Sep 05, 2003, 05:49 PM
United States, IL, Chicago
Joined Dec 1996
Matt
I fly a Sig 1/5th Cub on a geared MaxCim and 20 cells - at 8lb 2 oz, she's off the deck before 3/4 throttle and flies on a sniff of power. Used 20 as I had them and they fitted - they are 2000 NiMh and I've flown for nearly 8mins with plenty left.
See no reason your AF40 / 1/4 scale Sig shouldn't be a good flier. Have never seen a Sig that didn't go great as an electric, in fact! Would echo the others in suggesting the Superbox to allow for bigger props - I fly my 1/5th on a near scale diameter 15 x 8.
DOn't know about your 1/4 but fitting and accessing the battery is a snip in the 1/5th, thanks to its functioning side door / window. I didn't even bother making up the battery fittings until I had the model built, as the door offered so much interior access.
What I did find was that my guesstimation of the pack going in the centre of the cabin was way off. I had to move it forward to hard against the back of the front cabin frame former to achieve balance.
If I could carry one around, would be looking at a Sig 1/4 Cub - my 1/5th is a lovely sight in the air and is a dream to fly. Good luck with your project. Can you figure what the model is in my avatar?
Regards
Dereck
