Old Feb 06, 2012, 09:46 PM
bs_sunil is offline
Find More Posts by bs_sunil
Free crash course available!!!
bs_sunil's Avatar
United States, NC, Apex
Joined Oct 2011
Originally Posted by minirips2 View Post
BSD is the distributor for Mighty Midget Motors here in the US. I haven't seen them anywhere else. The performance and efficiency of these motors is exemplary.
I think the MM Competition Special is really made to spin bigger props more efficiently, for F3P. I'd be very curious to see what RPM it turns. Unfortunately, MM doesn't list KV in their specs, which I think is odd. I've got one looking for a home, so I'm quite interested in this
MR2
Here is the link to the original manufacturer of midget motors
http://www.microbrushless.com/
and here the link in RC group. His name is Uttam (pronounced "ootam" "oo" as in oops)
http://www.rcgroups.com/forums/showthread.php?t=500301
Probably he can answer the questions...
bs_sunil is offline Find More Posts by bs_sunil
Old Feb 06, 2012, 10:04 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Originally Posted by nate32 View Post
Happened to me too.... slammed my into the ground yesterday and destroyed the front. It happens on rare occasions though and thats the first time it has caused a crash. Maybe from having the travel adjsutment at 125% for the dx6i could be causing it to stick..
Never go above 100% or the servos WILL stick. That's your problem.
airpower is offline Find More Posts by airpower
Old Feb 06, 2012, 10:34 PM
micromantis is offline
Find More Posts by micromantis
No mods no glory!
micromantis's Avatar
United States, CA, Redwood City
Joined Nov 2010
Plenty power, unlimited vertical.
The Thunder Power 2S 250mAh 25C battery fits perfect with 12-15 min flight times. My favorite daily bird.
Might Midget 13/6/9T
GWS 4540
1.5mm id, 3mm Collet
Stock Brick
TP 2S 250mAh 25C (fits perfect, no need to hog out fuse)
micromantis is offline Find More Posts by micromantis
Old Feb 06, 2012, 10:52 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
GWS 4540
Stock Brick
The Stryker has unlimited vertical stock. This thing must be a monster!
erkq is online now Find More Posts by erkq
Old Feb 06, 2012, 10:55 PM
No mods no glory!
Joined Nov 2010
LOL
She is
Old Feb 06, 2012, 11:01 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Originally Posted by Diesel6401 View Post
Was wondering if anyone here had some dimensions for the stock 200mah 2s batt. This is suppose to be the stock battery supplied with the umx mig and just trying to figure out which lipos will work best (besides stock). Thank you in advance.
Diesel,
E-flite 2S 200mAh:
L x W x H
41x18x13mm
rc
ps. If the MiG flies that well in the vid on an E-flite 200 we are in for a treat with the Hyp 2S 240!!
RCBABBEL is offline Find More Posts by RCBABBEL
Old Feb 06, 2012, 11:02 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Old Feb 06, 2012, 11:06 PM
bs_sunil is offline
bs_sunil's Avatar
Joined Oct 2011
LOL
She is
Oh god...not another mod...how do i convince my wife that buying these new parts is more important than her shoes..
Old Feb 06, 2012, 11:16 PM
Diesel6401 is online now
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Originally Posted by RCBABBEL View Post
Diesel,
E-flite 2S 200mAh:
L x W x H
41x18x13mm
rc
THANK YOU! That is EXACTLY what I needed! Yea the battery is suppose to be the same for the Mig. That Hyp 240 should really wake it up.
I was hoping to use this http://www.hobbypartz.com/77p-sl350-2s1p-20c-2222.html but I believe it may be to big. I will have to take a good look at that Hyp 240. Once again thank you! The Stryker 180 is also on my to buy list. Just hard to keep up with all the RC offereings! I did pre-order the mig though.
Diesel6401 is online now Find More Posts by Diesel6401
Old Feb 07, 2012, 07:00 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
OK found the USA Dealer but no 13/16/9 listed.
http://www.bsdmicrorc.com/index.php?...ID=52&offset=0
Edit I finally found it
http://www.microbrushless.com/productsG3f3p.htm
sure was well hidden.
Listed performance
GWS 4.5*4 3.3 128g 13200
4.5 X 3 = prop loading factor of 60.75 ( short formular)
for a 4X 4 prop loading is 64 and the stock E flitewith the
GWS 4040 prop
Max. A 3.96 / 29.5 watts
Holds 12,300 RPMS / 3.7A
Also just curious do you often get above 1/3 throttle?
I pull on average 160 mAh in 5 min. which would be approx. 8 min. if I drained a 250 flat or aprox. 7 to 7-1/2 limiting DOD to 80 to 90%.
I wonder if MicroDan has something similiar.
Charles
Old Feb 07, 2012, 07:40 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Yanked out my board today.
Easy job.
Everything is super accessible.
This plane is begging for a speed mod job.
Check out that cracked center FET.
rc
Old Feb 07, 2012, 07:48 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Easy job.
Check out that cracked center chip.
rc
What mod you thinking bro?
I've also blown a chip like that on a 200a 8s esc while plugging in 4s
never could figure out what cause that one..... made me a little upset thoug..
brushless55 is offline Find More Posts by brushless55
Old Feb 07, 2012, 09:00 PM
RealGambler is online now
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Easy job.
rc
Those are the FETs!?!?!? Easy to replace, but hard to explain why the board would have died when plugging the battery. I guess a fast glitch, or simply making the beeps could draw a lot of current...
So, what is the status of that receiver again? Board totally dead?, or everything's working but the motor? If the board is totally dead, I would think that something else is also blown somewhere else.
RealGambler is online now Find More Posts by RealGambler
Old Feb 08, 2012, 07:48 AM
MJF is offline
MJF
Find More Posts by MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
Has anyone ever put the stryker guts in a polecat or sukhoi or whatever
MJF is offline Find More Posts by MJF
Latest blog entry: eflite ultimate 20-300
Old Feb 08, 2012, 10:02 AM
Rob_G is offline
Find More Posts by Rob_G
Regina, SK
Joined Nov 2006
Easy job.
rc
I have a spare board I'd trade you for some batteries
Rob
Rob_G is offline Find More Posts by Rob_G
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
