Old Feb 17, 2013, 11:47 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by GBLynden View Post
Yeah, but mine is nose heavy and I finally have the CG tuned just right. What packs do you suggest and how does their weight differ?
I use Hyperion 240mAh's. I don't have any of the E-flights to compare. But the Hyperions weigh 16 3/4 grams. with wires and a little Velcro tab.
erkq is online now Find More Posts by erkq
Old Feb 17, 2013, 11:58 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Originally Posted by GoAround View Post
Looking at my prop, it seems to be angled to give down thrust at the rear. I wonder if this is correct as it would give the symptom of pitching up at speed.
Down thrust will cause it to pitch down (or at least limit any ballooning) under power.
This is because the thrust is delivered behind the CoG causing it to rotate downwards.
Tony
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Feb 17, 2013, 04:37 PM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
Tony, the top of the prop is nearer to the front of the aircraft than the bottom meaning it is blowing up a bit. This should force the tail down and the nose up when power is applied which is what I'm seeing. I haven't had a chance to fly it since programming the throttle to down elevator mix but if my thrust angle is wrong then I naturally would like to fix that first.
GoAround is offline Find More Posts by GoAround
Old Feb 17, 2013, 05:16 PM
gopeder111 is offline
Find More Posts by gopeder111
wing dragon/typhoon 3d
Joined Sep 2005
I bought a stryker 180 at my LHS for $65. While setting up the plane I realized that either the motor or esc is messed up. The prop spins slowly in a weird twitchy way Hopefully my LHS will make it right but if they don't, has anyone else ever had this problem? Is Parkzone customer service good? I have a feeling I'm going to have to spend money to ship it to them so they fix it.
gopeder111 is offline Find More Posts by gopeder111
Old Feb 17, 2013, 05:22 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
This may be too simple, but Is the lipo fully charged? They can go flat while setting up planes if they haven't been charged.
KC is offline Find More Posts by KC
Old Feb 17, 2013, 05:40 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
I think HorizonHobby Customer Service is GREAT!! If I've had a problem with a servo or motor they simply sent me a brand new one! My full-size Stryker I had to send the motor & ESC to them and they sent me a brand new motor & ESC right back. I've never had any problems with their service, good luck.
rcoconut is offline Find More Posts by rcoconut
Old Feb 17, 2013, 06:00 PM
Joined Sep 2005
Yes, it was fully charged.
Old Feb 17, 2013, 07:40 PM
brushless55 is online now
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
sounds like a loose motor connector
brushless55 is online now Find More Posts by brushless55
Old Feb 17, 2013, 10:00 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Hands down the best customer service I have ever seen. Contact your LHS first, and if they give you grief contact parkzone/horizon. They will make it right for you.
3d astronaut is offline Find More Posts by 3d astronaut
Old Feb 18, 2013, 01:28 AM
BMFA 190658
Joined Mar 2007
Sorry my bad!
Thought you meant the prop was blowing downwards. These pushers get me all confused...
Tony
Old Feb 18, 2013, 01:48 AM
overthebars is offline
Find More Posts by overthebars
overthebars's Avatar
meridian, idaho
Joined Mar 2010
Picked one of these up after seeing the ridiculously low price drop. I've read enough pages of the thread to get a 4040 prop and some legit batteries on order. Can't wait for the accessories to show up so I can get her maidened. I think I will spend some more time on the thread pages just to get some flying hints & tricks figured out.
overthebars is offline Find More Posts by overthebars
Old Feb 18, 2013, 02:55 AM
GoAround is offline
GoAround's Avatar
Joined Dec 2012
Originally Posted by SilentPilot View Post
Sorry my bad!
I thought so - they make all the usual terminology useless!
Do you think I should shim it a bit? If so, what angle are they normally at? I would imagine the exact opposite of mine ..
Old Feb 18, 2013, 04:04 AM
BMFA 190658
Joined Mar 2007
Yeah, I'd adjust that.
A slight bit of up thrust might be ok but try flat first
Old Feb 18, 2013, 06:17 AM
GoAround is offline
GoAround's Avatar
Joined Dec 2012
Wilco. Should be able to get a test flight in tomorrow and will report back.
Old Feb 19, 2013, 01:06 PM
Joined Sep 2005
My LHS is getting a new shipment on Weds. so they will replace it then. I also bought a Dx6i on ebay to go with this plane but I read it has problems with elevon mixing after I bought it. Is this going to be a major problem with the stryker? Does anyone use a dx6i with theirs?
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
