Old Sep 29, 2012, 11:44 PM
Oetboy is offline
Find More Posts by Oetboy
United States, TX, Colleyville
Joined Jul 2012
Flew my icon for the first time today at a lake at 8500 ft ASL. Took off fine. Buzzed around a bit and brought her in for an ok landing (a bit of a belly flop and splash... But no harm done). Took off again, gained some altitude and decided to go for a loop on full throttle... Had enough to get up and around, but at the bottom of the loop she went into a spin and I crashed nose first into the lake. Rented a paddle boat to retrieve. Broke a few things:
1. Wings and motor stayed together but foam supporting motor broke off from fuselage. easily repaired with gorilla glue.
2. I lost two plastic pieces which I believe sunk. The plastic covering just behind the cockpit and before the motor (i can see aileron wiring now!). Also, one of the decorative small windows popped off. Hopefully I can still fly without these pieces?
3. I pre-treated all electronics with Corrosion X. I bathed Rx. Sprayed ESC and elevator servo (opened case and saturated). The other servos and motor I just sprayed them in their cases and hoped for seepage and successfull treatment. Everything still works post crash except one aileron servo. It made a funny "electrical" noise which sounded almost pulsatile. It responded to Tx commands a bit but did not travel as far as the other aileron. The wing itself appears undamaged from crash so I assume water is killing this servo. I let it dry out more and tried it again. Still the same funny noise but after some sluggish movements, the servo stopped in neutral position and won't respond at all to my inputs. Is the servo now a complete list? Anybody experience something similar? Suggestions?
4. Also small amout of water in cockpit. Now all fogged up. How do you fix this? Cut off windshield, dry, and reglue
Oetboy is offline Find More Posts by Oetboy
Old Sep 30, 2012, 12:59 PM
Paul-RC is online now
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Sorry about your crash.
Sounds to me that you may have pulled out of the loop a bit too hard and it stalled. T-Tails have bad stalls.
Even if the Icon does kind of well in aerobatics you have to be really smooth while doing them or coming out of any stunt.
As for landings , well it likes to come in with some power , not really speed but power to the motor like high iddle.
For the servos thats water for shure.
On mine I did cover more the servo arm area and stuff petrolium gely vaseline in there to repel water and it works really well.
For the cockpit fogging I would open up a small openning in the floor but do seal around the edges of the windshield on the outside.
Paul-RC is online now Find More Posts by Paul-RC
Old Sep 30, 2012, 01:35 PM
falconjet50 is offline
Find More Posts by falconjet50
United States, FL, Coral Springs
Joined Jan 2007
You will need a new servo for sure, I had mine flip over and servo acted funny until final it just froze up. I tried drying it out with a hairdryer with no luck. I purchased a new servo and replaced. Caerfully pull back tape and then use rudder cement to replace tape back on. On mine ou can not even tell I replaced my servo.
falconjet50 is offline Find More Posts by falconjet50
Old Sep 30, 2012, 01:40 PM
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
I also did replace my rudder servo but not do to water , just a stronger one , a HS82MG and it sideways on an elevated foam block with silicone and vaseline too .
It will never get in contact with water unless the plane fills up with water
Old Sep 30, 2012, 08:13 PM
Oetboy is offline
Joined Jul 2012
I am on vacation in the mountains so getting a new servo for my left aileron won't happen until I get back home. I'm upset that I damaged my plane do quickly. Do you all think I can fly the icon like a 3 channel trainer?! Just disconnect ailerons altogether and switch rudder to aileron so it's controlled on right stick? At least I could do touch and goes, right? Or is this not as easy to control as say a Super Cub 3 channel and I'm only wishful thinking?!
Old Sep 30, 2012, 09:33 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
The wing is to flat to be controlled by rudder only. I would wait.
rcrich is offline Find More Posts by rcrich
Old Oct 01, 2012, 02:13 PM
Oetboy is offline
Joined Jul 2012
Which servo did you replace it with?
Old Oct 01, 2012, 07:19 PM
Joined Jan 2007
I replaced with the stock servo from Eflite. Servo work great, any servo that gets wet will most likely fail. I sent back the orginial to Horizon and they sent me a replacement FREE of charge. Now that's custom service. I have had over 60 flights with this ICON with the new servo and no issues
Old Oct 02, 2012, 12:01 PM
Oetboy is offline
Joined Jul 2012
It's been 3-4 days since submerging my icon. The failing aileron has starte working again! I thought it might be a fluke and I didn't want to trust it after it behaved so erratically. But I've tried powering it up multiple times now and it seems pretty normal! The only difference I see between the damaged aileron servo compared to the other aileron servo is that when I "relax" the input (go from deflection to neutral), the damaged servo has a small amount of "flutter" before fully going neutral and remaining completely still. This is VERY minute movement and lasts only a split second.
Do you think it finally dried out and I can fly again? Or too risky?!
Old Oct 02, 2012, 12:50 PM
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
I personally would not risk it because if it jams on you in filght in one direction your done.
Old Oct 02, 2012, 02:09 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
I'm just now getting into transmitter (DX6i) control mixing. How does the A5 react to a programmed aileron/rudder mix? What % of rudder mix with aileron is recommended with the A5?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Oct 02, 2012, 02:12 PM
Renfield is offline
Find More Posts by Renfield
above us only sky
Renfield's Avatar
United States, SC, Greenville
Joined Jan 2006
Remove and disassemble the servo. Clean, lube and reassemble. Hang the cockpit from whatever angle it drains. If you're missing just the rear windows, forget about it. But make sure the radio room is sound. A new fuse might be in order. Rinse, repeat and FLY!!!
The Icon comes with coated Rx and ESC. The aileron servos often take a dunk, but they are tough. The only one I've replaced all summer was from hitting my neighbor's lamp post (on his dock) at full speed. It ripped the connection off the servo. I had to glue the wing in several directions. I'm pretty sure the servo still works. The wing still does!! This is one tough bird.
Renfield is offline Find More Posts by Renfield
Old Oct 02, 2012, 02:43 PM
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Thank you!
I have very little % on mine just to say it moves a bit along with the ailerons, if I need more I just feed in more manually.
I can also switch it off with the mix switch ( DX7)
Old Oct 02, 2012, 08:09 PM
Oetboy is offline
Joined Jul 2012
I kept on testing the "water damaged" aileron and it just kept on working... I took the risk and put her in the water and air this evening!!! Awesome landings in glass water, in the mountains with autumn leaves changing colors... And so peaceful... Until I hit full throttle!!!
Old Oct 02, 2012, 08:15 PM
Oetboy is offline
Joined Jul 2012
I have aileron/rudder mix at 20%. Not sure it's the best percentage mix, but I have only flown 2 batteries. First battery didn't go so well certainly 20% is flyable...
Build Log Icon A5 1800mm Wheazel Waterplanes 25 May 28, 2015 11:54 AM
Sold LPU: Parkzone Extra 300 - BNF (140) or PNP (100) samolot Aircraft - Electric - Airplanes (FS/W) 3 May 31, 2011 12:40 PM
Wanted Parkzone T-28D or F4U Corsair, or similar PNP or BNF TL697 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2010 11:17 PM
Found Parkzone F4U Corsair or T-28 BNF or PNP *Cheapish?* major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jul 30, 2010 04:50 PM
Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian Sid3ways Aircraft - Sailplanes (FS/W) 6 Jul 21, 2009 08:36 PM
