And I do have the mQX (fun!), the Beast 3D (didn't like it, dropped the brick in a SU-26 and loved it) and the MiG (beautiful, but EDF isn't my thing) so am well acquainted with the AS3X behavior and the one thing that can be said about the system is we all seem to experience it individually. I don't love it, don't hate it either but I think it has its uses allowing lighter models to fly in wind, something it does well. Flying the SU-26 with AS3X (20 grams lighter than the B3D at 55 g AUW) in 3-5 m/s wind was fun, mainly because it looked like a bad stop-motion animation. But the model did what I wanted and went where I wanted, flawless. Flying the Stryker on the same occasion I didn't even notice the wind. So, I my opinion the UM Stryker doesn't need AS3X and let's just leave it at that, ok? And if you really want it you could always drop a MiG brick in the Stryker and add a mixer to get elevon control. |
I've posted this before in hopes that someone would try it, I would if I had the B3D brick.
TODD http://www.rcgroups.com/forums/showp...&postcount=726 |
Don't do that. It doesn't work. The AS3X is doing NOTHING good. If he was smart, he'd make outboard ailerons (with an external servo) and inboard elevators (with the elevator servo) or better yet, trade the brick for a V1 Beast brick. |
Latest blog entry: AR6400 guillows Space Shuttle
Me too!
I prefer non AS3X most of the time anyways, I guess I'm just a control freak
Latest blog entry: Maybe my fleet is too big...
Where AS3X could potentially benefit is if the CG was moved back to the point of boarderline instability.... far enough back that the stryker without AS3X would suck in the wind (obviously no one is currently flying their stryker in this condition)... but with AS3X would still be flyable.
People would really like the crazy stuff the stryker could do in this case... stuff a lot crazier than what it can do, now, with a forward CG. If a plane is stable in 20 mph winds, it doesn't need AS3X... Move the CG back and it won't be stable in 20 mph winds without gyros. The CG on my AS3X Sbach is at a point where flights would last about 4 seconds in the calm without AS3X, but I fly it in 15 mph winds. |
United States, TN, Memphis
Joined Jun 2011
$92
http://www.wholesaletrains.com/Detai...p?ID=200864905 Last month I thought a used one for $80 with a repaired nose was a good deal, lol. |
Change of subject:
So, I've been spending waaaay too much time messing around with control mixes on my Micro Stryker. I have a DX8 and have been concerned that if I dial in the amount of pitch and roll that I want, then I'll overdrive the servos when I corner the stick (for an inverted flat-spin or other maneuver). I can actually hear the servo's whine jump louder when I exceed the the limits. I checked some of the Parkzone manuals and saw this text pertaining to those linear servos: Quote:
But, the helicopter programming DOES have an "E-Ring" feature that prevents servos on a swashplate from overdriving when you corner the sticks! So, my Stryker thinks it's a heli now! I set it for 135deg swashplate control. Then I opened the Stryker and moved the elevator servo to the pitch channel. In the Swash control, I zeroed out the collective so that nothing changes when I move the throttle stick, but I was now able to adjust the roll and pitch throws so that I can have nearly max elevator and roll, yet if I corner the sticks, they do not go beyond 115% (the limit of the linear servos). Perfect!Since I had it open, I removed the Y-split adapter and connected one rudder servo directly to the rudder channel, and then connected the other rudder servo to the Ch5/Xport channel. Spent a little time mixing Aux2 with those two channels, and I now have split-rudder control! My rudders now move twice as far to the outside as inside, and I now use the flap switch to enable two levels of "split-rudder" air brakes. Wish me luck, gents. This should be a wild test-flight on Wednesday! If all goes as planned, I'll post my DX8 SPM file. - Jim |
| Thread Tools | |
| New Product Parkzone F 27Q stryker | friz | Electric Plane Talk | 181 | Nov 04, 2011 02:54 PM |
| Video Parkzone Stryker F-27Q updated 23/07/2011 | Anda Inc. | Electric Plane Talk | 3 | Jul 23, 2011 05:26 AM |
| For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 | rcwarrior | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 22, 2011 11:02 AM |
