Thanks for the reply. Is it necessary to do it using the CCS or is that optional? If it is a requirement, can it be done only thru the CCS or it is available in the Options menu. I was hoping I can get away with buying the charger-to-PC interface for now. Thanks again. Rico. Edit: Just found the 10XP manual from FMA. Looks like changing a preset is also possible thru the built-in options/mode menu... but I need to read more to ensure. Still would appreciate if you can add any comment. Thanks. |
Seattle
Joined Sep 2007
Correct. The 10XP includes presets for both dual and single pack charging. The dual pack presets include "dual" in the title. I highly recommend the PC connection. FMA is good about supplying user requested features in firmware updates. The pc connection is required to update the firmware. Plus, management of the presets and other charger settings is quite a but easier with the CCS. |
Joined Jul 2008
Your comment has me asking another question. The Power Supply? I have a 13.8 VDC, 28A (max) output power supply from Revolectrix. With this power supply the 10S maximum output is 225 watts and the 10XP is 269 watts. What power supply does one use to get the maximum 605 watts from the new XP? Is there a better way to charge 4X - 6S 3300 or larger 5000 mAh packs at the same time? Thanks |
Seattle
Joined Sep 2007
My question is about both the 10S and the 10XP. And if it was worth upgrading to the new XP for my charging needs.
Thanks for clarifying. The XP is capped at 15 amps vs the original Cellpro10s at 10 amps. Charging two 6s 3300 packs that would be a charge rate of just over 2c vs 1.5c for the Cellpro10s. What power supply does one use to get the maximum 605 watts from the new XP? Review this chart from post 52 in this thread. For 6s packs, the maximum output is 378 watts. Next look at the power chart from the 10XP manual. To achieve 378 watts, you'll need a power supply approximately 18v and 25 amps. Server supplies in series are a good way inexpensively get 24v and more amps than you would need. ![]() Is there a better way to charge 4X - 6S 3300 or larger 5000 mAh packs at the same time? For a charging scenario where the user would like to charge up to 4x 6s packs at a time, the Cellpro10XP may not be the best selection. See post 52 for more commentary on the subject. http://www.rcgroups.com/forums/showp...8&postcount=52 A high wattage dual port charger capable of charging at least 2 6s packs at a time would better suit my needs and it sounds like yours as well. |
OK guys, all the Cellpro 10XP's have shipped and are on their way! Thank you for your orders!
For the guys that want node only charging with the 10XP, it takes a little mod to the adapter board. Keep in mind, if you choose to perform this mod, you no longer have the over current protection from the charger, like you did with the Cellpro 10S. You will be responsible for setting the current limit, not to exceed 4 amps. The way the mod works is the adapter is wired one way for 2S - 5S packs and another way for 6S (not that too many people will be charging node only for 6S but I added it just in case). If you have a pack connected to the adapter board, the banana plugs will be hot and could short out it touched together. Always make sure the banana jacks are connected to the charger before you connect your pack to the adapter. Please let me know if you have any questions, thanks. |
Error with charging
Hey everyone,
I just received my Cellpro 10 XP but I am having trouble getting my batteries to charge with the new XP. I'm almost sure there is something that it is something I am doing wrong but I don't know what. When I try to charge my 6s 5000mah Zippy, I get Ch2. Bad S. Count, ERROR XH NODE. Ok, so do I have to have another adapter? Whenever I connect one of my 3s Sky LiPos and try to charge I get: Ch1. Bad S. Count, ERROR XH NODE. Ok, so what gives here? Here are some pics from my bench: Picasa web Explanation of pics: 1. Screenshot of my settings 2. Attempt at charging 3s Sky 4400mah on 1st preset 3. Error immediately after hitting start on charger 4. Error immediately after hitting start while attempting to charger 6s Zippy on preset 2 5. Attempt at charging 6s Zippy 5000mah I opened a case with support on the FMA site but I am hoping that someone can clue me in before the weekend is over. I would like to use my product! Thanks, Justin UPDATE: by Unplugging channel 2 I was able to get it to charge one of the sky lipo batteries. Now it won't charge anything again. |
When you use a FMA/Revolectrix adapter as you are, then you do not put the 10XP into XH MODE. I think that is your problem. Please put the charger back into the factory default FMA WIRING MODE, and it should start working for you. The FMA adapters convert the XH wiring to FMA wiring. That is their purpose. Let me know how you make out. Tim Marks |
| Thread Tools | |
| Discussion FMA Cellpro 10XP Charger | alexf1852 | Batteries and Chargers | 73 | Jan 01, 2013 10:40 PM |
| New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron | Ward Hagaman | Slope | 174 | Nov 16, 2012 08:40 AM |
| Sold Cellpro 4s Lipo & A123 Charger | apex | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Jul 02, 2011 09:49 PM |
| Found all around charger wanted / trade for Cellpro 4S +++ | jazzster | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Mar 21, 2008 05:55 PM |
| New Product Introducing the all new Brushless Sensorless Motor Controllers for cars and boats | jackson_f | Product Announcements | 3 | Jan 12, 2007 03:13 AM |
