Old Dec 01, 2012, 09:51 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Originally Posted by brushless55 View Post
Got mine yesterday from the Black Friday $70 sale!
and picked up a DX8 about an hour ago!!!
$70!!! Wow, & a DX8, nice score!!! Congrats!
rcoconut is offline Find More Posts by rcoconut
Old Dec 01, 2012, 10:03 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
I have a DX6i and like that radio but this DX8 flipping rocks!!
so easy to program my Stryker to the DX8
brushless55 is offline Find More Posts by brushless55
Old Dec 01, 2012, 10:38 PM
rcoconut is offline
rcoconut's Avatar
Joined Sep 2006
No doubt!!! It was such an easy transition to the 8 as well as moving the fleet over!! My Radian Pro was so easy!!!
Have fun with both!!!!
Old Dec 01, 2012, 11:28 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Glad you got a DX8, BL. You'll love it. The DX6i is a nice radio for the money for sure, but I love my DX8!
erkq is online now Find More Posts by erkq
Old Dec 02, 2012, 05:40 AM
tomcor is offline
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
I just received my new UM Stryker. It is missing one servo cover. And the battery seems to be slightly puffed, when you squezze it seems hard is this normal for the stock battery.
Also when i power it up the servos make quite a bit of noise at idle. I bound and setup setting on my dx6i still seems noisy. It works ok with control. First flight next day off.
tomcor is offline Find More Posts by tomcor
Old Dec 02, 2012, 05:50 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Originally Posted by lovespicyfood View Post
Hi Jim,
Just loaded your file into my DX8 after moving the servo connectors around as suggested. Everything works fine except for the right aileron is not working. However, this control surface works fine when applying elevator- the control surface moves and moves in the right direction.
Any suggestions on what is going on?
The only thing I did so far was erase the +30 sub trim on the rudders...
Pete
Sub trim on Rudder?
I thought that was a big no no for linear servos...
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Dec 02, 2012, 07:08 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Should not be missing the servo cover... There's a few reports of servo covers not having much glue on, so maybe it's somewhere in the box under the foam.... The noise is normal (I guess this is your first ultra micro with linear servos?).
RealGambler is offline Find More Posts by RealGambler
Old Dec 02, 2012, 07:58 AM
Hornetnz is offline
Find More Posts by Hornetnz
United States, NC, Raleigh
Joined Jun 2005
I grabbed that deal too. Actually I mentioned it, and the wife bought it for me for Christmas.
Hornetnz is offline Find More Posts by Hornetnz
Latest blog entry: 93" AJ Laser 230z
Old Dec 02, 2012, 03:48 PM
macr0t0r is offline
Find More Posts by macr0t0r
Got more toys than my kid
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
Originally Posted by SilentPilot View Post
Sub trim on Rudder?
He's using my SPM file which employs split rudders. I moved the sub-trim inwards 30 counts and then mechanically re-aligned the rudders. This is because I have the rudders configured to go more "out" than "in" to give a better yaw-response with less pitch-up tendency. It also allows a little extra yaw movement when you have the tails split for air-brakes.
However, many people may not want to spend nearly as much ridiculous time I did making it juuuuuust right.
- Jim
macr0t0r is offline Find More Posts by macr0t0r
Old Dec 02, 2012, 04:38 PM
BMFA 190658
Joined Mar 2007
I thought that using sub trim on these tiny linear servos was a sure way to mess them up...
Old Dec 02, 2012, 07:38 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
Flew mine on 3S today (ofc, rudder got stuck twice @ 80% ;-)
That was damn tricky to bring it back with a stuck rudder when it was over the water, i might have grown a couple of white hair..
Anyway, won't fly it 3S anymore. It doesn't bring much. its heavier and the added speed doesn't really make it more fun IMO (plus, its not _that_ much faster).
I used a 250mah 3S and a 4040 prop, stock ESC/motor, did max throttle passes of ~5-10s nothing blew up. (i wouldn't recommend something with a lot more thrust than the 4040 cause i'm not sure the ESC would handle the amp draw)
CrashMeUp is offline Find More Posts by CrashMeUp
Old Dec 02, 2012, 09:27 PM
macr0t0r is offline
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
Well, usually a servo will travel the same amount in opposite directions, so adding subtrim is nearly a guarantee of binding the servo in one direction. However, I modified the sub-trim AND the travel adjust, so it works out that they move to the same physical location in both directions.
But yes, you don't want to mess around with the sub-trim without checking things out in the servo monitor first. Otherwise, you could overdrive the servos.
- Jim
Old Dec 02, 2012, 09:28 PM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Originally Posted by macr0t0r View Post
2. Move the Elevator(Ch3) servo plug to the Pitch(Aux1/Ch6) channel.
Hi Macr0t0r, I'm finally getting around to trying your upgrade, but I'm stuck on step 2. So if you move the servo plug from Ch3 to Aux1/Ch6, where do you move the one that's already plugged into Aux1/Ch6?
Edit: Just for giggles, I powered up as is without touching that elevon servos, since I didn't know what to do with them, and I'm getting similar results as Lovespicyfood did in his post on the previous page. The left elevon works as ail and elev, though not the full deflections, and the right elevon works as elevator only.
Edit 2: I plugged the servo from Elev(Ch3) into Ail(Ch2) instead of following the instructions And now it seems to work as advertised. Can you confirm that's correct?
The only thing I'm still curious about is I can give full right ail, and the right elevon moves up, then I can add full up elev, and the right elevon will still move up a bit more. Same to the left, down, etc. It's not a lot, probably better than it was without your mod, but this is normal? It's what you get, too?
Can't wait to try it out! Thanks for doing the work and sharing with us!
Oh, and I guess I should ask about this, too. I used to have a mix from my gear ch to my elevator. I made it so with 'gear down' I got a little up elevator for hand launching, then I could switch to 'gear up' and be right back in trim. I was reading you are using the gear channel already for something? If so, is there another switch I could duplicate this with? Sorry, but I don't know squat when it comes to heli programming!
xmech2k is offline Find More Posts by xmech2k
Old Dec 03, 2012, 12:46 AM
BMFA 190658
Joined Mar 2007
- Jim
Nice one Jim, I'm looking forward to trying these settings
Tony
Old Dec 03, 2012, 06:36 PM
macr0t0r is offline
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
<snip>
Huh...nothing should initially be plugged into the Aux1/Ch6 port, as the Stryker only uses the first 4 channels in the stock configuration. ILoveSpicyFood also had to a similar swap, so you're not alone. Did I post the wrong receiver manual? I may have to pop open my Stryker and take a few pictures so that people can see the end result. Technically, the servo that is being controlled by the elevator channel needs to be plugged into the pitch channel. I can confirm that with the servo monitor on the DX8. However, the plug labels may not be correct in the PDF I linked to. In any case, assuming that the "Elevator" and "Aux" channels are swapped, I'd say your current setup is now correct.
The E-Ring feature will not let me "max" the control throw from just a single input. I'm required to reserve what looks to be about 5% movement. Certainly a lot better than reserving nearly 50% movement when using elevons.
Ah...well...the "gear" channel is now the other rudder. You pulled out the Y-harness and plugged the two rudders into individual channels, right? Therefore, I moved the gear channel from the switch to the left trim toggle so that you can individually adjust one rudder channel in order to line up the two rudders. I then use the 3-position Flap switch to set the split-rudder air-brakes. You may be able to re-assign the gear switch as flaps (I'm not sure, as I don't have my radio with me). Using the gear switch to pop a little up-trim for launch is a good idea (I remember that from the full-size Stryker forum). I'll add that in this week.
- Jim
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 03:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 06:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 12:02 PM
