drying everything out. Enjoy!
Icon A5 Radio Control Scale Model Splash (1 min 16 sec)
AeroRecon is offline Find More Posts by AeroRecon
Old Nov 14, 2012, 03:37 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Cool vid. It looked like a bird going for a fish at the end
Old Dec 10, 2012, 09:14 PM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
Icon A5 maiden
Flying with Gaby. (LOTS OF MAIDENS). (5 min 19 sec)
carlocivicsi is offline Find More Posts by carlocivicsi
Old Dec 12, 2012, 02:39 PM
thinman is offline
Find More Posts by thinman
Joined Dec 2008
Has anyone set up the Icon in the flaperon configuration so the ailerons could be used as flaps also? Wouldn't this possibly make for slower landings?
Bob
thinman is offline Find More Posts by thinman
Discussion ParkZone Icon A5 BNF or PNP ElIntocable Waterplanes 5122 Jun 22, 2016 03:53 PM
Discussion New Parkzone Icon A5 friz Electric Plane Talk 66 Apr 09, 2013 04:05 AM
Discussion ICON A5 by Parkzone Kinnerhatz Waterplanes 1 Jul 28, 2011 10:57 PM
Discussion HobbyKing Icon-A5 for FPV? djdavid60 FPV Talk 7 Jul 13, 2011 03:20 PM
Sold A488 ICON A5 70" wingspan, EPO, retracts,flaps $75 LPU baddb1 Aircraft - Electric - Airplanes (FS/W) 1 Mar 27, 2011 08:26 PM
