Old Aug 31, 2011, 10:30 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Well I posted pics, included info, and no help...I guess I will have to add weight to my right wing. I can't believe I am the only one with this problem of the left bank tendency. Wish I could find a solution.
J
jabsten is offline Find More Posts by jabsten
Old Aug 31, 2011, 10:36 PM
Kaw1000 is offline
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
J
Maybe thrust angle of engine got knocked outta wack? One aileron higher than other or not hinged right? put it on your finger center of fuse see if it tips to on side or other.( kinda like checking cg) Make sure rudders are centered?
Other than that don't know what to say.
Kaw1000 is offline Find More Posts by Kaw1000
Old Aug 31, 2011, 10:38 PM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
The pics were quite small, hard to see any problems that might be there...in the last pic, is the plane sitting perfectly level? One simple thing you might have already checked, are the wings nice and straight and level? I.e. no warping or twisting, or one wing being higher than the other? With these little planes, it doesnt take much to cause big problems. Kaw1000 has some good suggestions as well.
Nick
micro_builder is offline Find More Posts by micro_builder
Old Aug 31, 2011, 10:46 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
So you're into private videos, eh?
Originally Posted by RealGambler View Post
Well, I have a #3 keychain that work since day one (must be 3 years old). But this is a video from my second HD #11 keychain, and guess what, it died on me as well... No luck with those little HD cam... But, even if the video is screwed, there was some funny stuff, so I still put it on youtube (almost look like it was taken by an infrared camera!).
Basically, a bird that was interested by my Stryker, and two failed upright boomerang that ended on the ground. Don't worry, I normally bail out early, those are the exceptions. I was trying, and trying, and trying, and not watching how fast the ground was coming toward my airplane . But yes, I'm now better at upright boomerang (still end up inverted too often, but hey, winter is not here yet...) . No damage on the Stryker so far.
http://www.youtube.com/watch?v=1c1cAD8cB9Q
erkq is online now Find More Posts by erkq
Old Aug 31, 2011, 11:08 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Nick
There is no warping, and they are straight. When I do the cg test it sits straight and true. My ail are centered. I don't know, but thanks for the suggestions. It could be an offset rudder.
Justin
Old Sep 01, 2011, 05:48 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Got my maiden flight of the UM Stryker in this morning. All I can say is WOW, what a great plane. Only flew one pack through but was pretty easy to get on to coming from the Beast only a week ago. It certainly is fast and twitchy even on low rates which is all I tried so far. Bit nose heavy that I had to trim out for now, will have to cut out some foam to get battery back it seems forr proper CG. And I LOVE parachute landings, one of the best things about this plane I think, and that was even with the low rate settings, on high it should drop in even more vertical.
Only issue I ran into was a broken nose. Did what appeared to be a fairly soft slightly nose in landing into soft wet grass and the nose cone popped but also broke part of the foam. Nothing major but I think that pin the rubber attaches to does more harm than good as it looks like the pin itself did the damage putting the force into the foam.
I wonder if it would be better with the pin removed and the rubber nose attached with CA directly to the foam instead? Or maybe reducing the length of the pin to a 1/4" or less, so it doesn't extend so far as all it needs to do is hold the rubber. Even velcro might be better. Would reduce the nose weight as well as possibly prevent the issue I had. Anyone try this or a similar mod?
Maiden video to follow...
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 01, 2011, 05:50 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Oooops, I put it private while it was uploading, then I modify it to public when it's finished... I guess it took a while for Youtube to receive the modification... Sorry! As I said, not a great video anyway, since the %?$&$% camera was dying on me, so that's why I was low profile!
RealGambler is offline Find More Posts by RealGambler
Old Sep 01, 2011, 05:55 AM
Canada, QC
Joined Oct 2009
Originally Posted by schooner2000 View Post
I wonder if it would be better with the pin removed and the rubber nose attached with CA directly to the foam instead? Or maybe reducing the length of the pin to a 1/4" or less, so it doesn't extend so far as all it needs to do is hold the rubber. Even velcro might be better. Would reduce the nose weight as well as possibly prevent the issue I had. Anyone try this or a similar mod?.
You're probably the first who would attempt such a mod... Sure enough, if you could weight that pin for us (if you decide to stick the nose directly), that would be great... Because if it's heavy, it would definitively be a decent mod for those with nose heavy Stryker... Probably hard to remove though, looked like it was stuck very well.
Old Sep 01, 2011, 06:00 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
It is pretty light so not sure if my scale will weight it or not. It wasn't as hard to remove as I would have liked
I think for short term I will just CA it back in as is, but if it happens again I think I'll remove it and go with velcro, like a small circle in the middle.
Site Sponsor
Old Sep 01, 2011, 06:29 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Nothing too exciting flying wise. Maiden flight of my new Stryker...
UM Stryker Maiden (5 min 19 sec)
Site Sponsor
Old Sep 01, 2011, 08:32 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Is there any way to fix compressed foam on these UMs? I know with EPO you can use hot water to expand it back, any way to do it on these or bascially it is what it is and just live with it or fill it?
Would like to fix my nose compression if I can before I CA piece back in. It isn't compressed very much but would like to get it back if there is a way.
Site Sponsor
Old Sep 01, 2011, 08:42 AM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Well if some of you have used a 4x4 I think I better give it a try. Hopefully that will speed it up enough for me to enjoy flying it instead of cussing it for being to slow.
Hance is offline Find More Posts by Hance
Old Sep 01, 2011, 09:44 AM
wgarman is online now
Find More Posts by wgarman
More Planes Than Sense
wgarman's Avatar
United States, PA, Wexford
Joined Feb 2010
Parallel Charging
My thanks also for all the parallel charging info. That cleared things up a lot. This electrical stuff confuses us civil engineers
wgarman is online now Find More Posts by wgarman
Old Sep 01, 2011, 10:45 AM
Elisecat is offline
Find More Posts by Elisecat
"Add Lightness"..Colin Chapman
Keystone State, USA
Joined Jun 2007
The hot water trick will work. It has been done on the Sbach (by me and others).
I can tell you it works as I essentially busted the whole front half of my Sbach off and after water and epoxy it is back to flying as new!
Elisecat is offline Find More Posts by Elisecat
Old Sep 01, 2011, 10:48 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Great thanks, I'll give it a try.
Site Sponsor
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Video Parkzone Stryker F-27Q updated 23/07/2011 Anda Inc. Electric Plane Talk 3 Jul 23, 2011 05:26 AM
For Sale Latest PNP F-27Q Stryker (NIB) Kansas City Area $180 rcwarrior Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2011 11:02 AM
