Joined Jun 2003
20 amps & 250 watts out from 12-13.8 volt in, Version 2?
I love the software FMA/Cellpro has in my Multi4. I believe it is similar in the PowerLab 8. The way it measures chemical activity in the battery, at least I think it must, and responds is terrific and makes for great safety! While the user interface in the 10XP isn't quite as nice it's close enough so that it is safe and perhaps easier to use. (See Tim Marks' Comments about the interface in post 48 and post 50.) However, I use either 2 12v 7Ah field batteries in parallel, my car battery, or (at home and the club) a 13.8v power supply. I chose not to lug around a large power supply because it's a pain. (I realize I can re-wire the Great Planes electric caddy to put the field batteries in series for 24v.) Is there a reasonable chance of a version 2 of the 10XP which will put out 20 amps at 250 watts with 12v - 13.8v in? Table of charger cababilities for LiPo charging. |----------------------------------------------------------------------| | No. | Charger | Charge | Power | Charger | @ 3C Charge Rate | | LiPo | watts out | Voltage | Amps | Max Amps | Max Batt Capacity | | Cells | @ 12v in | n x 4.7v | | | | |----------------------------------------------------------------------| | 2 | 234 | 9.4 | 24.8 | 15.0 | 5.0 Ah | | 3 | 234 | 14.1 | 16.5 | 15.0 | 5.0 Ah | | 4 | 234 | 18.8 | 12.4 | 12.4 | 4.1 Ah | | 5 | 234 | 23.5 | 10.0 | 10.0 | 3.3 Ah | | 6 | 234 | 28.2 | 8.3 | 8.3 | 2.8 Ah | |----------------------------------------------------------------------| | 2 | 250 | 9.4 | 24.8 | 20.0 | 8.8 Ah | | 3 | 250 | 14.1 | 17.7 | 17.7 | 5.9 Ah | | 4 | 250 | 18.8 | 13.3 | 13.3 | 4.4 Ah | | 5 | 250 | 23.5 | 10.6 | 10.6 | 3.5 Ah | | 6 | 250 | 28.2 | 8.9 | 8.9 | 3.0 Ah | |----------------------------------------------------------------------| | 2 | 500 | 9.4 | 53.2 | 30.0 | 10.0 Ah | | 3 | 500 | 14.1 | 35.5 | 30.0 | 10.0 Ah | | 4 | 500 | 18.8 | 26.6 | 26.6 | 8.9 Ah | | 5 | 500 | 23.5 | 21.3 | 21.3 | 7.1 Ah | | 6 | 500 | 28.2 | 17.7 | 17.7 | 5.9 Ah | |----------------------------------------------------------------------| - Jim |
Sorry, the CP10XP is capped at 15A. There will not be a 20A v2 model offered. Thanks, Tim Marks |
http://www.parkzone.com/Products/Def...ProdID=PKZ1032 The plane is the Parkzone J-3 BL edition. The stock charger is the only way that I can get this to charge. I have tried my Detrum DC6 and my FMA 10XP charger and I get an error on both. The XP says that there is a Low Tot V which I am assuming is due to the fact that it doesn't see one of the cells? Not sure. I will post the error later if necessary. |
If I can't find another method I will consider modifying my charge adapter for this purpose but I am leery about changing my board at this time. I may just buy a different battery for this bird. |
This selection is used to charge 2S Lipo's in unbalanced mode. Connect the battery discharge leads to the charger. The balance leads are not used. Glen |
United States, IN
Joined Aug 2003
Should boost sales too! I really like the 4S Gold unit I have, especially the simplicity & ease of use. But those features seem to fade in favor of the higher amps & multi pack features in your higher end units. Right now, if I were to get another of your chargers, I'd favor another 4S Gold, a Multi, or maybe a 10S, but it's really a bit confusing which to choose. A Product Selector Guide on your web site would help a bunch in choosing!!! |
Duly noted. Thanks for your comments. Tim Marks |
Are you using the Revolectrix adapters? If so, make sure you have the unit in FMA WIRING MODE. Check p 22 of the user guide here: http://revolectrix.fmadirect.com/sup.../item_1375.pdf Some customers inadvertently put the charger in XH WIRING MODE which can produce this safety code. Tim Marks |
| Thread Tools | |
| Discussion FMA Cellpro 10XP Charger | alexf1852 | Batteries and Chargers | 73 | Jan 01, 2013 10:40 PM |
| New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron | Ward Hagaman | Slope | 174 | Nov 16, 2012 08:40 AM |
| Sold Cellpro 4s Lipo & A123 Charger | apex | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Jul 02, 2011 09:49 PM |
| Found all around charger wanted / trade for Cellpro 4S +++ | jazzster | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Mar 21, 2008 05:55 PM |
| New Product Introducing the all new Brushless Sensorless Motor Controllers for cars and boats | jackson_f | Product Announcements | 3 | Jan 12, 2007 03:13 AM |
