Old May 01, 2012, 08:04 AM
paxfish is offline
Find More Posts by paxfish
United States, MD
Joined Jan 2012
Originally Posted by DFloth View Post
Here's what I've been working on.. My PZ Icon A5 FPV!
Very Cool! Is that camera/vid transmitter waterproof? Could a smaller FPV LiPo be used to gain back that 1.7ounces?
I really think this might be my next plane....
paxfish is offline Find More Posts by paxfish
Old May 01, 2012, 12:29 PM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
PAX...
No the camera and Tx are not water proof.. but I have treated each with CorrosionX.. Lots of information her on RCG.
Link: http://www.corrosionx.com/corrosionx.html
And I'm saving my pennies for an eventual GoPro.
In truth a separate VID TX battery is not needed if you tap into the 3s motor battery. But using a separate battery insures a clean power signal to the Vid TX. And I've found a 460mah 3s for the VID TX is about the smallest I'd trust for a 15-30minute flight.
Cheers..
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old May 01, 2012, 04:21 PM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Went out a bit today to test my retreival Airboat and had an Icon flight
The boat is great but if I want to ride at high speed I need to install a stab to be able to trim the nose. But since its a rescue boat I wont do that , at least for now.
It was calm water but gray and misty so I only had 1 flight today.
Paul-RC is offline Find More Posts by Paul-RC
Old May 01, 2012, 05:50 PM
92PathSE is offline
Find More Posts by 92PathSE
Today's forecast: Summer
92PathSE's Avatar
United States
Joined Apr 2011
I really dig that boat!
92PathSE is offline Find More Posts by 92PathSE
Old May 02, 2012, 02:21 PM
Tuk151 is offline
Find More Posts by Tuk151
TUK151
Tuk151's Avatar
United States, LA, Ruston
Joined Aug 2011
Cool boat..
Tuk151 is offline Find More Posts by Tuk151
Old May 02, 2012, 02:24 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Originally Posted by Tuk151 View Post
Cool boat..
Yes cool! but I hope I dont have to use it for rescue
Just for fun is good enough
Old May 02, 2012, 02:57 PM
Tuk151 is offline
TUK151
Tuk151's Avatar
Joined Aug 2011
I'm interested.. .How are you going to hook it to the Icon A5 for a rescue?
Does it have reverse?
I'm guessing your going to get behind and push the a5....
Old May 02, 2012, 03:45 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
No reverse, it all depends on how the Icon is in the water.
The nose of the A5 goes well between the floats so I can push from there .
From the back too as long as I go slow I'm shure it will work out..... at least I hope
Old May 02, 2012, 04:49 PM
bigrap is offline
Find More Posts by bigrap
Joined Aug 2010
Rescue Boat
I was inspired with your rescue boat! I'm building one now with a pair of 40 size floats I got for free. I would also like to zip around the pond for some fun and don't want to bury the float tips. Would it work if you angled the traction prop up in the front of the boat so at speed it would lift the back up on plane? I'll try to post pics when i'm done.
bigrap is offline Find More Posts by bigrap
Old May 02, 2012, 04:52 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Possibly , its worth a try.
Old May 02, 2012, 08:35 PM
Lprevost is offline
Find More Posts by Lprevost
United States, NC, Morrisville
Joined Oct 2011
I agree, great boat. i've got those exact same spare floats. Now I know what to do with them!
Lprevost is offline Find More Posts by Lprevost
Old May 02, 2012, 09:02 PM
Lprevost is offline
Joined Oct 2011
I had a nasty incident during my learning curve on the Icon where I was really trying to slow it down before turning final and tip stalled it into the ground.
Has anyone tried some of the solutions for tip stall on the Icon like this one?
(from another forum) --- It also had a nasty tip stalling habit which I was able to correct by "reflexing" (angling up) the ailerons approximately 3 degrees.
Old May 02, 2012, 09:03 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
fly faster?
_OZ_ is offline Find More Posts by _OZ_
Old May 02, 2012, 11:38 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Originally Posted by _OZ_ View Post
fly faster?
Yep, what he said.
I don't think messin' with the ailerons will help when you run out of airspeed and ideas at the same time.
Just leave around 1/4 throttle till you are low and in the flare.
Sounds like a good learning experience though.
Buzzed is offline Find More Posts by Buzzed
Old May 04, 2012, 03:16 AM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Well got a call from a buddy yesterday and he lost his A5 from a cooked ESC.
He lost all power and it went down hard in the water.
HE will repair it but I told him to install a separate BEC even if he doesn't add Flaps at least if the ESC fails he will have power to glide in.
He said no water went to the ESC before this happed and he has been using the 2200 3 cell lipo's and flying 8min not pushing it so the ESC wasn't working hard from what I can see.
Build Log Icon A5 1800mm Wheazel Waterplanes 25 May 28, 2015 11:54 AM
Sold LPU: Parkzone Extra 300 - BNF (140) or PNP (100) samolot Aircraft - Electric - Airplanes (FS/W) 3 May 31, 2011 12:40 PM
Wanted Parkzone T-28D or F4U Corsair, or similar PNP or BNF TL697 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2010 11:17 PM
Found Parkzone F4U Corsair or T-28 BNF or PNP *Cheapish?* major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jul 30, 2010 04:50 PM
Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian Sid3ways Aircraft - Sailplanes (FS/W) 6 Jul 21, 2009 08:36 PM
