Old Jul 27, 2011, 08:28 PM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Mini-Review
Turnigy Monster Beatle Review - Awesome Little 4WD Buggy
Owned exactly zero RC cars as of a month ago (my collection includes plenty of RC planes and heli's), but found this little buggy - the Turnigy Monster Beatle - at HobbyKing and it looked like a good deal for $70, considering it was a 4WD buggy powered by a brushless motor w/25A ESC. I also lacked a decent 3CH pistol-grip Tx for cars, so I bought the HK-300 2.4Ghz Ground Radio for under $20 bucks at HobbyKing, can't beat that price, and the radio works well and feels great (I pulled the 8AA battery compartment and used a 2600mAh 1S LiPo instead).
Took it out of the box on arrival, was packaged very nicely. Only initial modification I made was to threadlock and CA some screws as per the recommendations within the included instruction manual. I pulled the battery posts to make extra battery room as I own a couple dozen 3S 2200mAh LiPo's. I figured that I'd try 3S even though the Monster Beatle was advertised to run on 2S, might as well give it a shot.
A couple clicks of steering trim and the Monster Beatle was driving like it was on rails, also needed to turn the throttle trim down as the Monster Beatle literally took off like a rocket even with the slightest throttle trigger. I bet this thing was hitting speeds of over 30mph at full throttle.
The suspension does a great job of keeping the buggy on the ground even when cruising around at fast speeds and cranking the wheel to make it spin out, it's a blast. I've had over 30 runs with it now, I get nearly 25-35 minutes of solid run time from a charged 3S 2200mAh 25C LiPo pack, which is excellent, especially for someone accustomed to planes that have a max flight time of 7-10 minutes.
There was one caveat, however, on 3S you do need to be careful on the throttle. After 10-12 minutes of cruising around at fairly high throttle, the ESC and motor would nearly burn your finger when touching them. The Monster Beatle needed a Monster Heatsink. Unfortunately the motor is sort of cramped in there, but the ESC was ripe for a heatsink modification. I pulled off the plastic ESC case and stock heatsink (which was really small), and pulled a big CPU heatsink off an old Xbox motherboard. Used a combination of thermal paste and RTV silicone on the corners to really lock the heat sink down to the stock 25A ESC. Used a large 18" zip tie that happened to fit perfectly over the area where the ESC and Rx were mounted.
Now the ESC doesn't even get warm no matter how long I cruise around, but the motor still heats up into the 150-175F range. The motor is mounted to a metal plate, so I may try to run some metal from the large CPU ESC heatsink to the metal motor mount to bleed off more heat into that main heat sink, not sure how effective it would be, or if it would work. As long as I limit my fun to 10 minutes or so, the motor does get hot but not hot enough to toast it.
Overall the Turnigy Monster Beatle was a great investment, it's an excellent first off-road RC buggy and obviously suited well for someone who lacks RC car experience (like me). It handles best on paved surfaces, but short grass or gravel is perfectly fine for the Monster Beatle, it can get through most terrain easily with its rugged tires and 4WD drive system. Definitely a great buy at $70 + shipping (HK US warehouse now has the Monster Beatle in-stock!).
ChrisWNY is offline Find More Posts by ChrisWNY
Old Jul 27, 2011, 10:22 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Thanks for the write up. I have one on the way this week with 2S 1700 lipos. I hope to have it setup with an FPV 900 mhz before the end of the week. The challenge will be to get cool air over the video gear, but keep it from getting creamed in a roll over.
cactus is offline Find More Posts by cactus
Old Jul 28, 2011, 08:55 AM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
@cactus - it's actually a challenge to roll the Beatle over on a paved surface, but if you're speeding along off-road at full throttle, anything is possible. Your best bet might be to put the video gear inside the Beatle if it fits, cut out the windshield and a vent in the rear of the canopy and that should allow some airflow over the video gear, as well as the ESC and motor inside the Beatle. It's a great little buggy, you'll like it.
Old Jul 28, 2011, 08:46 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
Got some laps in with mine and it is fast on 2S! I noticed it is making a clicking sound from the drive train, so I have to figure that out before I drive it much more. Nice little rig.
Edit: The clicking was from the steering servo when the travel was too far. I dialed it back with my digital trims and its running great.
I put my video gear on it and cruised around the basement. In stock travel, it is way to jumpy and fast for precision driving via FPV, so I'm going to make a second model memory for it and make all the travel adjustments max out at walking speed. This will be the setting I let my 6 year old try!
Old Aug 09, 2011, 11:42 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
I had my steering servo go out yesterday while my son was cruising around on the reduced throttle travel setting I have for him. I had a Hitec HS-81MG servo lying around that fit perfect. This little thing is FAST on 2S.
Old Aug 10, 2011, 04:31 PM
nicoyenny is offline
Find More Posts by nicoyenny
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
I just got mine, boy this is FAST and a lot of fun. I can do back flips on my shoes!!! (NOTE: when flying my planes, sometimes an observer will request me to do a "backflip", my answer is always that I am too fat to do that and by doing a backflip I would lose control of my plane and probably crash, of course they want me to do a loop, but I dunno exactly what they mean...)
NOW I can make my little car DO backflips, this beetle is amazing, I ordered a bunch of replacement parts for it (incredibly inexpensive) just in case, not to be left stranded ...
I FULLY recommend it to anyone who wants to have some fun and not break the bank on a mini revo ...
nicoyenny is offline Find More Posts by nicoyenny
Old Aug 10, 2011, 04:37 PM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
That's good to know - I actually have a spare HS-81MG so if the steering servo breaks I'll have a good replacement. I'm still running on the stock steering servo, no issues so far.
Old Aug 11, 2011, 12:17 PM
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
QUESTION:
What bodies fit this truck?
HK does not show replacement shells, and it would be nice to have a custom body for it ...
Old Aug 11, 2011, 01:57 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
Originally Posted by nicoyenny View Post
QUESTION:
I was about to post the same question, looking myself. I want a second body to house FPV gear on so I can swap them out.
Old Aug 29, 2011, 12:15 PM
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
bodies? anyone?
Old Sep 07, 2011, 12:30 AM
ezarc is offline
Find More Posts by ezarc
Joined Sep 2011
Good read, Im buying one of these next week.
I thought I would sign up and give you guys the link to the body shells as the info here helped me out.
http://www.hobbyking.com/hobbyking/s...ell_110BS.html
They are on backorder so it might take a few weeks to get one.
Also the Kyosho Mini Inferno body shells fit, as well as the wheels, oil shocks and many other interchangeable parts.
ezarc is offline Find More Posts by ezarc
Old Sep 07, 2011, 02:41 PM
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
Thanks!
I just noticed they are listing the shell, too bad it's backordered
Old Sep 07, 2011, 06:25 PM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
@ezarc - Thanks for noting the interchangeability with the Kyosho Mini Inferno, I'm sure that will be good to know for spare parts in the future!
Old Sep 08, 2011, 02:04 AM
ezarc is offline
Joined Sep 2011
Turnigy just released a new on yesterday, apart from the obvious it shares all the same parts with the Monster Beatle.
1/16 Brushless 4WD Racing Buggy w/25A System
Old Sep 08, 2011, 09:22 AM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Other than the tires and chassis, it looks identical internally to the Monster Beatle. I would've had to use a much smaller heatsink with that chassis...
Question 1/16 Brushless 4WD Monster Beatle from HobbyKing merlin703 Off-road Cars 2 Jul 22, 2011 07:20 AM
Sold "Dutch " pricing, now $66 - Excel 4WD 1:10 nitro buggy and all accessories codell Cars - Cars and Parts (FS/W) 11 Jul 21, 2011 05:06 PM
Sold Excel 4WD 1:10 nitro buggy and all accessories codell Cars - Cars and Parts (FS/W) 5 Jul 07, 2011 10:16 PM
For Sale FG Modellsport Gas Powered Off-Road Buggy Beatle Racer with Zenoah 26cc Gas Engine herbdusowitz Cars - Cars and Parts (FS/W) 0 May 25, 2008 09:20 AM
