Old Nov 27, 2012, 08:36 AM
discohse is offline
Find More Posts by discohse
Still using old FF8
Taiwan
Joined Mar 2007
Hi, just got 10XP. After I try to connect it by CCS and forgot what I did, maybe reset to default once, now it always show "charging supply less than 24.4V" when start charging. What it means? And, when the fan will start to work? I use 24V power and charge 2x3S in Dual mode, 15C table, Auto 1.0C mode. Thanks.
discohse is offline Find More Posts by discohse
Old Nov 27, 2012, 08:42 AM
cmoulder is offline
Find More Posts by cmoulder
Pullin' G's Man
cmoulder's Avatar
Ossining, NY
Joined Dec 2005
See post #185 this thread.
Bob
cmoulder is offline Find More Posts by cmoulder
Old Nov 27, 2012, 04:39 PM
discohse is offline
Still using old FF8
Taiwan
Joined Mar 2007
Thanks, I find post#219 that explained my question.
Old Nov 30, 2012, 01:40 AM
Goodie_2_Shoes is offline
Find More Posts by Goodie_2_Shoes
Goodie_2_Shoes's Avatar
Australia, TAS, Launceston
Joined Jun 2012
Hi everyone,
I just have a couple of quick questions about the 10XP. I'm interested in finding a charger that would suit most of my needs and the 10XP ticks all the boxes. It seems like charging Lipos is pretty straight forward on this charger; however, I'm wondering about charging my Fromeco Li-ion packs I use in my gassers. Is there a way to charge the packs without having to worry about a balance charge? Could someone please talk me through the process of charging these packs?
On my old single port charger I just charge them on a Lipo setting at 2s 1.3A for my 2600mAh packs.
If you're not too familiar with these packs that are a 2S 7.4V either 2600 or 5400mAh.
Goodie_2_Shoes is offline Find More Posts by Goodie_2_Shoes
Old Nov 30, 2012, 02:45 AM
Joined Jun 2012
Just reading through the user manual and I noticed that the charger is capable or charging 1 2s Li-ion pack unbalanced. Now, if Fromeco packs had balance wires I could do 5 2s packs which is a bummer because I was hoping to charger at least two packs at a time without having to solder on balance connectors.
Am I on the right track or have I completely stuffed up???
Cheers
Old Nov 30, 2012, 02:47 PM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Man, you got me confused but then that's nothing new for me.... lol
Kurt (Fromeco) used to build some packs without balancing circuitry as he didn't sell a balancing charger. He's since done quite a bit of testing on the A123 (LiFe chemistry) cells and came to the same conclusion every one else has; they need to be balanced charged.
The same is true of the Li-Ion/LiPo chemistry; they need to be balance charged and it's been quite a long time since I've seen any of those batteries without balance leads.
My first thought would be that you should contact Fromeco and see what they've got to say, it might be a suggestion that you chuck those batteries.
As for your other question about the 10XP doing a "non-balance" charge; I think.... it can do that but would not do it myself so I've not really looked at all the capabilities.
Zeeb is offline Find More Posts by Zeeb
Old Nov 30, 2012, 04:49 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Cheers
Hi:
Either you are confused or I am. You can charge batteries in parallel regardless of whether you do a balanced charge or not. You just need to make up appropriate parallel harness. It's always best to balance charge, however. So I'm just saying what's possible, not necessarily what I'd recommend.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Nov 30, 2012, 09:44 PM
Joined Jun 2012
Well thanks guys, I had another look on the Fromeco site and found this that pretty much sums up everything http://www.fromeco.org/products/06frcjst-640/
Seems as if you can order the balance tap or when purchasing new batteries through Fromeco add a special request to have them add it.
I think I will still get the 10XP, it will be great for all my pattern stuff, parkflyers and foamies. As for my gassers I'm going to get the new Fromeco simple charger. Looking forward to playing with my new chargers, thanks again.
Old Dec 01, 2012, 05:07 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Goodie,
Since you are getting the CellPro 10XP be sure to specify the 5 node FMA wiring on your batteries.
Glen
P.S. You will also need two of the CellPro (JST PA) 10S 5S-to-4S adapters.
http://www.usastore.revolectrix.com/...-to-4s-Adapter
This adapter will interface between the 5 node balance connector on your batteries to the 6 node connector on the 10XP.
ggcrandall1 is offline Find More Posts by ggcrandall1
Last edited by ggcrandall1; Dec 01, 2012 at 08:24 PM. Reason: Additional information
Old Dec 21, 2012, 01:12 PM
ibbe76 is offline
Find More Posts by ibbe76
Joined Jan 2012
Hello everyone,always gets mild headache infront of the screen so I ask directly instead of searching.
the Cellpro 10XP Charger seems to be what I am looking for...so
for my logo 600 I got this turnigy 10s lipo- 2 JST-XH
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
So,I guess this is the right bord and I need two of them?
http://www.fast-lad.co.uk/store/revo...o-p-13563.html
or is there something else I need
ibbe76 is offline Find More Posts by ibbe76
Old Dec 21, 2012, 05:06 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
That would work and allow you to charge that as one 10s pack. However I think the Powerlabs would give a little more flexibility due to the higher wattage. You could still charge that 10s pack, but as two 5s packs in parallel.
Gregor99 is offline Find More Posts by Gregor99
Old Dec 31, 2012, 02:40 AM
fly2bob is offline
Find More Posts by fly2bob
fly2bob's Avatar
United States, CA, San Diego
Joined Nov 2005
To other FMA cell pro 10 users;
Can you explain info on internal resistance and the screen on the charger when you're charging. Should all the cells numbers be close ? What does the m and omega symbol mean when it's next to a cell's number?
I have a 5s 4200 pk that I can only use up to about 60-70% throttle on. It's a 4m, 12lb e-glider w/ a 16x10 folder on it and uses a C.C.125 esc. The pack fully charges fine, and there is no puffy on any of the cells. But if I try to go past the 70% throttle, the motor cuts out, and the esc will do a single beep intermittently.
I'm guessing that one or more of the cells are bad. IDK.
fly2bob is offline Find More Posts by fly2bob
Old Dec 31, 2012, 06:17 AM
cmoulder is offline
Pullin' G's Man
cmoulder's Avatar
Ossining, NY
Joined Dec 2005
The IR numbers should be close. For instance, on a very good quality battery with a C rating of 30 to 40, IR numbers will be something like 1.3, 1.7, 1.6, 1.5, 1.5 and on a lesser quality battery something like 2.5, 3.1, 2.8, 3.2, 2.7. Omega is the resistance in milliohms. If one cell is more than a few tenths of a milliohm above the others, the cell may be bad or is starting to go bad.
Throttle cut-out as you describe sounds just like thermal shutdown from over-amping. A quick fix is to change the upper throttle point on your transmitter so that 70% is your high-throttle stick position (or VR lever position for throttle if you are using the throttle stick for Crow/airbrake in a sailplane configuration).
Old Dec 31, 2012, 11:12 AM
Gregor99 is offline
Seattle
Joined Sep 2007
If your controller is an ICE, enable logging to see the current, pack voltage and controller temperature. It may be hitting the LVC under load. If the LVC is too high then lowering it may help. If the pack is not able to hold voltage under load, then it may be toast, or the pack is too low of C rating for the application. If that is the case, limiting the throttle fly2bob can help as long as you still get the performance you are after.
Old Dec 31, 2012, 12:16 PM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
ESC is a C.C. 125, so no data logging I'm afraid. Bought the batt used. Use to work fine. Did fly it to LVC, a mistake I now know. IDK what fuel % flying to the LVC puts you at, but I know it's not 80% like suggested, maybe more like 50%. Did lower to the LVC slightly to be able to use it as is.
It's a Neu 5s 4300 25/50c, and as I said, it charges fine (will take a chg up to full), and there is no puffy of any kind. As for the rest of the system; C.C. 125 esc, Neu 1510.5/1Y w/ a 6.7 gb, and 16x10 folder. From the motocalc; sys draws about 90 amps & puts out about 1500 watts.
So I guess that's it for that battery?
I'll have to go ahead and do a chg. and report the (resistance numbers) info.
Bob
Discussion FMA Cellpro 10XP Charger alexf1852 Batteries and Chargers 78 Feb 11, 2016 10:59 PM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 180 Oct 04, 2014 09:43 AM
Sold Cellpro 4s Lipo & A123 Charger apex Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 02, 2011 09:49 PM
Found all around charger wanted / trade for Cellpro 4S +++ jazzster Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 21, 2008 05:55 PM
New Product Introducing the all new Brushless Sensorless Motor Controllers for cars and boats jackson_f Product Announcements 3 Jan 12, 2007 03:13 AM
