Old Feb 11, 2012, 11:39 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
This thread has made a very interesting turn!
and its sweet.. than you for this info!!
brushless55 is offline Find More Posts by brushless55
Old Feb 11, 2012, 03:37 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Can you confirm this?
I am far from being an EE and up on all of the MOFETS however there are a bunch of very smart minds over in the DIY Electronics Forum..
Many if not all of the MOFETS are not designed to be to used in such configurations but no the less many have in fact staked them on BL ESC with good results. Like I said power handling does not double but I believe 50% increase is about right.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 11, 2012, 03:42 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Charles
And a 50% increase would be perfect!
erkq is offline Find More Posts by erkq
Old Feb 11, 2012, 03:43 PM
big ignore list
Joined Nov 2011
Charles
That is awesome.. adding even 25% is good!
Old Feb 11, 2012, 04:14 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Charles
Charles,
Thanks for the reply. I'll dig into this and take a visit to the DIY Electronics forum. I just want to be close to 100% certainty I won't smoke the board. Others....feel free to add what you find. :-)
I looked at my UM Stryker board and it has 4606 BA1F1E inscribed on the mosfets. Based on the Manufacters symbol it is an Alpha Omega Semiconductor. The continuous current rating is 6 amps at 25C and 5 amps at 70C.
http://www.aosmd.com/pdfs/datasheet/AO4606.pdf
These mosfets are easy to get to. If this mod is possible, I'll be using conductive epoxy to secure the secondary mosfets on top of the existing mosfets. This hopefully ensures good heat transfer.
Updates on References:
This is a real good video showing how a mosfet works. In the 6400NBL we have IC's that contain 4 fets inside.
Transistor / MOSFET tutorial (4 min 50 sec)
http://www.mini-z-guide.com/mosfet.htm
http://www.rctech.net/forum/electric...e-current.html
http://www.fairchildsemi.com/product.../soic8_dim.pdf
http://aosmd.com/pdfs/datasheet/AO4616.pdf
http://www.mini-z-guide.com/FETInstall.htm
http://en.wikipedia.org/wiki/MOSFET
http://www.mcmanis.com/chuck/robotic...rial/h-bridge/
http://trebor69.tripod.com/speedcnt.html
http://www.ti.com/tool/rdk-bldc#Technical Documents
http://www.societyofrobots.com/elect...tutorial.shtml
http://www.societyofrobots.com/schem...ridgedes.shtml
http://www.avrfreaks.net/modules/Fre...ng%20Guide.pdf "Low cost SMD Soldering guide"
http://www.mcmanis.com/chuck/robotic...FET-power.html
http://www.atmel.com/Images/doc8012.pdf Sensorless control of 3-phase brushless DC motors
Digi-key does not list the AO4606. I'm thinking the 4616 is the newest version.
Silverexpress is offline Find More Posts by Silverexpress
Last edited by Silverexpress; Feb 19, 2012 at 01:06 PM. Reason: Updates on info I found and digested
Old Feb 11, 2012, 04:19 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Leading Edge Repair
Snapped one of the points of the leading edge today. Here are some picks of the repair I made with Gorilla Glue, a modelling pin and a blue marker pen, sorry the pictures are a bit blurred:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Feb 11, 2012, 04:28 PM
Your customer
Joined Dec 2009
These things are under a $1 usd. Lol. Cheapest bang for the buck if it works. It'll allow us to use higher KV or bigger lower KV motors, and increased pitch and or diameter props.
Update: PLD seems to be our man. I've emailed him some questions on doing this. Let's hope he responds back.
Update: PLD stated it was ok. Order for AO4616's on the way. I'll stack the as3x board and replace the AO4606's on the 6400nbl (to stay on topic here ;-) ). Thanks for the reply PLD.
http://www.rcgroups.com/forums/member.php?u=24181
Also, thanks to everydayflyer (Charles) for mentioning this.
Update:
I've been reading about DIY ESC's, and came upon TI's RDK-BLDC development esc board. A quick glance at the technical manual and I came upon programmable features for the esc microcontroller. On the TI RDK, the following parameters can be set to shut the motor down:
1. Over current
2. Under current
3. DC over voltage
4. DC under voltage
5. Over temp
6. Motor stall
The one that can prevent any benefit to this mod would be #1 above. If this value is set to protect the AO4606, an upgrade to the AO4616 or even stacking will be of no use. We will have to just give it a try and see.
I don't know if the microcontroller on the 6400nbl and AS3X have the above parameters. The BL controller chip has had its P/N and make scratched off by the manufacturer on both the 6400nbl and the AS3X, and thus I cannot research what features it has. If anyone knows what it is, let me know. After looking at a few ESC projects on the internet, not all have the same set of parameters.
Old Feb 12, 2012, 10:33 PM
rycomm is offline
Find More Posts by rycomm
Flyin' Ryan
USA, MO, Lee's Summit
Joined Sep 2001
Does anyone know of an airframe to put some mini stryker electronics into. I flew my stryker through a tree, and pretty much destroyed it. I was hoping to find a jet cat style foam design and transfer the electronics over. The stryker was great fun, but replacement parts seem to be a bit over priced.
Thanks, Ryan
rycomm is offline Find More Posts by rycomm
Old Feb 12, 2012, 10:41 PM
Your customer
Joined Dec 2009
Thanks, Ryan
You might want to check here:
http://m.rcgroups.com/forums/showthread.php?t=851608
Old Feb 12, 2012, 11:02 PM
bs_sunil is offline
Find More Posts by bs_sunil
Free crash course available!!!
bs_sunil's Avatar
United States, NC, Apex
Joined Oct 2011
Thanks, Ryan
If you want to go balsa..here the link to an awesome balsa Stryker..I am planning to build one...
http://www.rcgroups.com/forums/showthread.php?t=1263134
bs_sunil is offline Find More Posts by bs_sunil
Old Feb 13, 2012, 10:15 AM
big ignore list
Joined Nov 2011
Originally Posted by Silverexpress View Post
Charles,
These mosfets are easy to get to. If this mod is possible, I'll be using Artic Silver 5 to epoxy the secondary mosfets on top of the existing mosfets. This hopefully ensures good heat transfer.
Update:
1. Over current
2. Under current
3. DC over voltage
4. DC under voltage
5. Over temp
6. Motor stall
Awesome stuff man!
thank you for posting more info
Old Feb 13, 2012, 11:07 AM
Your customer
Joined Dec 2009
Awesome stuff man!
I find this real fun. Thanks. Having dealt with microcontrollers first hand in other applications I knew that the actual function of OCP, under voltage, over voltage...etc...had to be performed by something else. Googling OCP, I found this
http://www.national.com/news/item/0,1735,550,00.html
Just an example of ic's that provide these functions. The processor does nothing more than collect and act upon the information passed on to it from these chips.
I'll take a gander at the 6400nbl again tonight. I could have sworn there was an LMxxxx chip on it :-(
Update: On the back of the AS3X is a bank of resistors :-( these can also be used for monitoring current.
FYI: I'm not trying to reverse engineer these boards. Just looking to see if additional fets or possibly better fets can be used.
Update: Here is a reference on using resistors for current sensing:
http://www.ti.com/analog/docs/micros...=7&familyId=57
I need a closer inspection of the AS3X board to see if the traces connect the bank of resistors in parallel/series. If so then a real good possibility that this is what is being used for OCP sensing. You can see the bank of resistors in the upper right of this picture I posted a while back.
http://www.rcgroups.com/forums/showp...&postcount=532
Next question is "what is OCP really being used for?". What is it protecting?
HH stated that it was a the tolerance of a few components that's causing the OCP issue in the GEE BEE. Could these be the bank of resistors???
Old Feb 13, 2012, 12:12 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Originally Posted by FlyinCowboy View Post
Can't snooze behind the controls. Dang.
Did the same, and I used toothpicks and gorilla glue, good as new.
kenstogie is offline Find More Posts by kenstogie
Old Feb 13, 2012, 01:00 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
UPS tracking shows that my new board will arrive on Thurs.
I've been having a (3S) blast with my Beast 3D. (Aprox 20 flights now)
Peak charging to 4.0V per cell is working well.
http://www.rcgroups.com/forums/showp...ostcount=13887
I'll be flying the Stryker/4040 combo on 3S asap!
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Feb 13, 2012, 01:46 PM
Your customer
Joined Dec 2009
rc
Hello RCB,
What did you burnout on your board with 3s? What's the highest current draw you've seen? I'm trying to get an idea of what amps OCP gets triggered.
Nevermind: Find your prior post regarding what blew. It's the middle mosfet. Did you get a max current reading? If the max is well above 5 amps, than that means OCP get's triggered well beyond and we may actually benefit from stacking the fets (if we can find a source for AO4606)'s or replacing them with the AO4616 fets from the Beast 3D AS3X board.
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
