Old Nov 23, 2012, 07:04 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Originally Posted by pda4you View Post
I like this site for GWS props...
http://www.gwsprops.com/
Second!
A stateside vendor with great prices and service.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Nov 23, 2012, 07:36 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Hey I have a question about the F27Q stryker 180. For those of you using the DX7s, is there any connections in the plane that need to be switched to be able to fly this plane like the DX6i, or is it all in the radio?
electricrc68 is offline Find More Posts by electricrc68
Old Nov 23, 2012, 07:38 PM
BigEast is offline
Find More Posts by BigEast
Enjoying life through flight
Joined Mar 2012
no wiring needs to be messed with. Simply select Elevon type in you Dx7s, set your dual rates/expo and you're off!
BigEast is offline Find More Posts by BigEast
Old Nov 23, 2012, 07:43 PM
Joined May 2011
Oh okay cool thanks! Do you have any expo/dual rate settings you recommend for the stryker?
Old Nov 23, 2012, 07:46 PM
BigEast is offline
Joined Mar 2012
I do! Tomorrow when I get home I'll post them.
Old Nov 23, 2012, 07:53 PM
Joined May 2011
Alright cool thanks!
Old Nov 23, 2012, 10:24 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
brushless55 is offline Find More Posts by brushless55
Old Nov 24, 2012, 12:37 AM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Thanks for the recommendations on props! My lhs ordered me some but they are orange. . I think I will call and cancel so I can get black ones from gwsprops!
Pete
lovespicyfood is offline Find More Posts by lovespicyfood
Old Nov 24, 2012, 01:08 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Pete
Did he get you the 4040's? I could never find black ones. It seems all the 4040's are orange. It doesn't look too bad on the Stryker! I hate those things on my regular planes, though.
erkq is online now Find More Posts by erkq
Old Nov 24, 2012, 01:12 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
You can get them in grey.
airpower is offline Find More Posts by airpower
Old Nov 24, 2012, 01:21 AM
Joined Sep 2004
Gwsprops shows they are black so I ordered some. My lhs could only get orange. I suppose a black sharpie would work good enough...
Old Nov 24, 2012, 06:32 AM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Many of the you guys run on 3S?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Nov 24, 2012, 09:07 PM
BigEast is offline
Joined Mar 2012
I used a Dx18 for the following but this setup can also be transferred into a Dx6i or above. If using a dx6i, simply use the dual rates given and use one of the several mixes given:
First, below is my personal setup:
-Timer is set to 5:00
-CG in recommended location
-Travel setting for FLP and RRU are set to 70%, all other channels are set at 100%
-GWS4040 prop used
-Everything else stock
High rates:
Aileron: 100% rates, 20% expo
Elevator: 100% rates, 15% expo
Rudder: 100% rates, 5% expo
Middle rates
Aileron: 75% rates, 10% expo
Elevator: 75% rates, 10% expo
Rudder: 5% rates, 100% expo
(This rudder dual rate is set up on the same switch as the speed brakes are on. This is to protect the servos on the rudder when speed brakes are deployed)
Low rates:
Aileron: 60% rates, 10% expo
Elevator: 60% rates, 10% expo
Mixes:
For greater agility/roll rate: I adjusted these mixes specifically as to not overdrive the servos, but to give much greater pitch/roll responsiveness.
Mix 1: AIL>RAL
Rate: 34% 20%
Offset: 0%
Trim: Inh
Switch: (Select desired switch)
Mix 2: ELE>LAL
Rate: 34% 20%
Offset: 0%
Trim: Inh
For speed brakes, here are the following mixes: NOTE, in order to create speed brakes, disconnect the rudder y-harness from the brick and plug the rudders in their own port. "Dual rudders" must be selected in wing type as well.
Mix 3: RUD>FLP
Rate: 100% 100%
Offset: 0%
Trim: Inh
Switch: On
Mix 4: FLP>RRD
Rate: -100% -100%
Offset: 0%
Trim: Inh
Switch: On
Flap system:
Pos 0: 0% 0%
Pos 1: -90% -10%
Pos 2: 90% -10%
Speed: 1.4s
For a better hand launch, use the following mix as it gives a little up elevator before you throw the aircraft:
Mix 5: -A->LAL
Rate: 0% 15%
Offset: 0%
Trim: Inh
For reduced torque effect when throttle is applied use the following mix. This mix was done on a curve mix with 7 evenly spaced out points and was done with the DX18: This mix can be tweaked for your aircraft.
Mix 6: THR>RAL
1: 0%
2: -3%
3: -4%
4: -5%
5: -6%
6: -7%
7: -8%
Expo: Act
Trim: Inh
Switch: On
The following section contains experimental mixes that reduce coupling in knife edge. They can be tweaked for maximimum effect. Note that mixes 7, 8, and 9 should not be used at the same time as 10 and 11.
This first set of mixes lowers the amount of inboard rudder deflection:
Mix 7: RUD>RRU
Rate: -10% 0%
Offset: 0%
Trim: Inh
Mix 8: RUD>LRU
Rate: 10% 0%
Offset: 0%
Trim: Inh
Mix 9: RUD>FLP
Rate: 0% 30%
Offset: 0%
Trim: Inh
The following mixes allow deflection of only the outboard rudder;
Mix 10: RUD>RRU
Rate: -100% 0%
Offset: 0%
Trim: Inh
Mix 11: RUD>FLP
Rate: 0% -100%
Offset: 0%
Trim: Inh
The following mixes mix in a little bit of down delection of an aileron when rudder is applied. i.e left rudder input is given, left aileron deflects downwards:
Mix 12: RUD>LAL
Rate: -8% -8%
Offset: 0%
Trim: Inh
Mix 13: RUD>RAL
Rate: -8% -8%
Offset: 0%
Trim: Inh
Hopefully all of this helps somebody out. Who says you can't put thirteen mixes into a tiny stryker
Old Nov 24, 2012, 09:44 PM
Joined May 2011
I used a Dx18 for the following but this setup can also be transferred into a Dx6i or above:
My timer is set to 5:00
High rates:
Middle rates
(This rudder dual rate is set up on the same switch as the speed brakes are on. This is to protect the servos on the rudder when speed brakes are deployed. So when rudder movement is given when speed brakes are deployed, little movement occurs)
Low rates:
Mixes:
For greater agility/roll rate: I adjusted this mixes specifically as to not overdrive the servos, but to give much greater pitch/roll responsiveness.
Mix 1: AIL>RAL
Rate: 34% 20%
Offset: 0%
Trim: Inh
Mix 2: ELE>LAL
Rate: 34% 20%
Offset: 0%
Trim: Inh
For speed brakes, here are the following mixes: NOTE, in order to create speed brakes, you need to disconnect the rudder y-harness from the brick and plug the rudders in their own port. "Dual rudders" must be selected in wing type as well.
Mix 3: RUD>FLP
Rate: 100% 100%
Offset: 0%
Trim: Inh
Switch: On
Mix 4: FLP>RRD
Rate: -100% -100%
Offset: 0%
Trim: Inh
Switch: On
Flap system:
Pos 0: 0% 0%
Pos 1: -90% -10%
Pos 2: 90% -10%
Speed: 1.4s
Mix 5: -A->LAL
Rate: 0% 15%
Offset: 0%
Trim: Inh
Mix 6: THR>RAL
1: 0%
2: -2%
3: -3%
4: -4%
5: -5%
6: -6%
7: -6%
Expo: Act
Trim: Inh
Switch: On
This first pair of mixes lowers the amount of inboard rudder deflection:
Mix 7: RUD>RRU
Rate: -10% 0%
Offset: 0%
Trim: Inh
Mix 8: RUD>LRU
Rate: 10% 0%
Offset: 0%
Trim: Inh
Mix 9: RUD>FLP
Rate: 0% 30%
Offset: 0%
Trim: Inh
Mix 10: RUD>RRU
Rate: -100% 0%
Offset: 0%
Trim: Inh
Mix 11: RUD>FLP
Rate: 0% -100%
Offset: 0%
Trim: Inh
Mix 12: RUD>LAL
Rate: 20% -20%
Offset: 0%
Trim: Inh
Mix 13: RUD>RAL
Rate: -20% -20%
Offset: 0%
Trim: Inh
WOW!!!! Thats a lot of settings!!!! Obviously, I have some questions now.
1. Are speed brakes necessary? What do you use them for?
2. With Mix 5, do you turn it off right after hand launching?
3. What is coupling in knife edge?
4. What are outboard and inboard rudders?
Sorry if those questions are sort of stupid...first time flying a wing (thats what a stryker is right?).
Old Nov 24, 2012, 09:54 PM
BigEast is offline
Joined Mar 2012
No worries! Glad to help
Q1: Speed brakes aren't necessary by any means. It's used to slow down the plane. Basically what it does is move both rudders out or in.
Q2: Yes; I turn it off after I regain control of the plane.
Q3: When the plane is sideways, and I give it rudder to maintain altitude, it doesn't fly as straight as it should. It gives roll input when I just want up and down movement from using the rudders (while sideways). That is coupling.
Q4: When I give left ruder, the leftmost rudder is the outboard rudder and the rightmost rudder is the inboard rudder. When I give right rudder, the rightmost rudder is the outboard rudder and the leftmost rudder is the inboard rudder.
Hope that helps
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
