Old Feb 02, 2013, 03:48 PM
Renfield is offline
Find More Posts by Renfield
above us only sky
Renfield's Avatar
United States, SC, Greenville
Joined Jan 2006
Originally Posted by WhirlyBits View Post
What did you use for a correction?
I'll probably use my "modern foamy modeler's secret weapon" - gorilla glue!
Just run a small bead in there and cover with tape to keep it from expanding/keep the surface flush.
I've read good things about the gorilla glue. I was tempted to go with CA and get in another flight that evening. But I took the high road and did a sweet epoxy fix with a proper cure time. You have to be looking for it to see anything.
I'm so glad it didn't break free altogether. That's much harder to get right.
Just one side, almost entirely where the factory saved $.30 on glue.
Renfield is offline Find More Posts by Renfield
Old Feb 02, 2013, 06:35 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
How's the stock power on this? Enough to pull the gopro and fpv gear?
Wingbreaker is offline Find More Posts by Wingbreaker
Old Feb 02, 2013, 07:21 PM
WhirlyBits is offline
Find More Posts by WhirlyBits
Fly Freely, Fly Responsibly
Fort Worth, TX
Joined Jan 2010
GG is pretty amazing stuff. The plane I have flipped over on it's back, is the PZ T-28. About a year and a half ago, I snicked off the vertical stab right at that bend 3-4" back from where is leaves the fuselage. I GG'd the whole thing back on using semi-sticky tape to keep it from expanding/ballooning. It's painted blue in that area, and you can't even tell it was GG'd, except for slight sheen in the matte finish - just at the break line - and you have to get real close to tell. It doesn't become brittle either, unlike epoxy. Just stronger.
GG is truly amazing stuff. Lighter than epoxy too. They both have their uses.
WhirlyBits is offline Find More Posts by WhirlyBits
Old Feb 04, 2013, 02:09 PM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
First tail fix on the former Hangar Queen
I've put four packs through the PZ today so far, and the tail fix is good! It did nothing for the dutch roll, but I never expected that to change.
Old Feb 04, 2013, 07:04 PM
Fort Worth, TX
Joined Jan 2010
Nice job!
That's about how my PZ T-28 tail repair came out (about the same location, also). It might have 'discolored' a bit, but mine is the USAF version (gray/blue) so it was not noticeable.
Question: My PZ Icon is due here on Wednesday. What about that gray paint on the underside. I've heard it comes off real easily with your hands (not from scraping). Can/should anything be done about that? Still an issue?
Old Feb 04, 2013, 07:22 PM
wilem is offline
Find More Posts by wilem
airplanes r made from aluminum
wilem's Avatar
United States, SC, Darlington
Joined Jul 2009
Nice job!
mine has not
wilem is offline Find More Posts by wilem
Old Feb 05, 2013, 08:12 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
Nice job!
The gray is fine. Silver, not so much.
Old Feb 05, 2013, 04:24 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Woo hooooo!
Not only has my PZ A5 shipped earlier today, but I just ordered an HK ORX3 V2 3-axis gyro!
Let's see those previously nasty 20-plus mph and added gusts winds! Bring it!
How do ya' like me now, son-a-ma-beeeesh????
Enjoy your new A5!
I have the ORX v2 on my HK small Icon and love it! However, they have some minor quirks. If you have to reverse the servo direction on the ORX, MAKE SURE that you also re-check the reversing settings in the tx after EVERY CHANGE! A reversal on the ORX will fix the gyro acting direction, but it will also reverse your control inputs, resulting in the need to reverse everything again in the tx. Fortunately for me, I got it all sorted before I went flying, and I had no death spirals or anything on the maiden. Also, do take the plastic case off before you install the ORX and check the soldering on all the input/output pins. One of my pins had no solder, which obviously prevented the unit from working. Applied solder in the correct place, and it's been working perfectly ever since!
Firehawk989 is offline Find More Posts by Firehawk989
Old Feb 05, 2013, 07:35 PM
Fort Worth, TX
Joined Jan 2010
Thanks, Hawk!
Yeah, I read the whole ORX3 "thread" where you and others refer to that. I'll be reading and re-reading it a few times during install and before I flip the "on" switch!
This is the first time I've ordered from HK. Ordered on Friday, specified "US Parcel" (or whatever) mail - including 10 10CM male-to-male servo cables - and just got an email that "it's about to be shipped" and "allow 48 hours for tracking info." Since I paid ~$16 for shipping, that ought to put it here around the end of the month...
Ah, well...I'm sure a few flights without it won't hurt. I'll skip the high-winds test, until it arrives...
Old Feb 06, 2013, 08:51 PM
Fort Worth, TX
Joined Jan 2010
Bummer.
Putting together my brand new PZ Icon A5.
Got the LG on and horizontal stab screwed on.
Left the wings off, for the moment. Plugged a LiPo in, got 3 beeps, no lights flashing in the Rx. Hmmm. Rechecked bind plug. Turned on my Tx on an empty slot in my Dx6i to try to bind anyway. No go, of course. Tried connecting the aileron leads also, for giggles. Nope.
Disconnected ESC lead to the included AR600 (BNF version), and mostly disassembled my PZ Stinson SR-10 to get the AR500 out of it to try.
3 beeps on battery power with the Icon ESC connected to it - no flashing.
I'm stumped. Bad ESC? Bad motor? It's not the AR600 Rx that came with it.
Can ya help me out, fellas?
What a bummer...at least I ordered it direct!
Old Feb 06, 2013, 09:06 PM
Fort Worth, TX
Joined Jan 2010
Disregard last transmission. It was a "bad" bind lead, of all things!
It binded fine. Back in 'bidness' and building resumes....
Old Feb 08, 2013, 08:58 AM
Renfield is offline
above us only sky
Renfield's Avatar
Joined Jan 2006
What's the word, whirlybird? Here's a little inspirational action shot to get you motivated.
Old Feb 08, 2013, 08:43 PM
Fort Worth, TX
Joined Jan 2010
Niiiiice!
Yep...she's all built and calibrated. The right aileron is just a little off...I have it set 1/4 trailing-edge height high on the outboard, and 1/2 trailing-edge height low on the inboard side - starboard aileron. No biggie...my T-28 came a little like that and only needed one click, max, on the Tx. Power run-up is impressive!
Unfortunately, winds are forecast for 14-18 tomorrow. Not really "maidening" weather.
When my ORX V2 comes in, though.... But I won't wait for it if a calm (2-7) day shows up.
Happy flights! I'll letcha' know when it's been skyward...
Old Feb 10, 2013, 02:03 AM
Gator23 is offline
Find More Posts by Gator23
Serial crasher
Gator23's Avatar
Switzerland (French-speaking part)
Joined Aug 2009
A few pictures of mine:
And a short video on snow:
Parkzone Icon A5 on snow (1 min 8 sec)
Nice little plane.
Gator23 is offline Find More Posts by Gator23
Old Feb 10, 2013, 02:22 PM
Paul-RC is online now
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Here is mine from flying this morning.
This is the second time on snow for it and lots of fun too
Here is a small video from this morning
Icon A5 -Winter-flight (3 min 11 sec)
Paul-RC is online now Find More Posts by Paul-RC
Build Log Icon A5 1800mm Wheazel Waterplanes 25 May 28, 2015 11:54 AM
Sold LPU: Parkzone Extra 300 - BNF (140) or PNP (100) samolot Aircraft - Electric - Airplanes (FS/W) 3 May 31, 2011 12:40 PM
Wanted Parkzone T-28D or F4U Corsair, or similar PNP or BNF TL697 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2010 11:17 PM
Found Parkzone F4U Corsair or T-28 BNF or PNP *Cheapish?* major.monogram Aircraft - Electric - Airplanes (FS/W) 2 Jul 30, 2010 04:50 PM
Wanted Multiplex EasyGlider Pro/Cularis PNP/BNF or Parkzone Radian Sid3ways Aircraft - Sailplanes (FS/W) 6 Jul 21, 2009 08:36 PM
