figured it out but kind of did it old shool. Found out what lead went to what servo and so on. Horizon put out a bulliten on it. http://www.horizonhobby.com/ProdInfo...dum_083111.pdf
Canada, QC
Joined Oct 2009
4 possibilities:
1- Because that's the one the design engineer had on his desk when they put the first prototype together! ![]() 2- Because somebody made a mistake when they did the Bill Of Material for the assembly line, and got the wrong part number. Once ordered, they went ahead with that part. 3- They wanted to make it a bit harder on us to get third party batteries, though we all know that it won't work. 4- They looked at lots of connectors, and found out that only that one could carry the current, was light enough, easy to use, allow for balancing, and had the minimum number of insertions high enough to meet their need. (I was kidding about option 1 to 3... Option 4 is probably (or hopefully) the real reason )
Canada, QC
Joined Oct 2009
Are you using full rates? If not, that's your problem! Because otherwise, it's only a question of going full elevators. Just kill the throttle while you're about 20ft in the air, let it slow down and progressively add elevator to keep the nose slightly up. Basically, you'll loose forward momentum, and slowly end up with full elevator, and the Stryker will elevator land itself. Once you get use to it, next step is to learn how to do the cobra (kill any speed quickly). Basically, even if you go fast, you can stop the plane on a dime, with a full elevator (doing a full nose up, ie, a cobra), then, level the plane and do an elevator landing.
Keystone State, USA
Joined Jun 2007
I believe I came across it in this thread somewhere, but can't find it now...
So If someone could answer or point me in the right direction... When using the DX8 with the UM Stryker what DR's are being used to NOT overthrow the linear servos? when at full rates.... |
Joined Dec 2004
Maidened my new stryker this morning after figuring out the dx6i programming. removed the front wheel and put the battery all the way back. Only took a few clicks of elevator and aileron trim. Fun plane, high rates are crazy
..kept it on low. Now I need more batteries.
Ft. Lauderdale, FL
Joined Sep 2006
My Ultra-Micro F-27Q is HORRIBLY NOSE HEAVY!
With stock battery all the way to the rear it needs so much up elevator to stay level at 1/2 throttle that giving it full throttle puts it into an immediate loop without giving corresponding down elevator. Not fun to fly at all this way... Why does Horizon keep making this mistake! ![]() It's the original UM Sukhoi all over again... ![]() Did any of you completely remove the foam block in the rear of the battery slot and place the battery all the way back to the receiver? I was hoping that cutting out the foam block won't weaken the structural integrity of the plane??? What elese can be done to lower a terribly forward COG in it's stock form! |
Canada, QC
Joined Oct 2009
Take off the wheel!!
Latest blog entry: Maybe my fleet is too big...
United States, CA, Sebastopol
Joined Dec 2010
| Thread Tools | |
| New Product Parkzone F 27Q stryker | friz | Electric Plane Talk | 181 | Nov 04, 2011 02:54 PM |
| Video Parkzone Stryker F-27Q updated 23/07/2011 | Anda Inc. | Electric Plane Talk | 3 | Jul 23, 2011 05:26 AM |
| For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 | rcwarrior | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 22, 2011 11:02 AM |
