Old Jan 18, 2013, 12:18 AM
jumna is offline
Find More Posts by jumna
United States, TN, Gray
Joined Nov 2010
Nice vid Realgambler. Are the upright boomerangs always a faster spin? The couple of times I've gotten an upright it seems to spin a bit faster. $75 is tempting for a backup emergency Stryker. Ya know, I'd like to see a sale on the 180's big brother sometime before spring....
jumna is offline Find More Posts by jumna
Old Jan 18, 2013, 02:08 AM
GBLynden is offline
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
So is the balance charger that comes with it any good?
GBLynden is offline Find More Posts by GBLynden
Old Jan 18, 2013, 02:30 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
I use it, very convenient if you have a 12v power supply, you can get one that works at staples or Walmart or something. I think it works well, all of my batteries charged using it lived up to and beyond expected lifespan.
airpower is offline Find More Posts by airpower
Old Jan 18, 2013, 02:38 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I use mine as a travel charger.
It works just fine and I trust it not to damage my batteries, however, without a readout to know how many mAh have gone back in I cut my flights quite short so as not to risk going over 80% discharge.
Tony
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jan 18, 2013, 02:44 AM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
If it had a voltage digital readout I would not care about old 2-4s balancing celectrix anymore, also ability to set charge current like on their mcpx and mossie chargers, that would make me perfectly happy. Two ports.
Old Jan 19, 2013, 08:59 AM
Sun Eagle is offline
Find More Posts by Sun Eagle
Sun Eagle's Avatar
Joined Dec 2012
I apologize if this has been covered before but after doing searches and reading many pages I could not locate exactly what I was looking for.
I bought a UM Stryker last night. Besides a bent control horn, to my horror I realized that the Battery/Plane has some kind of funky connector type on it that won't connect to my Turnigy charger. No warning of this was given on the box, on the website, by my LHS, etc.
1. What is the name of this type of connector?
2. Is this a proprietary Parkzone thing?
3. If not, where can I purchase bats that are setup with this connector already?
4. Can I purchase an adapter so I can charge this battery on my normal chargers?
Sun Eagle is offline Find More Posts by Sun Eagle
Old Jan 19, 2013, 10:02 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
It's called a UMX connector. It's only used on Horizon Hobby products (E-Flite, Parkzone). You can purchase batteries from many third party now, and they will come with the right connector. Hobby King (cheap), Hyperion, or if you want some homemade and very light package, check RCBabbel here on this forum. Sure enough, you can also purchase adapters, either for charging on your Turnigy charger) or for converting batteries (JST to UMX). For that, just google "umx adapter" and you should find quite a few. But quickly, Gleen, at RC-connectorsDOTcom is pretty good. RCBabbel is also selling some. And even Hobby King is selling some. Otherwise, dig around, there's quite a few place selling adapters. I highly recommend that you buy a parallel charging adapter, which will allow you to charge up to 8 batteries at once. (You can still charge only a single battery if you want, but eventually, you may have to charge a lot more! )
Some people also simply replace the connector on the airplane itself. But trust me, if you start flying those little UMX airplanes, you may end up with a few of them, so it's up to you. They really seem to like that connector, since they even started using them on the new heli mCPx BL that just came out.
RealGambler is offline Find More Posts by RealGambler
Old Jan 19, 2013, 10:03 AM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
1. You know, not sure what the "official" name of the connector is called, but I've gotten to know them as Micro Connector as well as the JST-PH Charge Connector???
2. No, oops, my apologies, guess it is a HH thing, sorry...... It's the only products I fly so wasn't sure 'bout that one!?!
3. HobbyKing has the batts with the connector on it already, or you can do what some of us here has done and contact RCBabbel here on the forums & he'll get you a 2s 240mAh batt also with the proper connector for you (I have 4 of his Babbel Batts as well as 4 of his 1s 180mAh batts, LOVE 'em!!!)
4. I use this to charge my micro batts with my ThunderPower charger:
http://www.progressiverc.com/paralle...beast-umx.html
rcoconut is offline Find More Posts by rcoconut
Old Jan 19, 2013, 10:06 AM
Canada, QC
Joined Oct 2009
You can make it spin slower with the rudder, but faster spin usually mean lower descent (and it's much cooler to look at!). I usually spin fast, then, if I want to land it, I simply inverse the rudder at the last few seconds, so I can slow down the spin enough (a lot) and land it without ripping anything.
Old Jan 19, 2013, 10:15 AM
BMFA 190658
Joined Mar 2007
Flew mine today in the snow!
Numb fingers stopped play before any mishaps, good job as the grey sky was causing orientation issues...
Old Jan 19, 2013, 10:27 AM
rcoconut is offline
rcoconut's Avatar
Joined Sep 2006
Hey Silent, would this help ya out during the cold months??
http://www.hobbyking.com/hobbyking/s...ap_Ready_.html
Old Jan 19, 2013, 10:41 AM
BMFA 190658
Joined Mar 2007
I've got a mitt on it's way, it'll probably get here in time for summer!
Old Jan 19, 2013, 10:45 AM
rcoconut is offline
rcoconut's Avatar
Joined Sep 2006
LOL, awe man, isn't that the way it always goes......
Old Jan 19, 2013, 10:55 AM
Canada, QC
Joined Oct 2009
That Tx glove is the most awesome thing for winter flying, but sadly, it's hard to launch the Stryker with one hand, then, quickly re-insert the hand into the glove and reach the Tx quickly. If you have somebody else to launch it for you though, then, it's a must. Otherwise, it's better to fly something that doesn't need handlaunch (Clean/frozen runway, or skis). Sure enough, it's a MUST in any cold country.
Old Jan 19, 2013, 11:13 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Just launch with your left. You have all the time in the world to get your left hand back in there if you've got your right hand on the stick.
erkq is online now Find More Posts by erkq
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
