Old Dec 31, 2012, 05:03 PM
fly2bob is offline
Find More Posts by fly2bob
fly2bob's Avatar
United States, CA, San Diego
Joined Nov 2005
Ok so putting my Neu 4300 5s 25/50c
Using a FMA CellPro 10s w/ v2.24 firmware. Fan kicked on for a second when powered up and the screen said, “safe to connect charging w/ accurate charge”, chose chg. @ 1c
Once started charging, scrolling though, screen said, “1 pack charge lipo set @ 1c”, scrolling again, said, “Ch 1 lipo fast C”.
starting fuel gauge=47% / pack voltage=19.68v (for 5s)
starting v per cell
1) 3.914v
2) 3.914v
3) 3.914v
4) 3.914v
5) 3.914v
starting IR per cell
1) -- m & omega symbol
2) --
3) -- m & omega symbol
4) --
5) -- m & omega symbol
I assume on the screen that cells 2 & 4 probably don’t have the ‘m & omega symbol’ next to them because there isn’t room for them on the right of the numbers.
After about 24 min.’s all the V for the cells were still identical to each other but the IR readings were as follows;
1) 10.8 m & omega symbol
2) 11.4
3) 12.9 m & omega symbol
4) 12.7
5) 12.5 m & omega symbol
It took about 2 hours to charge at 1c to get to 99% according to the ‘fuel gauge’.
All 5 cells are at 4.204v, total 21.022v, 2,074mah back in.
But the IR are as follows;
1) 9.5
2) 9.0
3) 9.6
4) 9.6
5) 8.7
So w/ IR #’s that high, I guess the battery is toast, right? And will following any advise from the my lipo is dead thread help in a case like this?
Thanks, Bob
fly2bob is offline Find More Posts by fly2bob
Old Dec 31, 2012, 10:12 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
I answered in your other thread. But, yes those IR values indicate a true C rating closer to 12c. When shopping for new packs, you might find this chart interesting.
http://www.rcgroups.com/forums/showp...&postcount=163
Gregor99 is offline Find More Posts by Gregor99
Old Dec 31, 2012, 10:34 PM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
What I get from the chart is that there doesn't seem to be much difference between lipos labeled w/ a 25c rating and a 60c rating, except zippys and such. Too bad, I bought a 5s 5000 40c lipo to replace this one (the Neu 5s 4300 pk). Although I'm not going to be drawing 180 amps from it. My sys only pulls 90-100 amps. So 5 (A) * 40 (c) = 200. Even if it's less than that, say 30c, I should be ok to pull what I will be pulling on it. I just have to break it in and do some 1 minute motor runs to be able to calculate the proper run time and calculate the amount of mah's it takes to fully recharge it so I can then calculate how much run time I will have to not go below 80% depletion, and not fly til the LVC kicks in. Say do you have any idea when using a motocalc program such as;
http://www.brantuas.com/ezcalc/dma1.asp
if the 'full throttle duation' in min.'s takes into account the 80% rule, or is that until the pack is fully depleted?
Bob
Old Jan 01, 2013, 12:09 AM
Gregor99 is offline
Seattle
Joined Sep 2007
That is only the 25c Gens ACE. Check out the Revolectrix packs which are very price competitively priced against the other packs on that list.
I looked at that program and while it looks interesting, I suspect that many of the values would need to be estimated or guessed. I would rather get some real world test data from the model.
Old Jan 01, 2013, 01:31 AM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
In my post #273 I forgot to write that the 5s 5000 40c pk I bought was a Zippy.
When you say you looked at the program, I assume you are talking about the Diversity Model Aircraft motocalc program
Since my motor (a Neu 1510.5/1Y which has a 3250kv) isn't on the list, I used the Neu 1512/1.5D which has a kv of 3200. I figured it was close enough. Then I input the 6.7 gb, 16x10 folding prop, 5s 4300 lipo, C.C. 125 esc, which yielded 95 amps, and 2:43 full throttle run time. Again, do you think that is run time is til the pk is empty or do you think they take the 80% rule in account? I would think the former.
Old Jan 01, 2013, 11:52 AM
Gregor99 is offline
Seattle
Joined Sep 2007
No idea, you'd have to contact the author to find out. If it was done correctly it would have used 80% or better yet provide a variable amount as some modelers prefer to use discharge to either higher or lower numbers.
Old Jan 08, 2013, 11:39 AM
needknees is offline
Find More Posts by needknees
Joined Oct 2012
Can anyone give me the size specs for the fan inside the 10XP case? Mine has been crapping out for quite some time (actually started ~2mo after purchasing the charger) and now rarely works even under a heavy load. Seems like the bushing went out.
Is this something I can relatively easily replace myself or should the charger be sent back into FMA? Thanks
needknees is offline Find More Posts by needknees
Old Jan 08, 2013, 02:45 PM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
If it's under warranty-send it back, if not DIY depending on how handy you are at such things. If it's not under warranty, you could open it up to measure it. Then you could see if the fan plugs in a board or is soldered. If soldered you could just clip the wires (but mark them first) and take the fan out yourself (since it doesn't work anyway) and take it to a place that sells such fans and match one up. If it's not in the manual I doubt the average person would know the spec's on the fan. Maybe it's best to call FMA and ask them if you feel you need to know before going to look for one.
Old Jan 08, 2013, 06:17 PM
DonA is online now
Find More Posts by DonA
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
The fan on the 10XP is easily replaced, 4 bolts hold it to the top panel, 4 screws hold the top panel in place. The fan plugs into the main circuit board. Just make sure you route the wires like they were originally to keep the fan power wires from hitting the fan.
Don
DonA is online now Find More Posts by DonA
Old Jan 09, 2013, 06:08 AM
cmoulder is offline
Find More Posts by cmoulder
Pullin' G's Man
cmoulder's Avatar
Ossining, NY
Joined Dec 2005
Use this.
Excellent fan, of which I have installed 3 or 4. The stock ones in the charger are crap. If you send it in for warranty they'll probably replace it with the same crap fan.
Bob
cmoulder is offline Find More Posts by cmoulder
Old Jan 21, 2013, 05:35 PM
Mechcondrid is offline
Find More Posts by Mechcondrid
Techno-geek of DOOM!!
Mechcondrid's Avatar
United States, CT, Ledyard
Joined Nov 2010
hey guys just got myself a cellpro 10xp after my trusty accucell 6 finally crapped oout after close to 6 years of horrid abuse and use, and i must say it is rather nice if not a bit of a curve to learn to use but anyway i just noticed today that the lcd has a couple line that seem to be faded compared to the rest of the display. is this a known defect or issue or am i just seeing things/did something/being stupid here?
Mechcondrid is offline Find More Posts by Mechcondrid
Old Jan 21, 2013, 05:40 PM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
Prolly not the latter. I doubt it's common. If you just bought it, you should prolly use the warranty card to send it to FMA or talk to the distributor and exchange it.
Old Jan 21, 2013, 05:42 PM
Joined Nov 2010
well i'm just asking because i can see it fine it just those two lines are a bit faded (like the two lines are at 50 or 40% contrast while the rest is 60%)
everything else is perfectly functional and fine it's just a quirk as far as i am concerned
Old Jan 21, 2013, 05:44 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
That is a bit hard to visualize as the display is only a two line display.
Could your elaborate a bit? A good picture would be helpful too.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jan 21, 2013, 05:46 PM
Joined Nov 2010
i dont mean character lines i mean pixel lines
Discussion FMA Cellpro 10XP Charger alexf1852 Batteries and Chargers 78 Feb 11, 2016 10:59 PM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 180 Oct 04, 2014 09:43 AM
Sold Cellpro 4s Lipo & A123 Charger apex Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 02, 2011 09:49 PM
Found all around charger wanted / trade for Cellpro 4S +++ jazzster Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 21, 2008 05:55 PM
New Product Introducing the all new Brushless Sensorless Motor Controllers for cars and boats jackson_f Product Announcements 3 Jan 12, 2007 03:13 AM
