Old Feb 16, 2013, 02:22 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
You guys are killing me.. The last 3 pages of this thread sold me on the stryker. Between this and the nano I just bought, I may be in some trouble
Whats the recommended battery for this bad boy? Any recommended mods? Different props? There is simply too much info in this thread! Off to read 250+ pages
edit// found: battery "180mah-240mah, something like a hyperion or nano tech"
prop "4040" seems to be popular
mods none that I have noticed besides a gram or two with pitch on wot (I will be using mixing if the issue is bad enough)
3d astronaut is offline Find More Posts by 3d astronaut
Old Feb 16, 2013, 07:20 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
For those of us without Magic Fingers at the controls, a bit of packing tape and CF can be employed to reinforce the airframe's common weak spots.
In particular, the elevon tips and the fuse from the canopy to the nose.
Just my 2 cents......
pugsam is offline Find More Posts by pugsam
Old Feb 16, 2013, 08:39 AM
GoAround is online now
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
I have now put in a 10% flap to throttle mix which gives a subtle amount of down elevator to up throttle ('the mix' puts elevator onto flap channel). I have left it switchable and am concerned it will only ever be tweakable to work on one set of rates so I may need to learn to do all my flying at high rates.
I have also been as precise as I can on the mechanical trimming as it seemed to have a minute amount of up elevator which would not have helped.
3 nails (3.75g) have been left in the tail. This seems a sensible amount to counteract the extra weight of the Nano-Tech 300mAh. It puts the CG 3mm forward of Eflie's recommended.
Looking at my prop, it seems to be angled to give down thrust at the rear. I wonder if this is correct as it would give the symptom of pitching up at speed.
I'll report back when I get the chance to fly it.
GoAround is online now Find More Posts by GoAround
Old Feb 16, 2013, 10:44 AM
Zeus_Lewis is offline
Find More Posts by Zeus_Lewis
Canada, AB, Calgary
Joined Jan 2013
Yes.. this is a must when everything is brand new otherwise it will start looking pretty beat up without. If I hadn't taped my Stryker, the small crash I had probably would made it look like it was a 10 year old piece of foam. I seriously have to give everyone credit for my ability to fly this plane. I read every post and took everyone's advise and also watched all the videos... really shows you what to expect.
The only thing I did do was I removed "the mix" because it seems to really overwork the servos in the corners and I am not skilled enough to be able to recover from a mechanical issue. Human error keeps me busy enough. I did add the Throttle to Elevator mix @ 10% which works perfect for me to keep everything level when on full throttle (I also had to completely remove foam block to move battery back far enough to get CG set on my plane).
Zeus_Lewis is offline Find More Posts by Zeus_Lewis
Old Feb 16, 2013, 01:24 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
ok lets talk about this mod with pictures
brushless55 is offline Find More Posts by brushless55
Old Feb 16, 2013, 01:33 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Ha!
There's usually more than one good way to do these things.
I'll see what I can come up with in the way of photos.......but YMMV....
Old Feb 16, 2013, 01:37 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Photos here illustrate the vulnerable area in the front of the fuse
http://www.rcgroups.com/forums/showp...postcount=4180
Old Feb 16, 2013, 01:43 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Posts showing some reinforcement strategies:
http://www.rcgroups.com/forums/showp...postcount=2678
http://www.rcgroups.com/forums/showp...postcount=1752
Old Feb 16, 2013, 01:50 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Not shown: using clear tape strips to strengthen the fuse along the fault zone pictured so graphically in post 4237.
That preventative mod doesn't photograph very well; the clear tape doesn't show up. (Which, of course, is a GOOD thing!)
Just use common sense. Apply tape strips in such a manner (location and direction) that their tensile strength will protect the foam from breaking as a result of impact forces.......
Old Feb 16, 2013, 03:47 PM
doug.wagner is online now
Find More Posts by doug.wagner
I can fix that!
doug.wagner's Avatar
United States, ME, Bangor
Joined Jul 2011
Thanks Pugs...now I can't get my mouth closed!
doug.wagner is online now Find More Posts by doug.wagner
Old Feb 16, 2013, 04:27 PM
Canada, AB, Calgary
Joined Jan 2013
Here's a few pics... it's hard to see but I used 3M Scotch Tape on the Wing Leading Edge then after i had my incident, I put the effort into taping the curved parts with Packing tape.
I should have done that it the first place with the Scoth tape but I didn't feel the need to. I do now though!
Old Feb 16, 2013, 04:30 PM
Canada, AB, Calgary
Joined Jan 2013
Hey Pugsam... I no longer appreciate Tensile Strength. That picture would have been better without it.
Old Feb 16, 2013, 05:40 PM
big ignore list
Joined Nov 2011
Awesome, thank you!
Old Feb 16, 2013, 05:57 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Awesome, thank you!
I wonder why we haven't heard from 8thelephant in a while......those posts are from him.......he's the awesome one.
8th, are you out there?
Old Feb 17, 2013, 07:32 AM
GBLynden is online now
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
Originally Posted by erkq View Post
Second E-flight? Ew... don't buy any more of those! You can have better performance and life at 1/2 the cost.
Yeah, but mine is nose heavy and I finally have the CG tuned just right. What packs do you suggest and how does their weight differ?
GBLynden is online now Find More Posts by GBLynden
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
