Old Jun 19, 2012, 04:02 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Originally Posted by SilentPilot View Post
Nice idea
Is that still work in progress?
I see the fus is missing and thought that might be what you were meaning by CG issues. The Stryker 180 can be nose heavy sometimes so your mod would help with that, now I see though that there is no board or battery!
Where do you plan to put them or is the fus going back on?
Yep still working on it but gettin close. No fuse just a reg wing, which is harder to get enough weight in the nose. That's why I moved the motor towards the nose a little over an inch. The RX is going to sit flat on top between the motor and battery bay, hopefully I'll get enough weight in the nose.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Jun 19, 2012, 05:30 PM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I thought it didn't look right at the back!
You should be ok. Most people think this is nose heavy to start with...
I nearly got some of those yellow HK servos for my Sbach but reports are that they don't like 3S
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jun 22, 2012, 12:25 PM
bladefan is offline
Find More Posts by bladefan
bladefan's Avatar
United States, OR, Portland
Joined Jun 2006
I may have damaged my motor. Crashed nose stright into light pole. Hard enough for the outrunner bell to fall off. Next flight, was WAY underpowered. Pulled bell off and cleaned with rubber eraser. Seemed like I cleaned off some marks. Next flight was much better but I dont think it had the same power as before.
Should I replace with another stock motor or is there another one out there that I should consider if I am going to spend some money replacing the motor?
bladefan is offline Find More Posts by bladefan
Old Jun 22, 2012, 09:04 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Took the Stryker out yesterday, did some slower flying
UM Stryker F-27Q 180 6/21/2012 (2 min 55 sec)
grovey is offline Find More Posts by grovey
Old Jun 23, 2012, 04:51 AM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
I've got a Stryker motor I'm not using. I'll let it go for 20 bucks. It has hardly any time on it. Under an hour. I put a Mighty Midget 13/6/9 CS on mine! The stock motor is actually pretty good on these. PM me if you want it. Now that I think of it, I've got the prop and adapter as well. 25 bucks for all of it shipped CONUS. Saves you 13 bucks and shipping.
MR2
minirips2 is offline Find More Posts by minirips2
Old Jun 25, 2012, 01:18 AM
AtomHeartMother is offline
Find More Posts by AtomHeartMother
Shine On !
AtomHeartMother's Avatar
Northern Ohio
Joined Feb 2003
Anybody breaking prop adapters? When I land the prop insists on clocking to the 6 and 12 position causing the prop adapter to snap right at the prop hub. A machined aluminum part would be nice here. I think it's the stress of the mounting screw pulling on the adapter with the 4x4 gws props....not to mention there's more prop hanging down when it clocks in that direction. I can do flybys and bump the throttle to try to move the prop to a more friendly 3 and 9 position, but that gets annoying after a while.
AtomHeartMother is offline Find More Posts by AtomHeartMother
Old Jun 25, 2012, 03:19 AM
BMFA 190658
Joined Mar 2007
Are you doing Elevator landings?
Old Jun 25, 2012, 04:44 AM
Shine On !
Northern Ohio
Joined Feb 2003
Yes, but I broke one on a normal landing as well... Been flying wings, etc.. for a long time...I can set them down pretty soft. Just seems to me the adapter is brittle/weak. I may play around with the 4x4 prop hub...take it down some and see if I can get some of the screw pulling stress off the prop adapter.
Old Jun 25, 2012, 05:30 AM
BMFA 190658
Joined Mar 2007
Hmm...
I always land with an Elevator and never had any trouble.
My only problems are launching the Stryker, if it were easier then I would have bought the big version too
Old Jun 25, 2012, 06:21 AM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
On the prop adapters - Search these forums for member ICU - or go to shapeways stores - He has essentially unbreakable prop adapters for a few dollars each. I can't swear by it, but know guys that have tried every way imaginable to break one of these on Sbach's, Beast's, CC, Stryker without success.
bobly is offline Find More Posts by bobly
Old Jun 25, 2012, 06:26 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by AtomHeartMother View Post
Anybody breaking prop adapters? .
Just in case, are you landing on grass? Never had one broke on me (mostly elevator landings, but straight and boomerang landings as well).
RealGambler is offline Find More Posts by RealGambler
Old Jun 25, 2012, 01:25 PM
Shine On !
Northern Ohio
Joined Feb 2003
Always land on grass RealGambler, but with the weeds, etc.. at my field the grass can be pretty tough. I forgot about shapeways bobly, thanks ! I have his site bookmarked.
Old Jun 25, 2012, 02:48 PM
Canada, QC
Joined Oct 2009
You may have hit a bad batch of prop adapters... I remember when the Beast came out, a bunch of reports came in that the prop adapters were fragile. I jumped on the bandwagon then, and ordered 3 of those adapters to make sure I would never miss a minute of flight. Guess how many prop adapters I have left today... THREE (yep, all of them are still in their original little bag).... Have not used one since, and I have about 5 airplanes with those prop adapters. Those reports where more than likely true, so only explanation would be that every now and then, there's a weaker batch of plastic that goes through the production line.... I think you'll eventually get a good one and it will last you a very long time. Sure enough, as other have suggested, if you want to be over with it, buy one of ICU's prop adapter. Those should be unbreakable!
Old Jun 25, 2012, 03:55 PM
Shine On !
Northern Ohio
Joined Feb 2003
I was thinking the same thing RealGambler...that there may have been a brittle batch from the factory. I have 2 oem adapters left and ordered a few from shapeway. Like you, I hate missing out on a fly day due to minor mechanical issues. The baby stryker is such a hoot to fly !
Old Jun 25, 2012, 09:24 PM
rcoconut is online now
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Ever since I switched from the over hand launch to the side arm launch life has been easier, as well as safer! After somebody on the full-size Stryker got his forefinger chewed up really bad by a prop strike during launch I switched to this real fast and I have NOT looked back! I launch his 'lil sister the same way but I go full-throttle. Big brother is 50-60% throttle and a different prop but stock motor:
Parkzone Stryker F-27Q Easy Hand Launch (5 min 6 sec)
IMHO this is the best way to launch by far! Re-think the full-size Stryker, you won't be sorry!!!
p.s.- I'm left handed so I hold the Stryker with my left hand on the right wing root, so I throttle up & than place my right hand on the right stick, don't even have to toss her, with the APC 7x6Sport she cruise right outta your hand
rcoconut is online now Find More Posts by rcoconut
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
