Old Jul 27, 2011, 03:33 PM
Jassel is offline
Find More Posts by Jassel
Joined Jul 2011
Help!
mCPx: something's fishy. Servo? Electronics? ***SOLVED***
Hi there!
Problems with my mCPx. It worked great for ~50 flights but now it's behaving strangely.
When throttling up, it moved in pulses in a clockwise direction (first video). Hovering thereafter went OK for about 5 sec when all of a sudden it jumped up and crashed. The rear servo had, without my input, gone all the way to the upper limit and had become stuck there.
When starting it up now (after manually returning the rear servo), one can see that the left servo does weird things as well. Also, the blue LED on the 3-in-1 board flashes irregularly but in sync with the servo twitches (2nd video). Possibly, it loses connection to the transmitter.
I've re-bound it to my DX8. Now the blue LED stays solid but the rear servo's standard position is all the way up. Won't move down even with full backward cyclic.
Anyone else experienced something like that? What's the most likely error source? Any suggestions?
Cheers,
Jassel
first video:
mCPx rotating in pulses; electronics error? (0 min 52 sec)
2nd video:
blade mcpx behaving strangely (1 min 34 sec)
Jassel is offline Find More Posts by Jassel
Old Jul 27, 2011, 04:43 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Looks like you got the servo jitters. Your at the time this can happen (40-50 flights).
This is caused by the servo conductive contact strip (the silver stripe) having black stripe marks on it.
See this thread for information, how to clean them, and what to use.
I am CX2Pilot over there. I posted a lot of information on the
last 3 pages.
Vibration or shakes? CHECK THIS!
http://helifreak.com/showthread.php?t=289666
Tom
Tom Z is offline Find More Posts by Tom Z
Old Jul 28, 2011, 05:07 AM
Jassel is offline
Joined Jul 2011
Tom,
I actually cleaned the rear servo a few days ago so I don't think it's servo dirt causing this problems. Swapping servo connectors on the 3-in-1 board shows that it's probably the rear servo and not the 3-in-1 that causes the problems. I guess I will replace this bugger with a new one.
Old Jul 28, 2011, 04:29 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Next thing to check. This happened to me after a crash and the servo
was doing what yours is doing. Mine was the ELEV servo.
Open the servo back up and check the wiper arms.
Mine got bent down in the crash and the servo jittered like yours. The finger tension was not tight
enough on the conductive strips to make proper contact.
I bent the arms back up with micro tweezers and it works like new again.
Check that no fingers are bent down or bent crooked.
Also check on the wiper arms is too see if they are worn out.
If all this is OK then sounds like you need a new servo.
This is a picture of a servo with worn fingers and one finger is bent.
Tom
Old Jul 31, 2011, 06:51 AM
Jassel is offline
Joined Jul 2011
Tom,
thx for your suggestions. I checked the servo and it looked nice and clean with no abnormal bends in the fingers. Anyway, I've replaced it with a new one and the swashplate movements are fine now.
HOWEVER, the problem of the blue LED going off from time to time together with servo movements and different motor noises persists (visible in both videos). I have the suspicion that my mCPX either loses power completely for short periods or that it loses connection to the transmitter.
The battery cable is fine (checked with a multimeter) and the connection between my radio and another heli (mSR) never has any issues. Possibly, the 3-in-1 is to blame after all. Time to go to my dealer / connect Horizon.
Old Jul 31, 2011, 07:05 AM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Before you replace the 3in1 try a new main motor. I'd say that will fix your loss of bind every second or so.
You could also just unplug the existing motor and see if the blue led stays solid.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Jul 31, 2011, 12:12 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by Jassel View Post
Tom,
I would try replacing the whole battery cable.. Just checking with a multimeter will not show the problem of broken strands of wire causing a low voltage to the RX....
livonia bob is offline Find More Posts by livonia bob
Old Aug 08, 2011, 04:02 PM
Jassel is offline
Joined Jul 2011
OK, it's flying again Seems it suffered from a combination of problems:
1)
The rear servo needed to be replaced. It looked fine on the outside and the mechanics did as well. I don't know what was wrong with it.
2)
The main motor was worn out. Replaced.
3)
The battery lead had several strands broken ~1 cm from the battery connector. Replaced.
Problems 2) and 3) were causing the loss of power/signal and thus the pulse-wise rotation.
Thank you all for your input!
Cheers!
-Jassel
Old Aug 08, 2011, 05:01 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I've had a problem where the aileron servo would suddenly go full right sending my heli crashing hard. This would happen at about 10 secs from lift off. It was weird to look at! I solved it by switching the aileron and pitch servos. I have no idea why that worked but it did. Wish I took a video of it before fixing it
tonyastro is offline Find More Posts by tonyastro
Old Aug 09, 2011, 07:55 AM
scottyvisco is offline
Find More Posts by scottyvisco
This helicopter smells funny
scottyvisco's Avatar
Berwick,Victoria,Australia
Joined Dec 2008
I have just had the same intermittent problems with a servo, i finally traced it to the servo motor being worn out and not having enough power to drive the gear-train ,put a new motor on and it works fine again
Cheers Scott
scottyvisco is offline Find More Posts by scottyvisco
Discussion New Minimum Wage for All! Oh wait...something's fishy Big Foot 48 Life, The Universe, and Politics 252 Feb 04, 2007 09:25 PM
First flight on Seledkin - Something fishy JeffD Electric Sailplanes 3 May 22, 2001 09:09 AM
