Old Jul 31, 2011, 09:10 AM
BMW318TI is offline
Find More Posts by BMW318TI
The Netherlands
Joined Jul 2010
Yup I have also the PL8, but the CP 10S is a great charger for my 1S lipo's
I am just using the PL8 for the big boys
BMW318TI is offline Find More Posts by BMW318TI
Old Jul 31, 2011, 04:40 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Not exactly. When I charge my 1s packs (which are 200-300mah) I always charge at least 2 in parallel for this reason:
Originally Posted by Howard Matos View Post
This adapter will not work with the Cellpro 4S or 10S chargers. Although those chargers are designed to charge single cells, the smallest capacity cells you may safely charge are 350 mAh.
Gregor99 is offline Find More Posts by Gregor99
Old Jul 31, 2011, 05:11 PM
BMW318TI is offline
The Netherlands
Joined Jul 2010
OMG I thought I 've made a good choice (CP 10S) for my ordered 1S 160 mAh lipo's. So I can't charge two 1S 160 mAH lipo at CH1 and CH2 at the same time?
Old Jul 31, 2011, 05:46 PM
Gregor99 is offline
Seattle
Joined Sep 2007
You can, but it will not finish off the charge properly as the CV stage will terminate prematurely. What this means is the cells will not be fully charged, which is arguably not nessessarily a bad thing for cell life.
Old Aug 01, 2011, 01:58 AM
BMW318TI is offline
The Netherlands
Joined Jul 2010
What kind of adapter you are taking about?
Okay thanks for your explanation!
I switched from Hyperion (real) dual charger to CP10S charger.
So that was bad choice?
Old Aug 01, 2011, 08:55 AM
Gregor99 is offline
Seattle
Joined Sep 2007
See this thread for the adapter the 1s adapter discussion
http://www.rcgroups.com/forums/showt...4#post16626538
Old Aug 01, 2011, 09:09 AM
BMW318TI is offline
The Netherlands
Joined Jul 2010
OMG!!!
Now I feel very sad!
I have ordered those Hyperion adapters.
So I can throw them in a corner? (useless?).
But the I will charge my ordered Hyperion 1S lipo's at 500 mAh.
So that will be a solution? To eliminate this problem?
I am really confused now, I can select 0,1A as charge current with CP 10S.
So it should be possible?
Old Aug 01, 2011, 11:16 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
So that the Hyperion adapter the 1S 6 parallel one here
http://www.rcgroups.com/forums/showp...47&postcount=2
and a FMA CP10 pigtail also shown in that post. Connect (solder) the red lead from the pigtail to the red lead on the Hyperion adapter and the black lead from the FMA pigtail to the Hyperion black lead.
Now you can charge up to 6 1S Lipolys at a time. If you charge 6ea. 160 mAh then that is the same as charging a single 960 mAh one so a 1A charge rate would be 1C.
Just make sure that all of the LiPolys have been discharged (flown) the same amout so the voltages are close. A couple of tenths of a volt ( 0.02)difference is fine but do not place discharged and fully charged ones in the adapter at the same time.
Charles
Old Aug 01, 2011, 12:13 PM
BMW318TI is offline
The Netherlands
Joined Jul 2010
Okay thanks for your information.
But it doesn't work on my CP 10S when I just use the 4mm banana leads connected to charger channels?
Because it's only 1S battery, so no balancer leads are needed.
Old Aug 01, 2011, 12:27 PM
Southern Pride
First off Cell Pro 10 will not charge any LiPoly without using the balancing leads.
Secondly this is the new Cell Pro 10 XP thread and this charger requires both the main charging leads and the balancing leads be connected to charge LiPolys.
The directions I provided will work with this charger.
If you have the older Cell Pro 10 charger then my directions will work with it also.
If you have the older Cell Pro 10 then you can use the FMA pigtail solder them to the Hyperion adapter red and black leads connect the FMA pigtail to the CP10 balancing port ,install the Plug Blocker ,cover the male bullets on the Hyperion adapter to prevent shorts and charge thru the balancing leads only.
Old Aug 01, 2011, 01:08 PM
BMW318TI is offline
The Netherlands
Joined Jul 2010
Okay thanks for your information!
I will modify the Hyperion adapters to make it work.
Yup I have the older CP 10S.
Maybe I will also buy the Multi Pro, because my PL8 doesn't have quick start feature
Old Aug 01, 2011, 07:07 PM
Southern Pride
If you use the CCS and go to Option Start Settings and Check Enable Quick Start and Suppress Use bananas it is only two presses of the Start Button.
Old Aug 02, 2011, 04:41 AM
BMW318TI is offline
The Netherlands
Joined Jul 2010
Aaha I didn't know that, because I don't use the CCS often.
Thanks!
Old Aug 03, 2011, 11:37 AM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
Questions Re: 2 of Gregor99's Posts Above
Originally Posted by Gregor99 View Post
[...]But I feel the specs could result in some customer sat issues when they discover that very few common charging configurations will come close to the 645 watt rating. I would much rather seen either increasing the output current to 20 amps, or increasing the cell count to 12 and keeping a lower current rating. This charger will be best suited for modelers using 4s, 5s, 8s or 10s. Modelers with 3s, 6s, and 12s would do much better to stick to the Powerlab8.
Gregor99:
What is the problem with 3s, 6s ... batteries and the 10XP?
[...]As for no perfect charger, the inventible iComparison to one particually similarly priced charger may produce unhappy customers that thought they were getting almost twice the wattage. But it turns out they ended up with even less usable wattage than the other charger.[...]
Please provide specifics about the wattage, I don't understand.
TIA
- Jim
JimHSoars is offline Find More Posts by JimHSoars
Old Aug 03, 2011, 02:33 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
Absolutely nothing. He's saying that for him to be happy with a charger he needs to be able to use a pack or series of packs that is nearly equal to the maximum cell count supported by the charger, which then allows utilization of as much of the available power as possible.
If the 10XP were to support 12S then he'd be able to combine 3S, 6S, and 12S packs in ways to use the full 12S support. But since it is limited to 10S he feels a 6S pack is too much under-utilization (60%) so you should get the PL8 since then you'd be using 6S of 8S or 75% utilization of available power.
I don't agree with that assessment, but everyone is entitled to their opinion. The same logic applied to maximum current capabilities would say that if you have smaller capacity packs you should get the 10XP since charging at 15A on the PL8 would be a waste of its potential.
SteveM732 is offline Find More Posts by SteveM732
Discussion FMA Cellpro 10XP Charger alexf1852 Batteries and Chargers 78 Feb 11, 2016 10:59 PM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 180 Oct 04, 2014 09:43 AM
Sold Cellpro 4s Lipo & A123 Charger apex Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 02, 2011 09:49 PM
Found all around charger wanted / trade for Cellpro 4S +++ jazzster Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 21, 2008 05:55 PM
New Product Introducing the all new Brushless Sensorless Motor Controllers for cars and boats jackson_f Product Announcements 3 Jan 12, 2007 03:13 AM
